Brembo Brake upgrade - Mustang Evolution
Old 03-19-2015, 09:23 AM   #1
Socal Stangman's Avatar
So I ordered the Baer Eradispeed +2 rotors for the rear of my 14, being delivered today as a matter of fact. Now I want to do the front which leads me to my question...if I buy the Baer 14" rotors for the front would a Brembo Caliper then be a direct bolt on? I don't want to buy a whole kit because it would be cheaper to just get the rotors and then the calipers. Any input on this?
Old 03-19-2015, 09:39 AM   #2
jande063's Avatar
As long as their rotors are the same thickness as the standard rotors, it is not a problem. You could contact the manufacturer's tech line to get that answer. The caliper is a direct bolt on, just the two bolts on the knuckle, the hydraulic line, and the restraining bolt on the line.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 03-19-2015, 09:52 AM   #3
Cool thanks. Im pretty sure the thickness is the same because it says they fit the GT. I wasn't sure if the V6 would have the same caliper mounting points.
Old 03-19-2015, 10:01 AM   #4
jande063's Avatar
Ford used the same knuckle for all of these cars, it keeps design, manufacturing, and supply complexity and cost down.
Old 03-19-2015, 10:39 AM   #5
Thanks for the info, I appreciate it.
Old 03-19-2015, 12:41 PM   #6
One more question, what about the brake lines? Will I need to replace these as well?
Old 03-19-2015, 12:52 PM   #7
jande063's Avatar
The brake lines that are on the Brembo calipers will do fine. I do not know if the lines for the original calipers will reach the brembo caliper. I would check to see if the brake line part number changes from the non-brembo caliper to the brembo caliper. Tousley Ford has their parts list online, it is a great resource.
To Brembo or not to Brembo (13 GT?) MustangCPA General Mustang Discussion 14 03-20-2015 09:21 AM
Brembo brake Upgrade questions kramer General Mustang Discussion 11 02-24-2014 02:08 AM
Cobra R Brembo brake upgrade complete Mzilla 1996-2004 Mustang GT 6 07-01-2013 02:09 PM
Brembo Brake upgrade poloka 2011-2014 Mustang GT 2 04-15-2012 09:45 AM
Brembo Brake Kit Shahrum Pre-2005 V6 Mustang 8 05-13-2004 06:27 PM
02:43 PM
