Ambient Lighting Help - Mustang Evolution
Old 03-17-2015, 12:45 PM   #1
Hey guys,
So my buddy's birthday is coming up and I wanted to surprise him with this lighting kit but I had a few questions. I will be using the follow kit:
LEDGlow 2pc. Expandable 7 Color LED Interior Starter Kit
So I will be using the method from the video below (Wiring from the Control Box from the LED Kit directly to the fuse fox.) Does anybody know what size fuse I would need to get ( I believe it's mini?). I wanted to also remove the fuse from a switch power rather than a constant supply. Which fuse do you guys recommend to use? I found a manual with the fuse chart but I just wanted to be a 100% sure. (page 222 attached below) The kit says I only needs 10amps or less.
Thanks!!
mattsup94 is offline   Reply With Quote
Old 03-27-2015, 05:43 AM   #2
Brandonb2012's Avatar
Any luck?
Brandonb2012 is offline   Reply With Quote
Old 03-27-2015, 07:35 AM   #3
Pretzel's Avatar
I do believe it is mini. I ordered this kit along with the expandable circuit for the mini fuse (not the low profile mini). Seemed to plug in fine. Granted, I have not finished this installation...it has started to pour here and hasn't let up yet.
Pretzel is offline   Reply With Quote
Old 03-27-2015, 07:38 AM   #4
Pretzel's Avatar
BTW, when I first went to plug in the expandable circuit, I lost the first fuse I yanked out (still can't find the sucker), so I had to run down to the hardware store to grab another 20amp fuse (in mini). Worked fine.
Experienced with 11+ Mycolor/Ambient lighting back n a stang 2011-2014 Mustang GT 10 02-26-2016 09:46 AM
Ford Ambient Light Kit/Interior Lighting Kevin.Cook 2011-2014 V6 Mustang 2 12-29-2014 09:40 AM
Ambient Lighting Tribbie 2011-2014 V6 Mustang 3 07-11-2014 09:44 AM
Ambient lighting tgmeyer 2011-2014 Mustang GT 8 08-01-2012 06:17 AM
ambient lighting 04TRV6 General Mustang Discussion 9 07-14-2012 09:41 PM
04:29 AM
