HELP! Shock or LCA issue. Rough ride - Mustang Evolution
Old 02-18-2015, 10:15 PM   #1
I have a 2012 v6. Not lowered. No suspension upgrades other than the following: Koni srt t shocks and lca's. One of my rear shocks was leaking, so i figured hell I am going to get those orange Koni Srt.t shocks as replacements for the rear and while at it put on my BMR lca's I had sitting in the garage. Now don't give me crap for not replacing the front shocks too, I was going to if I liked this setup. With this said, I love the way it launches and handles now but it is so rough in the rear. I mean tiny bumps I never even felt (when stock), feel like someone is punching the *** end. It is okay as a daily driver but I would really like to get some of the harshness out of it. What do you think is causing the rough ride?! The shocks are about a month old now and are the street version, they are suppose to be entry level in stiffness terms. I was thinking it is the shocks more than the lca's. I might just get all four new stock shocks and keep the lca on? What do you guys think? I have every bolt on mod done, I wanted to get some dive and body roll out but I hate how it rides now. Any suggestions? I drive the car somewhat spirited and I enjoy it! It is fun and I think with gears and some mods this car is wonderful for the weekend enthusiast
GrbbrBlue is offline   Reply With Quote
Old 02-18-2015, 10:27 PM   #2
NewMtang's Avatar
If you want a firmer suspension, then you won't have a smooth ride. If you want a smooth ride, ditch the lowering springs, LCA and replace with factory parts.
Don't drive on any rough roads anymore.
Old 02-18-2015, 10:43 PM   #3
Kevin.Cook
Guest
Posts: n/a
Sometimes having a tire with a bigger side wall will help. Going on 19s or so will make it worse.
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Old 02-18-2015, 10:51 PM   #4
[QUOTE=Kevin.Cook;2176147]Sometimes having a tire with a bigger side wall will help. Going on 19s or so will make it worse.
I have the pony package wheels 18x8 235/55/18 I believe.
and I am NOT lowered. Do you think my shocks are more the culprit for the rough ride than my lca's?
Old 02-18-2015, 10:52 PM   #5
Kevin.Cook
Guest
Posts: n/a
Do you still have the stock LCAs? If so, i would try swapping them out to narrow it down.
Old 02-19-2015, 08:55 AM   #6
I do have the stock lca's.
Old 02-19-2015, 09:09 AM   #7
Kevin.Cook
Guest
Posts: n/a
Swap them out and that will tell you which one is making you a "Ruff Rida" XD
Old 02-19-2015, 09:17 AM   #8
RaceRed3.7's Avatar
I got the BMR LCA's. They were easy to install took me and a friend 30 mins. Make sure you torque to 130. Then grease the bushings. After installing them the rear felt way more stable and its less bumpy to me. Better launch, its like all the weight goes to the rear tires. Also dont forget to take off the rear tires if you install these. all the weight will pull the suspension to the rear when you loosen the lca's when it breaks loose it kicks back. lol
-SOLD-13.246s@107.81 RaceRed 2013 v6 Mustang, 3.73 gears, MPT 91Race Tune, Axle-Back Straight Pipe, Tower Brace, BMR LCA's, BBK Shorty Headers, BMR Relocation Brackets, Lethal Performance X-Pipe Catless.
-2008 Civic SI...
RaceRed3.7 is offline   Reply With Quote
Old 02-19-2015, 05:59 PM   #9
Commercial Member
au01st's Avatar
Didn't know this. All the install videos I've seen left the tires on and just say to support the car by the axle.
Gonna do my BMRs next day I'm off work.
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 02-19-2015, 06:14 PM   #10
tym_v6's Avatar
^ Yeah, I'm surprised by this too. I did my BMRs with my car driven onto ramps and the suspension fully loaded. I had no trouble swapping out the LCAs.
Maybe it's for when the car is in the air?
rough ride billygodfree 2005-2010 Mustang GT 14 01-30-2014 01:26 AM
Rough ride on 19's? Missxalii Mustang Wheels & Tires 12 12-02-2012 09:13 PM
Lca/shock pointers AgentOrange 1996-2004 Mustang GT 0 02-14-2012 09:41 PM
Vibration/ Rough ride on 06 V6 99ford Pre-2005 V6 Mustang 3 07-18-2009 03:20 PM
Rough Idle and Rough Start Cajun JungleBoy Pre-2005 V6 Mustang 3 04-23-2006 11:33 PM
02:35 PM
