2 Questions: Modular Intake Tube and Gear Oil - Mustang Evolution
Old 03-17-2015, 02:04 PM   #1
derklink's Avatar
Hi everyone,
I have two questions and would highly appreciate any input!
1. Is that Airaid Modular Intake Tube worth the $105? I have an automatic with a tune and am mainly looking for a little better throttle response. Any low end torque and/or hp gain would be also great.
2. When I got my 3.31 gears, friend did it, he put in 2 quarts of Royal Purple.
I've heard of some that say it needs 3 quarts. What is true?
Thank you!
derklink is offline   Reply With Quote
Old 03-17-2015, 02:26 PM   #2
Diehard's Avatar
Originally Posted by derklink View Post
Hi everyone,
Thank you!
1. Ask your tuner for a little better throttle response. And while you're at it see what they have for an answer to your intake tube question.
2. Look here for your answer...
Royal Purple Max Gear 75w90 Mustang Gear Oil 1300 - Free Shipping
Edit: They say 3 quarts
Old 03-17-2015, 02:49 PM   #3
derklink's Avatar
Thank you for your input, Diehard! I have a Bama tune and I don't know if they can/will tweak out a little more but I can sure ask them. As to the gear oil, I am quite confused cause AM sells their gear kits with only 2 quarts ( I ordered the parts from them individually, since they don't sell a 3.31 gears kit).
Ford Racing Mustang 3.55 Gears and Install Kit 100572 (10-14 V8; 11-14 V6) - Free Shipping
And I have been running my 3.31's now for about 4 months without any problems.
Old 03-17-2015, 03:25 PM   #4
Diehard's Avatar
This sounds familiar. I think that question came up on this forum and the one of the AM reps commented on it.
I want to say it was a screw-up of some sort but not sure. Try a search.
Old 03-17-2015, 03:38 PM   #5
derklink's Avatar
Thank you!
How many quarts of 75W-140 Gear Oil to use? - The Mustang Source - Ford Mustang Forums
Still kind of confused
Old 03-17-2015, 04:40 PM   #6
Diehard's Avatar
I did some research, just for the hell of it, and now I'm confused too.
I would have sworn the answer was 3 qts then I checked my owners manual.
It said 4 pints(2 qts).
I'm surprised no one has chimed in yet.
Old 03-17-2015, 04:42 PM   #7
Harm_3.7's Avatar
When I got my gears installed I was told I need 2.5 quarts. Which is 3 bottles of royal purple and you still have some left over.
Harm_3.7 is offline   Reply With Quote
Old 03-17-2015, 04:56 PM   #8
tym_v6's Avatar
I needed about 2.5 qts, but I also have the FRPP aluminum girdle, which increases oil capacity somewhat.
Old 03-18-2015, 04:54 AM   #9
If the owners manual says 2 quarts why are you confused? I'm confused that your confused lol
Just_A_GT is offline   Reply With Quote
Old 03-18-2015, 06:04 AM   #10
David Young's Avatar
I've changed my rear end lube 3 or 4 times. With the factory cover it took 2 1/3rd quarts
David Young is offline   Reply With Quote
Old 03-18-2015, 07:53 AM   #11
smurf stang's Avatar
With the stock cover it will be 2 quarts plus the friction modifier.
Depending on which aftermarket cover it will be approx. 2.5 quarts.
2016 VW GTI 2.0 Turbo
Old 03-18-2015, 08:06 AM   #12
fenixignition's Avatar
are they the same spec on the 8.8 over the years? I kinda remember putting in 2 bottles of mobil1 75w140 in my 02 gt. stock cover, stock gears, etc.
2002 GT 5sp. 16x,xxx miles
Old 03-18-2015, 11:03 AM   #13
Diehard's Avatar
I like this answer the best.
When changing gears, would you typically use the stock cover?
What's the purpose of the aftermarket cover? Greater capacity better?
Old 03-18-2015, 11:51 AM   #14
Kevin.Cook
Guest
Posts: n/a
I heard it came with a drain plug so you didn't have to remove the cover every time in order to swap the fluid.
Old 03-18-2015, 12:48 PM   #15
Got a diff cover off of a GT500 for cheap and it gives you a drain plug and a fill plug. It also has "cooling fins" which should help cooling if you were to track the car. It also holds half a quart more so.
Old 03-19-2015, 11:37 AM   #16
tym_v6's Avatar
I have the FRPP aluminum girdle/cover that his drain and fill holes. Beware that for this cover, the fill hole is way above the level of the fill hole on the diff housing, so if you fill all the way up to this hole, you'll overfill the diff bigtime. Not sure about the GT500 cover, but it's worth paying attention to.
Airaid modular tube krazyrail 2011-2014 Mustang GT 1 06-14-2014 06:23 AM
5.4 modular swap HPS intake ?? victory181 1996-2004 Mustang GT 0 10-27-2011 06:12 PM
Ford Racing 4.6 Modular PI Intake stangstar92 1996-2004 Mustang GT 7 02-26-2011 02:25 PM
Long tube header vs. short tube USMCSS 1996-2004 Mustang GT 5 12-24-2006 05:06 PM
01:47 AM
