BIG PROBLEM ON PROCHARGED V6 - help - Mustang Evolution
Old 03-19-2015, 09:10 PM   #1
grom80's Avatar
All happened after my cooling fan resistor blew. Fan wouldn't start anymore...temp got to 243F but I noticed immediately and slowly drove back home, literally happened 5 minutes from home. Left the car there for a week waiting for replacement resistor...replaced it...turned it on, fan worked...and then this. Idle was inconsistent, runs sluggish, feels choked...and when you turn it off there is still a very slight smoke coming out of the right tailpipe.
No check engine light but on my phone app connected to an OBD device that monitors the ecu...I got the codes below :
Name:	ImageUploadedByMustang Evolution1426820998.464464.jpg
What's going on ??
grom80 is offline   Reply With Quote
Old 03-19-2015, 10:26 PM   #2
Noodles76's Avatar
Could have blown a head gasket and/or warped a head...
Rollin' in my 5.0
Noodles76 is offline   Reply With Quote
Old 03-19-2015, 11:28 PM   #3
2011fastford's Avatar
Region: New Mexico
ouch that sucks...
2011 Mustang V6 auto/procharger p1sc kit with 3.70 pulley/circle d 3200 stall/4:10 gears/dss aluminum driveshaft/tial q bov/bbk long tubes with catted x pipe/dynomax ultra flo catback/bbk throttle body/accel super coils/cyclone ported upper and lower intake manifolds/brembo front brake kit
INSTAGRAM @2011fastford505
2011fastford is offline   Reply With Quote
Old 03-20-2015, 12:16 AM   #4
2 Stangz's Avatar
Region: Nevada
Damn dude. Coyote swap time?
Old 03-20-2015, 12:27 AM   #5
Noodles76's Avatar
Check the oil; if it's milky, it has coolant in it and it will prove the head gasket theory. I would suggest you get it to a reputable shop and have them tale a look at it.hope you get it fixed soon and at a reasonable price.
Rollin' in my 5.0
Old 03-20-2015, 01:17 AM   #6
grom80's Avatar
Anyone have any thoughts on whether it could be pistons/rings/rods ? ...hopefully it's just head gasket...that's an easy one. If it is warped head what does that entail ?
Old 03-20-2015, 01:49 AM   #7
iantrusive's Avatar
Sounds like something got too hot and warped/broke.
Sent from my Mustang.
iantrusive is offline   Reply With Quote
Old 03-20-2015, 08:02 AM   #8
Noodles76's Avatar
If the heads are warped it is possible to have it repaired but most likely you will need to purchase new heads
Rollin' in my 5.0
Old 03-20-2015, 10:11 AM   #9
smurf stang's Avatar
If the heads are warped you will notice a loss of coolant so start there.
Check to see if you are burning coolant, check your oil like stated above, reset the computer.
2016 VW GTI 2.0 Turbo
Old 03-20-2015, 01:31 PM   #10
This might sound stupid ---BUT-- Worth a try.
Go out and disconnect the battery for about 1/2 hour.
Connect it back up and start it up.
There is some fail safe type thing in the computer that cuts engine performance way down if it thinks the car is going to overheat. Hopefully this will reset everything and make your engine run smooth again.
Old 03-20-2015, 05:35 PM   #11
grom80's Avatar
Tried that...same.
I will take it by steps :
pull plug (see)
Replace plug
Replace coil
Have it towed to my tuner because at that point it's a head problem.
Old 03-20-2015, 06:28 PM   #12
sticks123's Avatar
Outside of this issue how have you liked your pro charger?
sticks123 is offline   Reply With Quote
Old 03-20-2015, 07:27 PM   #13
grom80's Avatar
Never fully to tell you the truth...torque is not as immediate as when I was NA...sure when boost kicks in it's great.
Old 03-20-2015, 07:41 PM   #14
sticks123's Avatar
You got a supercharger right?
Old 03-20-2015, 08:50 PM   #15
Region: Arkansas
have you tried compression testing each cyl yet? if one cyl is vastly different than the others than you know its not an electrical problem (plug, coil, etc.)
Cold Silence is offline   Reply With Quote
Old 03-21-2015, 01:14 AM   #16
paintmann111's Avatar
Hey grom. Its chris from the cyclone fb page. Lol
Where you able to check the plugs/oil?
paintmann111 is offline   Reply With Quote
Old 03-21-2015, 07:56 AM   #17
grom80's Avatar
No not yet. I am out of town for work...will have to deal with it when I get back next week.
I'll try a compression test first and look at plug when I pull it out...then coil is next step.
Anyone know the correct numbers for compression on these engines ? Where do I get them ?
Old 03-21-2015, 08:08 AM   #18
grom80's Avatar
Yes I am supercharged
Old 03-21-2015, 09:43 AM   #19
Diehard's Avatar
I couldn't find the actual numbers, but you'll be looking more at the difference in readings anyway.
You may not need this but I thought it was a good little article on compression testing.
http://www.2carpros.com/articles/how-to-test-engine-compression/page/3
Good Luck!
Old 03-21-2015, 11:02 PM   #20
grom80's Avatar
Anyone know exactly which cylinder is number 6 and what are the normal compression numbers for this motor ?
Old 03-21-2015, 11:24 PM   #21
natestang07's Avatar
The cops should be labeled with numbers somewhere. Or the wires
Old 03-21-2015, 11:33 PM   #22
grom80's Avatar
Cops you mean ?
Old 03-22-2015, 09:40 AM   #23
Diehard's Avatar
Re: Compression Numbers
Here's what I found...
2011 Ford Service Manuals
Following link is for "Engine System — General Information"
Ford Service Manuals - DIAGNOSIS AND TESTING
then click on "Compression Test — Compression Gauge Check"
(Still doesn't give a specific value but rather that, "The indicated compression pressures are considered within specification if the lowest reading cylinder is at least 75% of the highest reading.")
Pretty sure the following is the correct one.
Name:	3.7L engine.jpg
The larger of the 2 diagrams, that is. Not sure what that smaller one represents.
Old 03-23-2015, 12:37 AM   #24
grom80's Avatar
Thanks !!
Old 03-23-2015, 12:40 AM   #25
Thanks !!
Yeah that bigger one is the way my 07 was
Old 03-23-2015, 04:59 AM   #26
JimC's Avatar
Attachment 178091
The smaller one looks like the coil pack spark plug wire diagram for a 4.0 -
JimC is offline   Reply With Quote
Old 03-30-2015, 03:37 PM   #27
grom80's Avatar
Hey y'all...
So I removed all the spark plugs and they look fine...oil looks fine...no smoke coming from the tailpipes...
Reverted to stock and then retuned the car...same problem...feels like it's running on 5 cylinders, sounds weird, shakes, hiccups and idle is irregular.
Did a compression test with the crew in hose method which is more reliable :
1 - 126psi
2 - 120 psi
3 - 122.5 psi
4 - 114 psi
5 - 125 psi
6 - 129 psi
How do these look ?
Old 03-30-2015, 07:46 PM   #28
Geok.91's Avatar
Hey y'all...
1 - 126psi
2 - 120 psi
3 - 122.5 psi
4 - 114 psi
5 - 125 psi
6 - 129 psi
How do these look ?
Did u check you oil and see if coolant was mixed in there yet? And looks like number 4 is your problem but the compression is not off that bad
Geok.91 is offline   Reply With Quote
Old 03-30-2015, 08:35 PM   #29
grom80's Avatar
Oil is clear...no smoke as well and no loss of coolant.
...so after all this I think the problem has been resolved...I changed out the coils (Accel) and put the stock coils back on...bada bing. My theory is that when the ****ty aftermarket fan resistor I had on burned out, it surged and fried the fuse but also a coil...since I am not running 1 different coil, I changed all of them. Tomorrow will drive around warmed up to test and confirm. Compression was good so not a case of piston rings or such...also oil is clear and no smoke as well as no loss of coolant means gasket is intact.
Old 03-30-2015, 09:03 PM   #30
Geok.91's Avatar
Glad to hear it's not the head gasket
Big Problem, need help! EMERGENCY! Project Pony Pre-2005 V6 Mustang 22 02-05-2013 12:02 PM
Anderson power pipe problem procharged gt p1blake04 1996-2004 Mustang GT 2 08-30-2011 09:25 PM
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 11:10 AM
Saleen or Procharged GT? jimmy_beaner The Bar 26 03-17-2006 10:14 AM
03 cobra vs procharged ls1 video Zim The Bar 15 08-02-2005 01:18 PM
05:04 AM
