Cigarette plug wont charge phone?? - Mustang Evolution
Old 03-03-2015, 10:10 AM   #1
Ive tried both cigarette plugs in my 2012 mustang, with different adapters and different charging cords. When i plug the adapters in they will light up, but they dont charge the phone. Tried checking if maybe the fuse was blown but there is no labeled fuse for the cigarette plug.
Anyone else have this problem?
theblackdahlia is offline   Reply With Quote
Old 03-03-2015, 10:14 AM   #2
Strange Mud's Avatar
normally this issue is the adapter doesn't have a high enough output.
Old 05-24-2015, 10:14 PM   #3
king_13's Avatar
Figured it wasn't worth making a new thread, what fuse goes to the cigarette lighter in the dashboard? It doesn't charge anything, so I figure it's the fuse.
Sent from my iPhone
2014 Oxford White 5.0 Premium
2015 Maroon Chevy Cruze LTZ
2011 Performance White V6 Premium SOLD
king_13 is offline   Reply With Quote
Old 05-24-2015, 10:51 PM   #4
Mean14's Avatar
Can you use the usb input in the center counsel?
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 05-24-2015, 11:00 PM   #5
king_13's Avatar
Yes, the USB and light work in the center console, just not on the dash. Do they share the same fuse?
Sent from my iPhone
Old 05-24-2015, 11:04 PM   #6
Midnight2012's Avatar
I use a 2.1 adapter for my Samsung Galaxy 3. 1.0 works but charges very slowly.
The accessory ports aren't for cigarette lighters btw.
OP does the light come on on the adapter?
And what kind of phone do you have?
Oops I see now the adapters light up. I had this problem and it was a simple setting adjustment in the phone. Had to be set for charging not just data.
Midnight2012 is offline   Reply With Quote
Old 05-24-2015, 11:30 PM   #7
king_13's Avatar
What fuse goes to the dashboard accessory port?
Sent from my iPhone
Old 05-24-2015, 11:35 PM   #8
Bear376's Avatar
It could be a bad ground or wire. My Dodge Dakota had this problem for years. Both power points would show that there was power, but would not charge. Several good mechanics could not figure it out. I finally ran a fused wire to the battery, and a ground wire to the chassis.
2013 MCA Edition-Sterling Grey
Roush body kit - Splitters/hood scoop
Whiteline suspension w/Koni shocks
Bear376 is offline   Reply With Quote
Old 06-01-2015, 08:56 PM   #9
I had the same problem...I only got one charger to work and it was a really long one...had to go deep in the hole i guess.
mustanguitarist is offline   Reply With Quote
change the fuse box cigarette lighter to turn off mexor The Bar 9 01-25-2004 03:10 PM
06:41 AM
