Airaid Intake Tube - Mustang Evolution
Old 02-11-2015, 06:04 PM   #1
Airaid Intake Tube
Has anyone just replaced their stock intake tube with the Airaid? Does it have any affect on the sound heard in the cabin? I have a sound tube from a V8 and wonder if this would add better sound? Really just looking to improve sound. Should I wait and do full CAI?
tucsondivots is offline   Reply With Quote
Old 02-11-2015, 06:18 PM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
You've got a factory CAI, so you won't see much in the way of gains from an aftermarket intake. The airaid tube should give you a better sound as it deletes the silencer that's attached to the factory intake tube. You may also be able to mod it to use the GT sound tube, but it may not be needed.
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 02-11-2015, 06:54 PM   #3
Thanks. Already have the modded GT sound tube (from VIG). Hoping adding the air intake tube will produce a little more sound.
Old 02-11-2015, 09:34 PM   #4
rob.james.arias
Guest
Posts: n/a
I have done this and also added a drop in AFE air filter. The sound increase is negligible. That said I am very happy with the way it cleans up the look under the hood. Theoretically from a performance standpoint it reduces wind turbulence creating a more efficient flow of air into the throttle body.
Not sure if the filter or the combination of filter and airaid tube was the reason however there is a better throttle response since the install.
Old 02-11-2015, 10:55 PM   #5
WordySanchez's Avatar
Very little sound difference. Some, but very little. That said I have one for a V6 for sale if you want it
WordySanchez is offline   Reply With Quote
Old 02-12-2015, 04:41 AM   #6
Strange Mud's Avatar
I installed an Airaid (scored used) and am real happy with the sound. As mentioned it's not huge but one of those small quality improvement. Remember it's for sound alone and a used one is a good buy. It adds growl throughout the rpm range and sometimes you even get a bit of whistle around 2k under acceleration
go for it!
Airaid intake tube Noodles76 2011-2014 Mustang GT 12 09-26-2014 05:32 PM
Steeda intake Vs stock air box with airaid tube knight5.0 2011-2014 Mustang GT 13 08-20-2014 11:19 AM
Airaid Intake Tube SRE TUS 2011-2014 V6 Mustang 27 07-23-2014 08:07 PM
Airaid modular tube krazyrail 2011-2014 Mustang GT 1 06-14-2014 06:23 AM
Frpp intake vs airaid intake Zaks06GT 2005-2010 Mustang GT 5 10-30-2012 02:12 AM
04:00 AM
