Check engine light - Mustang Evolution
Old 03-19-2015, 01:11 PM   #1
Check engine light
Hello first time posting and hoping you guys can help me out.
I've recently installed BBK Long Tube Header and BBK Off road x pipe and now Im getting check engine light.
Anyone know how to fix this? I've deleted the codes repeatedly and it still comes on.
Asian_Sensation is offline   Reply With Quote
Old 03-19-2015, 01:13 PM   #2
oxford5pointoh's Avatar
Do you have a tune? If you removed cats you will get a CEL unless you have a tune for the off road pipes
Old 03-19-2015, 01:15 PM   #3
So you're recommanding that I get it tuned to off road?
Old 03-19-2015, 01:19 PM   #4
Unless you want to look at a CEL forever and have your car think it has cats and is still seeing a ton of un used fuel. I could be wrong but that will probably cause your car to run lean. I'd venture to say it's not safe to drive that way. The tune will trick your car into thinking the O2 sensors are doing what they should. Keeping the fuel levels correct. Right now it thinks there are cats and it's seeing a ton of fuel as if it's rich.
Old 03-19-2015, 01:30 PM   #5
blackstang1's Avatar
I'm sorry, but i can't take you seriously with that username
2014 Mustang V6 w/Technology package, 6MT
Mods: Airaid CAI w/ Synthamax filter, 18" black AMR wheels
blackstang1 is offline   Reply With Quote
Old 03-20-2015, 10:44 AM   #6
I was thinking about getting MIL eliminators but will that fix the rough idle problem? Or do I have to get it tuned to fix the prpblem.
check engine
Check Fuel Cap & Service Engine Soon Light??????? mattstang Pre-2005 V6 Mustang 8 12-25-2006 01:33 PM
check engine soon light finally off stangracer Pre-2005 V6 Mustang 4 02-04-2004 10:41 AM
Check Engine Light MUSTANGJUNKY420 Pre-2005 V6 Mustang 11 08-09-2003 12:29 AM
Check engine light, codes inside, cause? MUSTANGJUNKY420 Pre-2005 V6 Mustang 1 08-03-2003 08:24 AM
Check engine light, codes inside, cause? MUSTANGJUNKY420 Pre-2005 V6 Mustang 2 07-30-2003 12:22 AM
04:28 PM
