Intake manifold - Mustang Evolution
Old 03-01-2015, 10:31 PM   #1
Floridasixer's Avatar
Intake manifold
Hey guys. Weird question but can the raised lines on the intake manifold be grinded down and made smooth? It's purely for aesthetics but I think it might look cool. Anyone know if it's possible?
Floridasixer is offline   Reply With Quote
Old 03-02-2015, 01:11 AM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Can it be done, yes. I'm fairly certain they aren't just for aesthetics though. They're for structural support of the intake manifold.
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 03-02-2015, 05:03 AM   #3
You could probably fill in the raised lines with something and sand it smooth if thats the look you are going for - but I agree with above - I'm pretty sure those are for support.
superblur is offline   Reply With Quote
Old 03-02-2015, 05:58 AM   #4
bucko's Avatar
I might be concerned that by sanding the lines down, the intake tubes themselves may warp from engine heat. I don't know this for sure, but there's a reason they were cast in; I agree with the others that they aid in structural support/strength.
Some folks have ground down a small amount at the top of the runners to allow clearence of a GT strut bar (they got one used for cheap), as these V6 intake lines you talk about prevent the required clearance needed. I do not recall anyone stating that this caused an issue, but again, it was only a small patch that was ground down.
Old 03-02-2015, 09:01 PM   #5
What would you recommend to fill in the gaps?
Old 03-02-2015, 11:54 PM   #6
Bear376's Avatar
It may be best to find a way to make a cover for it. Filling it in may create problems, or eventually crack. A machinist that can work with thin plastics, might be able to form something. I have suggested something like this to American Muscle.
2013 MCA Edition-Sterling Grey
Roush body kit - Splitters/hood scoop
Whiteline suspension w/Koni shocks
Bear376 is offline   Reply With Quote
Old 03-03-2015, 03:22 AM   #7
bucko's Avatar
Don't use body filler!!! It will only crack over time. That space is too large and too deep for body filler.
Old 03-03-2015, 08:32 AM   #8
SouthernCyclone's Avatar
An epoxy that will adhere to cast nylon. A very expensive endeavor to fill all those squares correctly.
I did 4 squares on my custom ported intake manifolds. I removed the casting pillars out of the middle of the intake manifold. Then used aluminum sheeting and aluminum to cast nylon epoxy to adhere a new square in place. Then I used epoxy for cast nylon to fill those 4 squares in. You also had to do the epoxy in layers (about half a square) let it cure and finish the square. Then sand smooth.
SouthernCyclone is offline   Reply With Quote
Old 03-03-2015, 10:09 AM   #9
Strange Mud's Avatar
1st to suggest the engine cover from the perf pack!
Old 03-03-2015, 06:15 PM   #10
I have it installed but it still shows the intake manifold on the other side of it
Old 03-06-2015, 04:39 AM   #11
outside the box idea.....test 1st before doing the entire thing!
as mentioned B4 the ribs are structural and I would worry about epoxy cracking, but how about filling the voids with high temp RTV? I've used it on stove ductwork and it's normally a red color good to about 400 deg. I think filling most of the void would give almost a checkerboard pattern of black and red.
Old 03-06-2015, 05:31 PM   #12
I've had the epoxy on my ported intakes for 8 months now. That includes 100+ summer heat and 0-20 degree winter cold. I'm also full bolted on and put my car through it's paces time to time. Not 1 crack, you just have to prep and use the appropriate epoxy for the application.
^^^that same intake manifold will be on my turbo build that's getting ready to take off as soon as I receive the parts this next week.
Old 03-07-2015, 01:52 PM   #13
Can you post a pic of the manifold? I'd love to see what it looks like
Old 03-07-2015, 03:33 PM   #14
The whole manifold is hydro dipped now, all you would see is the 2 smooth squares hydro dipped that I filled on the top of the manifold. The two on the bottom of course you can't see at all.
Boss intake manifold and the stock intake Yellow50 2011-2014 Mustang GT 43 04-26-2012 06:30 AM
Intake Manifold vs Intake Man-child jbanks 1996-2004 Mustang GT 17 08-02-2011 04:55 AM
Ported Intake Manifold..STRESS 99'sleeper Pre-2005 V6 Mustang 5 03-10-2005 08:10 AM
95 Intake manifold. Calston31 Pre-2005 V6 Mustang 6 12-05-2004 05:42 AM
Intake manifold and cylinder head jwscorpio Pre-2005 V6 Mustang 4 02-27-2004 06:49 AM
09:47 PM
