Shocks and Struts - Mustang Evolution
Old 03-16-2015, 11:18 PM   #1
Smile Shocks and Struts
So I am having a little problem. I lowered my car using SVE lowering springs. 1.5 inch drop all around. I bought the J&M Pandhard bar as well as Strut Tower brace. Put them all on about 2 months ago. I started getting a clicking noise while turning the wheel. I originally thought it was the inner tie rod or the rack and pinion assembly. I took in to firestone to get checked, the guy there told me its due to the lowering springs, it makes a clicking noise sometimes with the OEM struts. Has anyone had experience with this? I am looking at getting Steeda Pro Action shock and strut kit. Has anyone had experience with these specifically with SVE lowering springs or 1.5 drop? Any help would be greatly appreciated, thanks.
john21martin is offline   Reply With Quote
Old 03-17-2015, 12:37 AM   #2
Eric e's Avatar
What do you mean by clicking noise?
I know I've seen some people post about a clunking noise towards the rear(I think) and that it gets fixed by getting a better uca.
Katy Texas
Eric e is offline   Reply With Quote
Old 03-17-2015, 11:16 AM   #3
tj@steeda's Avatar
John,
Does this describe what you are experiencing?
After I lowered my 2012 mustang, I immediately started experiencing popping sounds when I took turns. I looked all over the net trying to find strut mounts to correct the problem. Not an easy task for a 2012, until I found these awesome caster plates by Steeda. 100 folds better and durable than the stuck strut mounts and better than any else on the market today. I strongly recommend these if you are experiencing the same with you 2011 and up lowered mustang or if your planning to lower your stang. - See more at: Steeda 2011-14 Mustang Upper Strut Mounts - Made in the USA 555-8135 - Free Shipping!
More than likely ... you will need to replace your mounts. Let me know if I can help you with set & if you would like to improve the ride even further ... then the Steeda Pro Action Shocks & Struts will add this to the package:
Exceptional ride quality
Properly valved for your Mustang
Better ride than competing brands
Engineered & manufactured to exceed OE standards
Great for street and track action!
Lifetime warranty
Made in USA
- See more at: Steeda 2011-14 Mustang Pro-Action Shocks and Struts 555-8405-11 - Free Shipping!
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Best and well priced shocks and struts 98mustang11 Pre-2005 V6 Mustang 150 03-06-2013 12:42 PM
shocks and struts install how to STEVE Pre-2005 V6 Mustang 6 05-25-2005 11:40 AM
installing shocks and struts STEVE Pre-2005 V6 Mustang 14 05-14-2005 03:45 AM
Shocks and Struts installed (pictures inside) Brent Pictures and Videos 22 11-07-2004 01:08 PM
Shocks and Struts with springs? steedav6builder Pre-2005 V6 Mustang 16 07-13-2004 09:42 AM
04:34 AM
