Cat deletes - Mustang Evolution
Old 02-11-2015, 10:54 PM   #1
roushMarlon831's Avatar
Send a message via Yahoo to roushMarlon831
Cat deletes
Will these fit the cyclone even if it says it's for gt? Click image for larger version
Name:	ImageUploadedByMustang Evolution1423720429.293166.jpg
roushMarlon831 is offline   Reply With Quote
Old 02-12-2015, 12:21 AM   #2
Harm_3.7's Avatar
I believe the GT has bigger piping but I think your local muffler shop may be able to fit it for you! I might be wrong but I would definitely ask around before pulling the trigger on those.
Harm_3.7 is offline   Reply With Quote
Old 02-12-2015, 12:25 AM   #3
That's what I thought as well. That my local muffler shop can make it fit. But yea I'll have to go and ask personally
Old 02-12-2015, 12:36 AM   #4
Harm_3.7's Avatar
Have you ever thought about a off road H pipe maybe?
Old 02-12-2015, 12:36 AM   #5
I was looking for sound and hp increase. Will the off road h pipe do that for me?
Old 02-12-2015, 12:41 AM   #6
WhiteCali5oh's Avatar
Region: West Virgina
Off road means it's wont have cats. So yes it's basically the same thing. Just a h and x have different sound and slightly different power gains I believe, correct me if I'm wrong on that last part though. Nothing noticeably different on the power though.
WhiteCali5oh is offline   Reply With Quote
Old 02-12-2015, 12:42 AM   #7
Harm_3.7's Avatar
Well you will get a horsepower increase but not enough to feel it. It will be there you just won't be able to tell. The sound will be greatly increased because the off-road H pipe deletes the cats. Also I see your in Cali so you have to pass smog to so remember that!
Old 02-12-2015, 01:11 AM   #8
I guess I'm better off getting an H Pipe or X pipe then. I'm just looking for sound mostly
---------- Post added at 08:11 AM ---------- Previous post was at 08:10 AM ----------
Yea I'm in California. But I don't have to worry about smog for quite a while so ima go ahead and do it and later put the cats back on.
Old 02-12-2015, 01:21 AM   #9
Harm_3.7's Avatar
With the H pipe I believe you can just swap out for when you need to get a smog check
Old 02-12-2015, 01:22 AM   #10
U can swap either one. Offroad x or H. Thy both should be direct bolt ons just like the ones for the 5.0?
Old 02-12-2015, 01:28 AM   #11
Harm_3.7's Avatar
I believe so but I'm not really sure since I don't have one lol
Old 02-12-2015, 05:07 PM   #12
Senior Member
Otroo's Avatar
You could just gut the cats and leave the casing on to pass a visual.
Otroo is offline   Reply With Quote
Old 02-12-2015, 05:58 PM   #13
Will that cause any problems?
Old 02-12-2015, 06:17 PM   #14
No it won't I've done it. If you do it wear a mask, don't breathe that crap, it WILL make you sick...
Adventure till you drop
Old 02-12-2015, 06:47 PM   #15
What should I use? Like maybe a piece of rebar or just a solid pipe maybe?
Old 02-12-2015, 06:51 PM   #16
Cat deletes
We used a big crowbar and kept starting it, and rev to about 3 grand for maybe 5-15 secs, to clean out the converter.
Don't do it if you live in Cali....
Old 02-12-2015, 06:59 PM   #17
So leave them on the car just disconnect the mid pipe from behind the cats. And beat the crao out of it? I live in West Virginia lol so no worries. We just do visuals.
Old 02-12-2015, 07:03 PM   #18
We took a sawzawll and cut it at the bottom weld of the converter and used a crowbar to break up the stuff and started the engine to blow it out...
Old 02-12-2015, 07:14 PM   #19
Then I guess just weld it back up yourself?
Old 02-12-2015, 07:18 PM   #20
Cat deletes
Well I did this at the shop I work at so I have access to the necessary tools to do it. I'd suggest taking to a auto repair shop that has a car rack and so it, I guess a muffler shop.
And yes to your question.
Old 02-12-2015, 07:19 PM   #21
We have like every tool needed
For anything lol even a welder. Just no rack 😩
Old 02-12-2015, 07:26 PM   #22
I'd suggest jack it up and put some stands under it and something behind the rear tires so it doesn't move. Maybe do it that way, also it does take some time to do...
Cat deletes (tune required?) BillyBoB4869 2011-2014 Mustang GT 4 09-04-2014 11:55 AM
Cat deletes? 03gteddy 1996-2004 Mustang GT 18 10-27-2013 11:56 AM
To use cat deletes or not? Mustang32Bill 2011-2014 Mustang GT 31 11-06-2012 06:35 AM
Final thoughts on cat deletes. Venomouz831 1996-2004 Mustang GT 12 07-31-2012 06:01 AM
Cat Deletes clowery64 2011-2014 Mustang GT 2 07-26-2012 04:32 PM
07:55 PM
