Tune required? - Mustang Evolution
Old 02-21-2015, 01:04 PM   #1
Tune required?
Hey guys I'm new to the mustang world as i just recently bought one a couple months ago. I've been researching about some different setups and I feel good about getting some BBK shorty headers from Americanmuscle but I can't figure out if I will have to tune my car afterwards. Can anyone tell me if a tune is required after I install the shorty headers with an aftermarket axle back exhaust? Thanks in advance!
Tek1836 is offline   Reply With Quote
Old 02-21-2015, 01:10 PM   #2
FastFord13's Avatar
No tune required.
Sent from my Nexus 5 using Mustang Evolution mobile app
Old 02-21-2015, 01:16 PM   #3
Ok Thanks!
Old 02-21-2015, 01:19 PM   #4
FastFord13's Avatar
Np
Old 02-21-2015, 02:31 PM   #5
Black8thElement's Avatar
You would gain more from a tune though
Sent from my LG-E980 using Mustang Evolution mobile app
Black8thElement is offline   Reply With Quote
Old 02-21-2015, 03:12 PM   #6
I would gain more by tuning than just bolting it on?
Old 02-21-2015, 03:23 PM   #7
FastFord13's Avatar
The tune will complement the mods.
Old 02-21-2015, 03:26 PM   #8
Its like if
you bolt that on the cpu thinks nothin has changed. The tuner tells the car "hey you have more power than you know" and your able to unlock it
Old 02-21-2015, 03:35 PM   #9
2 Stangz's Avatar
Region: Nevada
As you're new in the aftermarket world I'll leave you with two tips, I will not be offended what so ever if you decide against them.
There are MUCH better products than BBK out there. Don't be fooled by their prices or marketing schemes.
Don't expect much out replacing stock manifolds with shorty headers. I'd actually say you could expect A LOT more out of a custom tune than shorty headers.
Old 02-21-2015, 03:52 PM   #10
To add to that, I wouldn't recommend any other TB than Ford Racing. Less possible Drivability issues.
Old 02-21-2015, 07:59 PM   #11
Thanks guys. I'll take I'll the help I can get cause I am new to this stuff.
Old 02-21-2015, 08:10 PM   #12
So what headers would you recommend if I go tune + headers.
Old 02-21-2015, 08:13 PM   #13
Kevin.Cook
Guest
Posts: n/a
I myself, wish i could get borla headers. But i cant find any place that sells just the headers.
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Old 02-21-2015, 08:27 PM   #14
For those of you telling Tek1836 to get a tune, can you provide the details needed to later on get warranty work performed if something breaks. Keep in mind that Tek1836 has a new Mustang with a warranty.
SeaSalt is offline   Reply With Quote
Old 02-21-2015, 08:53 PM   #15
Most people with a tune have a Mustang with a warranty.
Old 02-21-2015, 09:24 PM   #16
So what's wrong with the bbk headers? Are they just cheaply made?
Old 02-21-2015, 09:30 PM   #17
Kevin.Cook
Guest
Posts: n/a
I personally dont think anything is wrong with bbk. If i cant find borla headers, i will get the bbk ceramic shorty headers from AM.
Old 02-21-2015, 09:33 PM   #18
Ok. So is the ceramic headers a better quality than the chrome headers?
Old 02-21-2015, 09:43 PM   #19
Kevin.Cook
Guest
Posts: n/a
I believe so because the ceramic ones disipate the heat better.
Old 02-21-2015, 09:44 PM   #20
Kevin.Cook
Guest
Posts: n/a
That and chrome is kinda tacky imo. I'd only get chrome if i was planning on adding 22" spinners also. XD
Old 02-21-2015, 09:48 PM   #21
Kevin.Cook
Guest
Posts: n/a
I would just like to keep my exhaust the same brand and not frankenstein it. But if it cant be helped, then oh well.
Old 02-21-2015, 10:15 PM   #22
509pony's Avatar
I like the bbk ceramic lt headers they look good and sound good you'll definitely need a tune for these
Sent from my SGH-T999L using Mustang Evolution mobile app
509pony is offline   Reply With Quote
Old 02-21-2015, 10:27 PM   #23
FastFord13's Avatar
There is no tune required for shorty headers. You can run the stock tune.
Old 02-21-2015, 10:34 PM   #24
FastFord13's Avatar
Chrome plated headers will eventually turn to a more blue ish color due to the heat over time. Ceramic will stay that shiny chrome ish color over time and will help with heat reduction. I have the chrome ones but I should have opted for the ceramic ones as they get awfully hot! If your going to do headers don't make the mistake I did.....go with ceramic.
Old 02-22-2015, 05:04 PM   #25
2 Stangz's Avatar
Region: Nevada
I never said anything was wrong with BBK's headers, I just said there are much better brands out there with better-designed products.
I recommend long tube headers if you're going to do aftermarket headers. I've been told the install is the worst part and aren't worth the gains with shorty headers (if you're after performance gains).
Old 02-22-2015, 05:48 PM   #26
So what's the deal with the heat? Does that hurt the exhaust flow? Sorry for so many questions, like I said I'm new to this stuff.
Old 02-22-2015, 06:06 PM   #27
509pony's Avatar
I believe that ceramic headers will help help keep the temperature down in your engine compartment allowing your intake to suck up colder air as for chrome headers they will heat up and temp will go up giving you less colder and a slightly less performance gain especially cars with turbos and bigger mods.
Old 02-22-2015, 06:16 PM   #28
Coyote2820's Avatar
Yeah man, regardless what brand you go with just make sure you go ceramic if you're getting coated but ideally stainless steel. If you plan to drop the cash to change out the headers then you should really consider just going long tune or mid-length so you see some benefit for your buck.
They will require a matching mid pipe (which will be beneficial to the flow, the power and the sound) and a tune will also be required to modify your cpu to account for your adjustments so you can take advantage of the upgrades and not leave anything on the table, this will also assure you don't have issues with Check Engine Light alerts.
As for tuning goes, previously someone mentioned something about warranty work and tunes rhetorically spiteful rather than informatively helpful so here is what they were talking about... If you use an aftermarket tune, that will void your warranty immediately so if you take it in for warranty work and they recognize it they you are pretty much screwed. If you buyer a tuner then you do have the option of returning to the stock tune prior to any Ford servicing(which is what I do and they have never been able tell) but they do have the capability of reviewing cpu flash history to determine if it has been tuned but that just depends on who the individual at Ford inspecting it and their personal knowledge on that and their determination to find a reason to void your warranty.
You can get more conservative tunes or racing tunes; regardless of what you do you will have a very noticeable increase in your vehicles pep. When I tuned mine I couldn't understand the hype because I thought it was a beast just stock. Then I did it and I now understand the hype. I will say though, not all tunes are created equal. I use Steeda because it's reliable and very effective, free tunes for life and they have had 0 engine failures with their tunes (BAMA 5+ EF) and the guys there at Steeda are quick, efficient and awesome to work with.
End of my very extensive rant..
2014 5.0 GT Premium - Active Duty
2013 5.0 GT - Retired
2003 GT - Retired
Coyote2820 is offline   Reply With Quote
Old 02-22-2015, 06:20 PM   #29
FastFord13's Avatar
I wasn't aware of any proven bama tuned 3.7 failures. Can you post some facts?
Old 02-22-2015, 06:48 PM   #30
2 Stangz's Avatar
Region: Nevada
509 and Coyote left some good feedback.
In short:
1) Heat = bad. Cold air in more dense > engine likes cold air... Ceramic = colder. Natural (stainless steal) is good too.
2) Tuning + warranty is a very controversial subject. Some dealerships endorse it, others (most) don't. However, there are laws protecting you. Just be smart (choose a good tuner).
I also recommend Steeda for entry level tunes. Safe and reliable with a solid reputation.
Old 02-23-2015, 12:22 AM   #31
Coyote2820's Avatar
I'll see what I can find for proof tomorrow because I'm not positive of the 3.7 stats for BAMA but to me it wouldn't matter if it was the motor on a go-kart if their product made it fail I wouldn't void my warranty with it.
2003 GT - Retired
Old 02-23-2015, 10:17 AM   #32
Alright good to know. Thanks guys!
Old 05-10-2015, 10:52 AM   #33
Hampton CIT's Avatar
Any update on this mod Tek? Looking at Shorty Headers here too.
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
Cat deletes (tune required?) BillyBoB4869 2011-2014 Mustang GT 4 09-04-2014 11:55 AM
Is an updated tune required? thatoneguy General Mustang Discussion 7 01-19-2014 09:12 PM
Wanted: CAI no tune required lllTRADEMARKlll Mustang Parts for Sale and Wanted 56 08-07-2013 10:44 PM
05 v6 CAI tune required? AgentOrange 2005-2010 V6 Mustang 16 01-16-2013 08:32 AM
11:10 AM
