MCA Grille - Mustang Evolution
Old 03-18-2015, 04:15 PM   #1
smcd32's Avatar
MCA Grille
Just installed my new MCA Grilles from #LEVITTOWNFORD on my 2014 Ruby Red Vert. Took 15 min. How to do this you might ask??? Its really simple and no tools required but Masking tape.
1. Place Masking tape on the bumper area under the grille.
2. Pull really hard with your hands on both sides of the grille fingers in the holes, it will take a bit of force but it will come off and you will not break the plastic tabs. Those are some thick tabs with a shallow lip. Just give a really good FIRM tug and it will pop right out.
3. Pull out bottom one same way. I will say that I had to reach down from Upper grille opening and pinch the top middle tab while tugging at it from the front but it came off after just a few trys. MAKE SURE TO DISCONNECT AIR SENSOR ON THE LOWER GRILLE LOWER RIGHT CORNER BEFORE PULLING IT ALL THE WAY OUT.
4. Clean up the layer of dirt and grime and install the new set. AGAIN MAKE SURE TO REATTACH AIR SENSOR ON LOWER GRILLE FIRST.
5. To re-install its as simple as lining up tabs and pushing the grille in. Remove tape and take pics for us to see.
Let me know what you think.
**This weekend the GT/CS Spoiler gets installed.**
ID:	177835   Click image for larger version
smcd32 is offline   Reply With Quote
Old 03-19-2015, 07:16 AM   #2
Pretzel's Avatar
Looks great, and thanks for the walkthrough! I installed my grille in a similar manner.
Pretzel is offline   Reply With Quote
Old 03-19-2015, 07:37 AM   #3
Darth Paul's Avatar
Just wish they did this grille with GT fog light openings.
Sent from somewhere near the center of the Milky Way
Darth Paul is offline   Reply With Quote
Old 03-19-2015, 08:08 AM   #4
Pretzel's Avatar
Did you install your fog lights? Was that the Starkey kit?
Old 03-19-2015, 08:49 AM   #5
smcd32's Avatar
Fog lights came with the Premium package
Old 03-19-2015, 10:57 AM   #6
Heres mine. Was the same color as yours but didnt like it much on black so i dipped it๐Ÿ˜
Name:	ImageUploadedByMustang Evolution1426784236.828842.jpg
Ride or die
efrain is offline   Reply With Quote
Old 03-19-2015, 11:31 AM   #7
tym_v6's Avatar
Looks great! I love the MCA grille...gives the car a more aggressive look.
Old 03-20-2015, 05:31 PM   #8
Diehard's Avatar
Can the tri bar pony emblem be removed and replaced, easily?
Old 03-20-2015, 07:17 PM   #9
rmb427r's Avatar
Thanks for the write up. Looks great!
Ron..
2008 Roush 427R
2014 V6 Prem
rmb427r is offline   Reply With Quote
Old 03-20-2015, 07:33 PM   #10
Shadetree43's Avatar
Thank you. Installed my CS grill much the same way. My 14 V6 Premium did not come with fog lights. I got them from eBay Ford seller. Switch from Amazon.
For info, with the CS grille the TriBar will mount on either side.
Shadetree43 is offline   Reply With Quote
Old 03-23-2015, 08:39 AM   #11
smcd32's Avatar
Honestly did not look at it before I installed it but from reading other threads on here it seems like a pretty easy modification from what others have said.
MCA grille PirateJohn 2011-2014 V6 Mustang 37 03-19-2013 06:47 AM
Lower billet grille matching mca edition NickAP12589 2011-2014 V6 Mustang 3 11-08-2012 08:49 AM
MCA grille color Brienna 2011-2014 Mustang GT 2 11-05-2012 04:08 PM
2012 Mustang v6 MCA grille question SixerStanger 2011-2014 V6 Mustang 6 09-25-2012 09:55 PM
MCA Upper and Lower Grille installed pwrby4d 2011-2014 V6 Mustang 11 09-24-2012 07:58 AM
11:56 AM
