Installing a 5.0 TB on cyclone - Mustang Evolution
Old 02-11-2015, 12:02 AM   #1
roushMarlon831's Avatar
Send a message via Yahoo to roushMarlon831
So I will undergo this experiment and was wondering. Will a 5.0
Intake fit it and fit properly on my car. My buddy is selling me his and wanted to know
roushMarlon831 is offline   Reply With Quote
Old 02-11-2015, 12:15 AM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
No, the placement and angle of the throttle body on the cyclone and coyote are different. A lot of modification would be needed, and even then, it still might not work
2012 Kona Blue 3.7L V6:
Old 02-11-2015, 12:16 AM   #3
Thanks, I didn't think so either.
Old 02-11-2015, 04:42 AM   #4
Siber Express's Avatar
Read away Gt throttle body on a v6
Old 02-11-2015, 10:49 AM   #5
Yes look at the other thread. A TB from a 5.0 fits just fine after a little massaging. I have done it.
Sent from my XT1080 using Mustang Evolution mobile app
lowbwan is offline   Reply With Quote
Old 02-11-2015, 10:49 PM   #6
Originally Posted by lowbwan View Post
...a TB from a 5.0 fits just fine after a little massaging. I have done it.
How did it work out for you? What did you notice different in driveability and performance?
What did you have to do to get it to fit properly?
GT 1 is offline   Reply With Quote
Old 02-12-2015, 07:29 AM   #7
I have had the 5.0 on my cyclone for several months. There has been little effect on mileage. The drive-ability seems better. The throttle response is better. No down sides so far. I have not dynoed the car since the change.
The hole pattern is wider on the 5.0 TB. All the holes have to be elongated toward the middle of the TB. The butterfly opens the opposite direction from the original which turns out not to be an issue but is necessary to understand when modifying the upper intake. The "quiet fingers" located directly behind the TB inside the upper intake must be removed to allow for full operation of the butterfly. This is done with a pair of needle nose pliers.
Old 02-12-2015, 07:43 AM   #8
How about sound wise. Is there a change in engine sound? A growl or something
Old 02-12-2015, 11:50 AM   #9
The sound is bigger. I added headers at the same time so it is hard for me to say.
I did it because it makes sense. BBK sells a 73mm TB for $400 and claim it works wonders. This mod cost me $56 and I have an 80mm TB. I am currently porting and matching my lower intake which is reported to add 20 rwhp. This TB addition can only help. I checked with my tuner before I did it. He was able to show how the TB mod was within the range of the tune to adjust. So your engine will adjust by itself to the change.
2011 Motor trend video for the V6 Cyclone Mustang 3.7 engine ronnie948 2011-2014 V6 Mustang 2 07-24-2014 01:37 PM
Cyclone powered exotic? fordfan100 General Car Discussion 8 04-28-2013 07:12 PM
From cyclone to coyote! Uscgfs 2011-2014 Mustang GT 14 06-20-2012 02:01 PM
05:32 AM
