TPMS sensor and fix a flat - Mustang Evolution
Old 02-22-2015, 08:23 AM   #1
Kevin.Cook
Guest
Posts: n/a
So I am getting a tire replaced due to an unfortunate nail. NTB mentioned if you spray fix a flat in these newer car tires, that fix a flat has a high chance of ruining the TPMS sensors. The guy said fix a flat is highly acidic and we should not be doing this.
Anyone else heard of this?
Old 02-22-2015, 08:43 AM   #2
Do not use "FIX-A-FLAT
It will ruin your tire pressure sensors and it-self glues the inside of the tire and very hard to get off.
Go to Auto Zone or a car parts store and get """SLIME""" it is water based, Won't ruin the sensors and just washes out so the tire is easy to patch.
It does come in an aerosol can as well as the old squeeze it in stuff. ( Needs a pump)
I carry both types. ( bought it when I had my Mini JCW)
This is a picture of the fix-a-flat after it was pried off of the inside of my tire. Not an easy thing to do.
Old 02-22-2015, 08:45 AM   #3
GrabberMeBlue's Avatar
This comes right from their site:
http://www.fixaflat.com/faq/
2012 Grabber Blue Mustang Convertible V6 Premium
1979 Solar Gold Trans Am
1995 Bright Red Trans Am Convertible
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 02-22-2015, 08:49 AM   #4
Kevin.Cook
Guest
Posts: n/a
Yea it says on their website it can be cleaned out of the sensor and it should return to normal function. But i was curious if it REALLY ruins the sensors beyond repair. Idk, maybe the rep was making it up.
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Old 02-22-2015, 09:01 AM   #5
It must have been change since I used it
I used it back in the year 2001 or 2002 When I had a flat. It ruined my $100.00 sensor (BMW MINI) and the tire shop would not repair the tire because the glob of crap turned to a plastic type stuff that glued itself to the inside of my tire. I bought my Michelin's then and took the old tires home. I Finley peeled off the scab ( Pictured in above photo) and took the tire to be plugged . I did sell all four on Craigs list.
They must have had to change the stuff because all new cars now seem to have tire sensors. I will stick to "SLIME" products though because I know they don't destroy anything and just washes off with plain water. And it does get you going if you do get a flat.
Old 02-22-2015, 09:38 AM   #6
TedG's Avatar
Fix-a-Flat cost me a new sensor, but it was better than being stuck.
I'm going to get the Slime. Thanks for the tip.
Become an Organ Donor today: http://donatelife.net/register-now/
Save as many as 50 lives. Thanks.
TedG is offline   Reply With Quote
Old 02-22-2015, 02:00 PM   #7
Commercial Member
au01st's Avatar
Thanks for the info. Going to throw a bottle of Slime in my emergency bag in the trunk!
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 02-22-2015, 04:59 PM   #8
Diehard's Avatar
Of course as many of you know a spare tire is not an option nor did my dealer know what I could use as a spare, for my car equipped with the Perf Pack option.
They give you a TEMPORARY MOBILITY KIT which includes a "sealant" then they tell you in the Owner's Manual...
"WARNING: The use of tire sealants may damage your tire
pressure monitoring system and should not be used. However, if
you must use a sealant, have an authorized dealer install a new tire
pressure monitoring system sensor and valve stem."
I did finally find the 18" alum wheel mini spare that would work with the larger brake calipers on the Perf Pack. ( I think it was used on some of the GT's.??)
I don't like the idea of relying on a sealant, which is only good for specific types of flats, and then possibly having to replace the PMSS.
Old 02-22-2015, 05:12 PM   #9
tym_v6's Avatar
I wound up buying Ford's spare tire kit with doughnut... never did test to see if it will clear the PP front calipers, but my research said it would.
Good to hear about Slime. Didn't know it was TPMS-safe; will have to buy some for the emergency kit.
Old 02-23-2015, 04:30 AM   #10
Strange Mud's Avatar
I talked with someone that works at a tire shop and they hate Slime. Evidently yes, you can clean it out but it ain't as simple as the cans say. I carry a plug kit at all times and when I go on trips of more than 50 miles from the house I throw an extra tire in the back (I'm lucky enough to have both summers & Neros)
Old 02-23-2015, 04:42 AM   #11
bucko's Avatar
Back in 2012, I had a slow leak, and used the Factory supplied bottle of tire fix that was in the trunk, along with the compressor to fill the tire. That afternoon, I took the Mustang over to a Ford dealer to have the tire properly repaired. The service manager informed me that the TPMS would need replacement. I told him to go ahead of course, but at their dime, not mine, as I followed the directions in my 2011 owners manual. Seeing as how Ford provided the tire repair bottle, I told the service manager that Ford would have to cover the cost of the TPMS if their supplied product ruined it.
The service manager agreed. Not sure if they replaced it or not, but it never gave me any codes or indications of failing (TPMS).
Old 02-23-2015, 06:26 AM   #12
Waylap1's Avatar
Region: New Hampshire
Dear Jeebus! Don't use slime or fix a flat! You want to talk about ruining your own wheels, sensors and genuinely pi$$ing of the technician you bring it to?
Buy a spare tire and change it like a man. What's this you say?.... It won't fit on your front? Then put it on the rear and put your GOOD rear tire on the front! But that takes an extra 5 minutes? Don't be a Mary, cowboy up.
Waylap1 is offline   Reply With Quote
Old 02-23-2015, 06:38 AM   #13
Yes, A spare is the very best
A plug kit is good too.
AAA is great but only if you have a spare.
Slime will get you going fast and out of harms way of jacking up your car on the side of some roads and interstates the way people drive now-a-days.
We used Slime in Shari's truck. They just squirted it out with a hose, dried out the tire with the air hose, put in a plug patch and "DONE" My tire store is well aware of slime and it did not bother the old guy one bit.
Old 02-23-2015, 07:29 AM   #14
yellowconve's Avatar
i bought a actual oem rim and put a new pirrelli i got from a run down tire shop for 40 dollars and rim 220 delivered.the pirrelli is brand new cant believe people pay almost 300 for good tires.
0-100 REAL QUICK!!!
yellowconve is offline   Reply With Quote
Old 02-23-2015, 07:35 AM   #15
Im with you there! My couzin just got hit lastnight waiting for the tools to change his tire! The side of the road is worse than an actual street laneClick image for larger version
Name:	ImageUploadedByMustang Evolution1424702095.130464.jpg
efrain is offline   Reply With Quote
Old 02-23-2015, 07:40 AM   #16
tym_v6's Avatar
^Holy crap! He's okay?
Old 02-23-2015, 07:43 AM   #17
Commercial Member
au01st's Avatar
I'm willing to bet most people here know how to change their tire, but it's a time/cost thing. I get roadside service for <$3 a month on my insurance. If I get a flat, I'll let them deal with it. That's what I pay for. I've been on the side of an interstate changing a tire; not an experience I want to have again. Remember, it's not about us, it's the other idiots out there running around.
Old 02-23-2015, 07:44 AM   #18
Yes he is nothing major thanks for asking
Old 02-23-2015, 07:59 AM   #19
tym_v6's Avatar
Glad to hear it!
Old 02-23-2015, 08:01 AM   #20
that will be difficult to buff out.
I remember helping someone on the side of the Merrit Pkwy in CT and her being suspicious when I told her it was her job to keep an eye on traffic as I figured out what was wrong with her car. I will say if I can't pull well off the road I'll drive till the rim (or wimp out and call for help)
Old 02-23-2015, 08:14 AM   #21
Glad to hear it!
Yes. But sorry for getting in here with an infiniti lol
Old 02-23-2015, 08:17 AM   #22
Kevin.Cook
Guest
Posts: n/a
Im with you there! My couzin just got hit lastnight waiting for the tools to change his tire! The side of the road is worse than an actual street laneAttachment 176003
Glad noone was hurt. People bag on others for making choices like calling for road side service when they need to realize, we are doing this because of the stupid choices others make on the road.
Such as changing lanes when someone is right next to them.
Old 02-23-2015, 08:26 AM   #23
Another thing to think of:
People have been robbed when being broke down or changing a tire on the side of an interstate highway. All states have had this problem.
I'll just stick to the "SLIME" AEROSOL and be on my way in two minutes.
Many, and I mean MANY cars have been rear ended while parked on the side of a road because a lot of people see the car and their brain try's to follow what is in front of them. By the time they realize the car in front of the is stopped it is to late and Whamo.
They had to actually pass a law here in Florida to make people move to the left lane and slow down if they see a Police car on the side of the highway and they still get rear ended once in a while when stopping a speeder or helping someone. And they have flahing blue lights.
Day or Night - It is a dangerous thing to be jacking up a car and changing a tire on the side of any road or highway.
Old 02-23-2015, 08:41 AM   #24
Yes you're right even here in TX its that way but there is just some dumbasses here and every where
TPMS Sensor Tool OzzyLiriano 2011-2014 Mustang GT 2 11-05-2013 10:14 PM
Tpms sensor. The Puma 2011-2014 V6 Mustang 12 04-09-2013 02:39 PM
TPMS sensor ?? Roger07GT Mustang Wheels & Tires 8 08-29-2012 01:36 AM
2013 (another TPMS) flat tire question / thought / boo on the goo! Twinarrow99 2011-2014 Mustang GT 10 05-26-2012 12:30 PM
My flat hood ain't so flat... Just_John Pre-2005 V6 Mustang 6 02-21-2012 03:58 PM
03:20 AM
