Driveshaft issue?? - Mustang Evolution
Old 02-11-2015, 04:30 PM   #1
Driveshaft issue??
Has anyone had a vibration after installing a DSS driveshaft on their car?? I went from 0 vibrations to one that is apparent at 65 definitely gets worse as I speed up. I've tried rotating the shaft 90* and am just curious if you guys have any other advice.. I can call the guys at the dss but I sure hope my freaking $700 driveshaft isn't messed up already. Oh and I've torqued everything and double checked the measurement on the yoke.
2014 V6 6 speed, air raid intake, bbk throttle body, 91 octane nitrous tune, borla long tubes, custom h pipe, borla s-type mufflers, 3.55 gears, nitrous outlet wet plate w/ 100 shot , line lock, drag shocks, bmr lower control arms
John316hi is offline   Reply With Quote
Old 02-11-2015, 04:35 PM   #2
Kevin.Cook
Guest
Posts: n/a
What exactly is vibrating? Steering wheel, shifter, etc?
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Old 02-11-2015, 05:52 PM   #3
gqsmash's Avatar
Don't know how many positions are available but try turning it again...if that's all you did and know it vibrates it's the placement or just horribly balanced
gqsmash is offline   Reply With Quote
Old 02-11-2015, 06:16 PM   #4
You can rotate it two or three times before ruling out the driveshaft. If it's a manual the dual mass flywheel transmits some noise/vibration.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 02-11-2015, 06:19 PM   #5
Kevin.Cook
Guest
Posts: n/a
If the steering wheel is shuddering, then its something with the wheels usually. If its standard and the shifter is vibrating, then its the flywheel or driveshaft more times then not.
Old 02-11-2015, 06:25 PM   #6
I feel the vibration in the shifter at first then as it gets worse it move to my feet then finally my steering wheel/ mirror starts bouncing. Started when I installed the driveshaft along with the Barton short throw and bracket. I'll try rotating it again. Not exactly my favorite thing to do without a lift handy. Lol thanks for the help tho guys!
Old 02-11-2015, 07:14 PM   #7
Voltwings's Avatar
Are you lowered? Its likely the pinion angle that is off if you are. An adjustable UCA / bracket is the remedy for this. The stock 2 piece allows the pinion angle to be off some, a one piece is not as forgiving.
Old 02-11-2015, 07:20 PM   #8
I'm not lowered or any suspension mods yet.. I was going to put on some LCAs and some dark star wheels but I'd like to figure this out first. I can check the pinion angle but if it takes a few days to figure this out I'll just have the driveshaft shop guys swap me out for a new one ($500 deposit and they will mail me a new one instead of me pulling and sending this one off)
Old 02-11-2015, 07:30 PM   #9
Voltwings's Avatar
Hmmm, there goes my theory. Go ahead and measure the pinion angle for us though if you can.
Old 02-12-2015, 04:41 PM   #10
Well i would say it's my driveshaft.. Lol pulled it back out today and re installed my stock one.. All vibrations are gone now.. If only the stock one wasn't a POS I wouldn't have to do this again whenever I work out something with the DSS guys.. :-/ oh well maybe it got hit during shipping..
Old 02-12-2015, 05:44 PM   #11
gqsmash's Avatar
Did you not try to rotate it again?
Old 02-12-2015, 06:36 PM   #12
iguanaman3's Avatar
It is probably out of balance. I have read of similar accounts and the owner brought the shaft to be balanced and was reimbursed. I know they are supposed to be balanced from the factory but they apparently screw up sometimes. You need to contact DSS I'm sure they will take care of you.
iguanaman3 is offline   Reply With Quote
Old 02-14-2015, 01:42 PM   #13
Ya I've sent it back to the dss guys.. They say they will do some tests and figure out what's wrong and fix it.. Or build a new one if need be. Sucks to have to wait but at least it will be right.
Old 02-14-2015, 08:22 PM   #14
It should be SMOOOOTH and no clunking at all
I just installed the Axle Exchange aluminum drive shaft in my 2012 3.7 V6 and it is smooth and all the clunking I had with the stock two piece is 100% gone.
The one from the Drive shaft shop should be smooth and all the clunking should be gone.
You may have got one that got out without being balanced properly. I know it is a bummer but stuff happens once in a while.
Old 02-15-2015, 07:46 AM   #15
David Young's Avatar
A few years ago when aftermarket aluminum driveshafts were 'first' being made by a few different companies for our V6's (2011-2014), wasn't 'dss' the one that had several recalls and design changes when they first started selling them? And stopped making driveshafts for our V6's for several months?
This is why i went with the one sold by American Muscle made by Axle Exchange. Just saying......
David Young is offline   Reply With Quote
Old 02-24-2015, 06:54 PM   #16
Well... Let's try this again... Got the driveshaft back today... New weights on there and stuff. Hopefully this is the last time for a while, at least until I upgrade my flywheel and clutch :-/
Old 02-24-2015, 07:30 PM   #17
FastFord13's Avatar
Keep us updated.
2013 Candy Apple Red 3.7, Roush Axel Backs, Airaid CAI, BBK shorty headers,Barton shifter bracket, Bama tuned, SR lowering Springs, J&M adjustable pan hard bar, 3.73 Ford Racing gears, GT 500 spoiler, Upper and lower MIMD grill, 2010 GT Premium 19" wheels, GT 500 stripes, Painted mirror covers, MMD Billitt fuel door. 2014 Premium cluster, Chrome mustang shifter knob,
Old 02-24-2015, 08:21 PM   #18
Well I gotta say it's easier with two people... And if I wasn't on my tiny *** garage floor. But two hours later it's in.. I'd rather wait till tomorrow to drive it.. There's nothing wrong with a car if you "fix" it and don't test it right?!?
Old 02-25-2015, 10:07 AM   #19
Well... Cruising at 65-70mph is fine.. And it is nice and smooth at 120... Guess I can actually try to squeeze in to a dyno tomorrow... Depending on how busy the guy is after my buddy's trans am..
WIN A 2015 Driveshaft Shop Driveshaft & Half-Shafts at AmericanMuscle! AMAlexLazarus 2015 Mustang GT 13 02-22-2015 02:54 PM
Drove at 124mph... road noise? Or Differential / driveshaft issue? dubaighost 2011-2014 V6 Mustang 11 09-20-2014 12:07 PM
Upgrade Your Weak Stock Driveshaft with The Driveshaft Shop at AmericanMuscle AMWill AmericanMuscle 1 03-16-2014 02:18 PM
Driveshaft Issue? kornflake7 2011-2014 Mustang GT 12 06-08-2013 08:30 PM
Benefits of an aluminum driveshaft... i need some help Zim Pre-2005 V6 Mustang 26 04-05-2004 08:49 AM
02:51 AM
