Swerving - Mustang Evolution
Old 03-21-2015, 01:14 PM   #1
roushMarlon831's Avatar
Send a message via Yahoo to roushMarlon831
Swerving
Put new wheels on my car and As soon as I step on it now my car swerves. What could be the problem? Click image for larger version
Name:	ImageUploadedByMustang Evolution1426965268.871668.jpg
roushMarlon831 is offline   Reply With Quote
Old 03-21-2015, 02:45 PM   #2
Arlexisv6's Avatar
Probably need a alignment
Arlexisv6 is offline   Reply With Quote
Old 03-21-2015, 02:47 PM   #3
Chaz12's Avatar
Did you balance all 4 tires?
2013 Premium Performance White
GT500 blue racing stripes with matching hash marks, cold air intake, Flowmaster super 44s with Roush tips, CDC performance grille, side scoops, painted white quarter windows
Last Mod: CDC Performance Grille
Next mod: Bama Race Tune!
Bama 91 Race tune, GT500 blue racing stripes with matching hash marks and side stripes, cold air intake, Flowmaster super 44s with Roush 4" Tips, CDC performance grille, side scoops, painted quarter windows, all lights tinted
Chaz12 is offline   Reply With Quote
Old 03-21-2015, 03:00 PM   #4
Arlexisv6's Avatar
^^^^^ this is what I meant lol
2014 Black 3.7 Mustang. Airaid intake, Sct Bame tuned. Flowmaster Force 2 axelbacks.
Old 03-21-2015, 03:23 PM   #5
They've all been balanced before getting put on
Old 03-21-2015, 03:42 PM   #6
Diehard's Avatar
Would be more alignment then balance. If either.
Check for correct air pressure all around, as well.
4 new wheels?
Old 03-21-2015, 04:17 PM   #7
Yea four new wheels. They've got their correct pressure. A thing you might want to known is their staggered? The back ones of course are 285/30/19 and front are 265/30/19. I didn't get em aligned by the way just balanced and put on
Old 03-21-2015, 04:18 PM   #8
Arlexisv6's Avatar
Then yea it most likely a alignment problem
Old 03-21-2015, 04:23 PM   #9
I'll go ahead and align them then
Old 03-21-2015, 04:41 PM   #10
Thanks for the help
Old 03-21-2015, 07:11 PM   #11
This may or may not matter but are the tires directional and are they on the right way? If I remember on my rx7 they tire shop mounted one of my rears backwards and it swerved and was really unstable?
Wysh is offline   Reply With Quote
Old 03-22-2015, 01:17 AM   #12
JohnnyBob's Avatar
I did the same thing, added brembo track pack wheels to mine and swerves on uneven road and especially when it's wet. I saw some directional marking on the wheels but made no sense to me the way they were pointing. How are you supposed to install directional wheels?
JohnnyBob is offline   Reply With Quote
Old 03-22-2015, 01:29 AM   #13
dave73's Avatar
Swerving
If you mount the drivers side on the passenger side and vice versa. They will be going the wrong way not sure that's causing your swerving though.
dave73 is offline   Reply With Quote
Old 03-22-2015, 08:20 AM   #14
Diehard's Avatar
When the car is moving forward the tire should be turning in the direction of the arrow shown on the side of the tire.
If it didn't make sense to you, chances are they were on the wrong side of the car.
Old 03-23-2015, 09:52 AM   #15
Bill Hamilton's Avatar
If your tires are mounted correctly then check the torque on the lug nuts. Over or under-torqued lug nuts on the wheels cause this too.
https://www.rsracing.com/TechWheel.aspx#torque
Bill Hamilton
USAF Retired
1970 Mach 1 351C
2014 Shelby GT-500
2014 Mustang V-6 Convertible
Bill Hamilton is offline   Reply With Quote
Old 03-23-2015, 12:57 PM   #16
Does it swerve if the ground is perfectly level and smooth?
Gotta remember with more contact patch from wider tires it picks up the small grooves on the road better which can pull the car even if the alignment is perfect.
Old 03-23-2015, 01:47 PM   #17
JohnnyBob's Avatar
For example when I'm leaning to the shoulder to turn right and I drive over the solid stripe it swerves.
Old 03-23-2015, 01:48 PM   #18
Is it an actual serve like jerks the entire car drastically? Or is it just a kind of tug to the side?
Old 03-23-2015, 01:58 PM   #19
It swerves to the point my traction control kicks in
Old 03-23-2015, 02:01 PM   #20
JohnnyBob's Avatar
It's more of a tug to the point where I have to firmly grip the steering wheel.
Old 03-23-2015, 02:50 PM   #21
Directional tires are mostly directional for wear and water shedding purposes.
Being a much wider tire with more offset you car will have a lot more FEEDBACK. Very sensitive to any uneven surfaces.
changing tires and wheels has nothing to do with alignment. if the alignment was off before the more aggressive tires will amplify the symptoms..
is your car lowered?
sledge42hammer is offline   Reply With Quote
Old 03-23-2015, 02:57 PM   #22
JohnnyBob's Avatar
Not lowered yet but after this issue I'm not sure I wanna lower it.
You don't think it could be the shocks/struts? I didn't have this issue before swapping the wheels though.
So to me everything is pointing to something about the wheels.
Old 03-23-2015, 09:41 PM   #23
Oh man, 3. Weeks ago my dealer replaced both control arms on my car and since then I am having the same problem!!!!!!
If you find a dix let me know please
Ranger052 is offline   Reply With Quote
Old 03-23-2015, 09:43 PM   #24
Dealer had align my car 2. Times and still same problem
Old 03-24-2015, 06:49 AM   #25
IzzyMan's Avatar
This might seem strange, but you mention the solid strip / line. Here, those lines are slick. What you describe has happened to me on a few occasions. It took me a while to realize what was going on. I also spin easily at intersections while driving across crosswalks and the wide horizontal line for stopping.
Might not be your problem but that's my two cents.
Daily Driver-2015 Ecoboost Magnetic Wheel & Stripe Package Mishimoto Catch Can
TRADED IN
2014 Base V6 MT - Deep Impact Blue
MMD Hood Struts / GT500 Spoiler(Black) / MMD Quarter Window Louvers (Black) / UPR Oil Can / SR Perf Shock-Strut Tower Brace / Replaced Coolant Overflow hose Bama X4/SF4 with Race Tune
IzzyMan is offline   Reply With Quote
Old 03-24-2015, 10:25 AM   #26
Did you remove the clips on the wheel studs???????
These may be your roblem. Factory Wheels clear them but a lot of aftermarket wheels don't.
They are only needed when the car was on the assembly line. It is recomended to remove these when installing aftermarket wheels.
Old 03-24-2015, 10:39 AM   #27
JohnnyBob's Avatar
My wheels are oem track pack wheels though.
Old 03-24-2015, 11:43 AM   #28
I guess it's not the clips
Like some suggested, See if the tires are rolling in the direction they are designed to.
Old 03-24-2015, 10:03 PM   #29
And what about me guys . Since the dealer replaced the lower control arms i am having the same problem.
Two different dealers have aligned the car twice but after a few miles the problem comes back again.
This is really frustrating :/
Old 03-24-2015, 10:52 PM   #30
JohnnyBob's Avatar
Are you having this problem with your front or rear wheels?
Old 03-25-2015, 04:49 AM   #31
Front
12:14 PM
