P2195 and P2197 - Mustang Evolution
Old 02-22-2015, 11:46 AM   #1
VIG
VIG's Avatar
Region: Delaware
P2195 and P2197
So I was driving along today and suddenly my car started to idle rough. It felt and sounded like it was cammed.
I was running my Bama 93R at the time then switched back to the stock tune immediately to see if it was just a tune issue. It continued to idle rough on the stock tune too.
After a few miles the CEL came on. Pulled the codes and got P2195 and P2197. O2 sensor signal biased/stuck lean (bank 1, sensor 1) and O2 sensor signal biased/stuck lean (bank 2, sensor 1). In other words, the sensors on the headers. I have a completely stock exhaust aside from the axlebacks, which wouldn't cause this.
Weird...
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 02-22-2015, 03:50 PM   #2
Socal Stangman's Avatar
Now I don't know if this is true or not, I'm basing this on what I was told from my Ford service advisor.
He told me the problems with aftermarket tunes are things like this. They tend to make settings lean to get all the power it can....once again I'm not saying it's true , it's just what I was told.
Old 02-22-2015, 03:52 PM   #3
natestang07's Avatar
Weird...
Could be as simple as bad and gummed up sensors. Might want to pull them and take a look
Old 02-22-2015, 04:52 PM   #4
VIG
VIG's Avatar
Region: Delaware
Yeah, I was thinking that too, but in theory it should go back to normal when I put the stock tune back on.
Yeah, you're probably right. I'm going to email Bama and see what they say.
Old 02-23-2015, 08:14 AM   #5
Site Sponsor
Weird...
Hey VIG - Sorry about the scare here! It sounds like that this could definitely be in regards to the sensors as the code is typically in relation to them malfunctioning. Shoot the Bama Team a call and they're happy to troubleshoot this with you! They've tuned your setup many times over and I'm positive that this is something small that they'll be able to work through quickly. I just want to go on record here in regards to the leaning out comment and Bama absolutely does not do this! My Bullitt along with our shop GT were test beds for their new V2 Tunes and if you're not running them right now I highly recommend that you take a look into them! The only reason why my car isn't on camera below is because I'm camera shy! Plus Green just doesn't look great in our studio!
VIG Let me know how you make out and if you have any other questions!
Toll Free: 1-866-363-4591
Free Same-Day Shipping!
Old 02-23-2015, 10:01 PM   #6
VIG
VIG's Avatar
Region: Delaware
So Bama got back to me, promptly as usual.
The more I drove it the more it felt like a vacuum leak, so during lunch, I went out to my car and disconnect and reconnected every vacuum hose I could find. Started the car back up and idles smooth and AFR is back to normal.
I don't know which hose it was, but it doesn't matter to me because it seems to be fixed now.
Engine Code P2197 Mustang_2005 2005-2010 V6 Mustang 15 11-21-2016 09:45 AM
p2195 p2197 mustanguitarist 2011-2014 V6 Mustang 6 04-24-2014 11:34 AM
Help!!! Dtc codes p0174 and p2197 Kochieey 2005-2010 Mustang GT 14 06-05-2012 07:03 AM
Check engine light-codes P2197,P2195 The Darkside Pre-2005 V6 Mustang 35 12-11-2008 10:12 AM
Fox Body '89 and 16" and 17" wheels and rims Kevin Brown Mustang Wheels & Tires 12 11-10-2005 05:56 PM
11:57 AM
