Dyno run - Mustang Evolution
Old 02-27-2015, 12:19 PM   #1
Dyno run
So I had my car up on a dyno this Thursday and the results were kind of funky.. Has anyone used nitrous on their cars or had an issue with power falling off at 4700rpm on up?? I'm trying to attach my sheets with this to explain it. Had to call Bama and start asking for a new tune because something definately off.
2014 V6 6 speed, air raid intake, bbk throttle body, 91 octane nitrous tune, borla long tubes, custom h pipe, borla s-type mufflers, 3.55 gears, nitrous outlet wet plate w/ 100 shot , line lock, drag shocks, bmr lower control arms
John316hi is offline   Reply With Quote
Old 02-27-2015, 12:25 PM   #2
This shows my n/a pull, my 50 , and 100 shot runs
Old 02-27-2015, 01:01 PM   #3
You are going to get a lot more torque than horsepower from a nitrous shot. You got 50 and 100 over your baseline numbers so the nitrous did its job. I think most people get about 380rwhp/440rwtq on a 100 shot.
2011 Mustang 3.7: 13.2 @ 105
BBK Shorty, MRT H, Borla S, 3.55 Gear, MPT Tuned.
LiveWire003 is offline   Reply With Quote
Old 02-27-2015, 01:23 PM   #4
I don't have an issue with the gains it's the 4500-6800 that I don't think are right.. Or at least the torque numbers. The dyno guy says something's not right so I'm working with Bama with some data logs to see what's going on. There was popping, running a little lean, and a dead pedal on one of the pulls. He thought maybe a torque management table or maf table could be off. I'm not exactly an expert at these things.
Old 02-27-2015, 01:43 PM   #5
Senior Member
Otroo's Avatar
What nitrous kit are you running?
Otroo is offline   Reply With Quote
Old 02-27-2015, 01:50 PM   #6
Nitrous outlet wet plate with a window switch. Pretty sure the window switch is nos. Had a full 15lb bottle at 900psi for each of the nitrous pulls. Wideband to watch he air fuel using. The jets recommended by nitrous outlet
Dyno Run Scut95 1979-1995 Mustang GT 8 03-18-2007 10:56 AM
Pics and video of my 2005 dyno run. I8URVTEC 2005-2010 Mustang GT 10 01-26-2007 08:36 AM
Dyno run goes bad! PonyTrader The Bar 15 07-25-2005 09:43 PM
A vid of my latest dyno run. Monkey The Bar 11 02-13-2005 10:38 PM
Help after dyno run 97Stallion Pre-2005 V6 Mustang 5 11-16-2003 10:18 AM
06:03 PM
