Installed 5.0 tb - Mustang Evolution
Old 02-17-2015, 05:36 PM   #1
roushMarlon831's Avatar
Send a message via Yahoo to roushMarlon831
Installed 5.0 tb
One problem. The sensor that goes on the throttle body touches a hot part of the engine Click image for larger version
Name:	ImageUploadedByMustang Evolution1424219791.718614.jpg
ID:	175632 will it be ok?
roushMarlon831 is offline   Reply With Quote
Old 02-17-2015, 05:44 PM   #2
Kevin.Cook
Guest
Posts: n/a
Get some sort of heat shield and secure it between the two.
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Old 02-17-2015, 06:19 PM   #3
Voltwings's Avatar
Is it not perfectly square? Just rotate it? That sensor is very important and your car will get very temperamental (and may not run) if its damaged or skewed.
Old 02-17-2015, 07:02 PM   #4
I bought some rubber epoxy that is heat resistant to up to 500 degrees and I'll use it to separate the two
---------- Post added at 02:02 AM ---------- Previous post was at 02:01 AM ----------
Yea got some heat resistant epoxy
Old 02-17-2015, 07:03 PM   #5
Kevin.Cook
Guest
Posts: n/a
Just leave the throttle body off and use a hair net.
Old 03-03-2015, 09:35 AM   #6
13StangVizion's Avatar
[QUOTE=roushMarlon831;2175313]One problem. The sensor that goes on the throttle body touches a hot part of the engine Attachment 175632 will it be ok?
How's the epoxy holding up? I got ahold of one (TB) and looking to install as well. I am intrigued about Voltwings' suggestion to rotate it.
13StangVizion is offline   Reply With Quote
Old 03-03-2015, 10:37 AM   #7
[QUOTE=13StangVizion;2184258]
It's good dude. I've checked to see if the sensor is hot or the epoxy and their both good. The epoxy doesn't transfer heat so no problems
Old 03-04-2015, 01:19 PM   #8
JohnnyBob's Avatar
You have this on a 3.7? What kind of CAI do you have on it? Also is throttle response better?
JohnnyBob is offline   Reply With Quote
Old 03-04-2015, 02:57 PM   #9
I have the stock intake on. But I also have the adapter if I ever wanted an after market cai.. And yea ull notice th difference right away!!
Old 03-05-2015, 09:52 PM   #10
2011fastford's Avatar
Region: New Mexico
Has anyone actually dyno'd there car after installing this? I think an 80mm tb is way to big for a NA V6.. and could possibly hurt performance.
2011 Mustang V6 auto/procharger p1sc kit with 3.70 pulley/circle d 3200 stall/4:10 gears/dss aluminum driveshaft/tial q bov/bbk long tubes with catted x pipe/dynomax ultra flo catback/bbk throttle body/accel super coils/cyclone ported upper and lower intake manifolds/brembo front brake kit
INSTAGRAM @2011fastford505
2011fastford is offline   Reply With Quote
Old 03-05-2015, 10:01 PM   #11
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Everyone who's done this mod says otherwise. They say the throttle response is much better over stock
2012 Kona Blue 3.7L V6:
Old 03-05-2015, 10:02 PM   #12
Yea someone did. Somewhere on the forums he even showed a dyno sheet.. It adds about or more performance than the 73mm by BBK and it's cheaper by far so I think it's a good investment. I can surely feel the difference on my car.
Old 03-05-2015, 11:52 PM   #13
Region: New Mexico
well yeah, but with no data to back it, it's irrelevent.. if i had "modded" my car i would like to think the mod added some performance.
is it posted in a thread somewhere
Old 03-06-2015, 12:37 AM   #14
Yea somewhere just gotta search up 5.0 throttle body
Old 03-06-2015, 02:50 AM   #15
Marc3.71994's Avatar
Will the mustang 5.0 TB fit on a 2012 3.7?
Marc
Marc3.71994 is offline   Reply With Quote
Old 03-06-2015, 03:13 AM   #16
Marc
I'm sure it will. But it's not a straight bolt on thing. You have to customize it in order for it to fit.
Old 03-06-2015, 01:48 PM   #17
How so?
Marc
Old 03-06-2015, 02:36 PM   #18
You have to get the holes with the bolts re drilled in order to align to your manifold and then you have to cut the fins inside your manifold to have clearance for wide open throttle.
Old 03-06-2015, 02:37 PM   #19
Name:	ImageUploadedByMustang Evolution1425677807.244396.jpg
A view of what I'm talking about
Old 03-06-2015, 03:08 PM   #20
GrabberBlue1993's Avatar
Its too big for a NA car, people actually lost power switching to the 80mm GT throttle body from stock.
Sent from my 831C using Mustang Evolution mobile app
"At least it isn't a Honda"
GrabberBlue1993 is offline   Reply With Quote
Old 03-06-2015, 03:17 PM   #21
I have to disagree. I actually feel a difference.
Old 03-06-2015, 03:17 PM   #22
Kevin.Cook
Guest
Posts: n/a
It probably shifts the powerband a little.
Old 03-06-2015, 03:18 PM   #23
For the price of a bbk 73 mm I rather get a cheaper and bigger 80mm 5.0 tb which I did.
Old 03-06-2015, 03:21 PM   #24
Go do a dyno run of it and it will show you losing power compared to the stock or the 73mm.
It's all the placebo effect, you're not gonna feel a difference
Old 03-06-2015, 03:21 PM   #25
A guy is selling me a throttle body from a 5.0 for $25 shipped
efrain is offline   Reply With Quote
Old 03-06-2015, 03:21 PM   #26
There's a reason bbk went with 73 and not 80. 80 is too big for NA set ups.
Old 03-06-2015, 03:25 PM   #27
Go for it dude
Old 03-06-2015, 03:28 PM   #28
Kevin.Cook
Guest
Posts: n/a
I already mentioned this once, just remove the throttle body and intake and your engine will get all the air it needs. And for free!
Old 03-06-2015, 03:29 PM   #29
I saw proof before I ever got mine, that someone posted a pic of a dyno he had done and it increased hp by 5 compared to the stock. So idk how it would be losing power. Everyone should just go for whatever they think is best. Anything rather than stock is better
Old 03-06-2015, 03:32 PM   #30
That's not true at all. A lot of things are not better than stock. I would rather have my stock airbox than a cheap eBay intake. I would rather have stock springs then cheap-o springs or coils. I could name a million things.
Can you post the dyno pic? I'm curious to see it.
Old 03-06-2015, 03:52 PM   #31
Kevin.Cook
Guest
Posts: n/a
I think as long as the engine is tuned to properly utilize the airflow, there shouldnt be any problems. But with that being said, I would only do that if you also had a better exhaust setup then stock to help get the air out.
Old 03-06-2015, 03:56 PM   #32
Unless I'm mistaken he's not tuned for the 80mm tb, so it's not doing anything, his car thinks 67mm is going in.
Only gains you are gonna see on a NA build is in combo with ported intake manifolds, cai like a steeda, headers, etc
Old 03-06-2015, 03:59 PM   #33
If you look for the 5.0 TB Threads you'll find the pic. Like I said I felt a difference but everyone will always have there likes and dislikes about something. And who said you would end up getting cheap parts to replace stock! I rather have roush lower springs than the cheap stock ones. I rather have a bbk cai then the air restrictive airbox..everyone has a choice
Old 03-06-2015, 04:45 PM   #34
I'm not gonna search through countless pages of threads to back up your claims haha, its not that big of a deal.
You're not tuned for it, your car still thinks it's 67mm, its literally doing nothing positive for your car. If you really wanna find out, dyno it yourself, relying on butt dynos does not work. Facts are facts, I cant debate it if you have no basis for your claims and don't plan on ever dynoing it. Again, no hard feelings at all, its a discussion, but it's not helpin ya.
Old 03-06-2015, 05:19 PM   #35
Kevin.Cook
Guest
Posts: n/a
Without a tune, you would feel an increase in the acceleration due to soo much air rushing in. Other then that, it probably just moved your powerband more to the low to mid range but no "actual gains". A tune will fix that for you. But you will have to datalog it cuz most companies wont have a config for it on a v6 right off the bat.
---------- Post added at 06:19 PM ---------- Previous post was at 06:18 PM ----------
Either way, congrats on another mod.
how can i tell the difference between factory installed a/c & a dealer installed? Anthony90GT General Mustang Discussion 0 12-01-2012 09:42 PM
Well the RPM heads and cam are installed!!!! Danger Dude Pre-2005 V6 Mustang 4 10-14-2008 06:53 AM
Dual Exhaust side exit installed w/ **pics Mustang96 Pre-2005 V6 Mustang 13 07-16-2003 05:59 PM
Mac Longtubes, H-Pipe (no cats), and Magnapacks Installed MusclesFromBrussels Pre-2005 V6 Mustang 0 06-27-2003 08:11 AM
installed my 232 badges pics** Mustang96 Mustang Audio & Video 2 05-12-2003 01:46 PM
08:56 AM
