Need help wiring please 😬 - Mustang Evolution
Old 03-11-2015, 07:57 PM   #1
Name:	ImageUploadedByMustang Evolution1426124362.431629.jpg
I tried putting this el light on the dash of my '14 v6 mustang. These were wired direct to test. I want to have them wired so they turn on when all the other lights on the dash go on.i don't want a separate switch. It's just a hot and ground. I just really suck at this sort of thing and was hoping to tap the collective knowledge of the forum.
Thanks in advance for any help!
Silverwulf is offline   Reply With Quote
Old 03-11-2015, 08:08 PM   #2
oxford5pointoh's Avatar
Easiest way would be to tap a positive wire that runs one of the lights on the dash (radio illumination wire comes to mind and is probably the easiest) then just find a good ground. There is a great ground bolt right above the fuse box on the passengers side. Use a test light to make sure you have the right illumination wire.
Lights on=test light on
Lights off=test light off
Success
Old 03-11-2015, 08:14 PM   #3
Thanks! I'll give that a try. Right now the connection side is on the drivers side because I was hoping to tap into a wire on the light switch. Any wire colors that indicate what I'm looking for? Is ground black? I'm used to German cars. They use brown.
Old 03-11-2015, 08:19 PM   #4
I've noticed black and yellow striped wires seem to be ground. I'm sure you can locate the wires you need behind the light switch as well. Just be careful not to disturb anything sensitive. And make sure you are careful if you use those wire splicer type connectors. Sometimes those will cut the wire completely and cause you to lose your original connection. And if that's directly behind your light switch that could suck.
Old 03-11-2015, 08:31 PM   #5
Kevin.Cook
Guest
Posts: n/a
If the car is auto, you can tap into the shifter lights. I did that for my footwells and led cupholder.
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Old 03-12-2015, 11:27 PM   #6
Commercial Member
au01st's Avatar
I forgot which is which, but you could use the same wires that Starkey recommends for puddle lamps. Should be able to find the video and get wire colors for either side.
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 03-12-2015, 11:38 PM   #7
Yeah that is a purple/green wire I believe. But if you use that the lights will only come on when he opens the doors or when he hits the unlock in the car. Those don't turn on with the interior lights like he wanted originally.
NITROUS. Is my wiring wrong. PLEASE HELP Jsmorley81 2011-2014 Mustang GT 12 02-17-2017 07:36 AM
Nitrous wiring help..... PLEASE Jsmorley81 2011-2014 Mustang GT 3 06-06-2014 08:55 PM
Quick Wiring help please!! Evolution 1979-1995 Mustang GT 4 04-04-2014 04:15 PM
Need wiring info Please help 1949FodF1 Pre-2005 V6 Mustang 1 02-21-2014 12:34 PM
2000 Mustang V6 Wiring Door panel wiring problem wyatt-00' Pre-2005 V6 Mustang 3 11-30-2009 12:43 AM
09:31 PM
