TPMS monitor fault - Mustang Evolution
Old 03-22-2015, 04:01 PM   #1
roushMarlon831's Avatar
Send a message via Yahoo to roushMarlon831
TPMS monitor fault
How do I get rid of this. Couldn't clear it with the tuner and I was going to train the cars tires but I guess I need a special device
roushMarlon831 is offline   Reply With Quote
Old 03-22-2015, 04:29 PM   #2
kgallowaypa's Avatar
Did you go custom tunes? Maybe call up your company and see if they can manual ovveride the TPMS in the cluster
2014 Sterling Grey V6 Manual
PMods: Steeda CAI // MPT 93 Octane Tune // 3.73 Gears // Roush 4" Axelbacks // Ghost Cammed by MPT
AMods: Dome Bulbs // Mirror Covers // Hood Pin Kit // Roush Upper & Lower Grille
kgallowaypa is offline   Reply With Quote
Old 03-22-2015, 09:47 PM   #3
FastFord13's Avatar
Only way is to get tpms, or black electrical tape.
Sent from my LG-D852 using Mustang Evolution mobile app
Old 03-22-2015, 11:30 PM   #4
Waylap1's Avatar
Region: New Hampshire
I've had the Tpms learning tool and never needed it. I switch back and forth winter and summer wheels and don't do anything. Never had a light.
We need more info. Are these oem factory wheels with original Tpms or aftermarket wheels with tpms or no tpms?
Waylap1 is offline   Reply With Quote
Old 03-23-2015, 12:04 AM   #5
These are original oem wheels. The thing is. I got a flat. So I went to go get it fixed and it was the air valve that was messed up so they switched it out, could it be that?
Old 03-23-2015, 01:52 AM   #6
tym_v6's Avatar
Did they Robert out fool with your TPMS? Did you use Fix A Flat?
You can get the TPMS tool for under $40. I got a fault after switching to my winter wheels, even though I've done several winter/summer wheel swaps before without any problems. The tool cleared it.
Old 03-23-2015, 09:03 AM   #7
derklink's Avatar
Sorry to chime in but I have kind of a similar problem. Switched to a set of OEM wheels and tires with TPMS. Bought the training tool and tried it many times. Just won't sync. Don't know what else to do.
derklink is offline   Reply With Quote
Old 03-23-2015, 09:30 AM   #8
iguanaman3's Avatar
That would be the problem alright. The TPMS sensor is part of the valve. It is strange that they replaced it with a plain valve and did not tell you about it.
iguanaman3 is offline   Reply With Quote
Old 03-23-2015, 10:03 AM   #9
Site Sponsor
Hey Guys,
Have either of you tried to drop about 15-20 lbs of air out of your driver side front tire and then attempt to have them relearn? If they worked previously they should be just fine! Give that a try and let me know how you're making out!
Alex
Toll Free: 1-866-363-4591
Free Same-Day Shipping!
Old 03-23-2015, 10:03 AM   #10
Strange Mud's Avatar
+1 on tape
Old 03-23-2015, 10:46 AM   #11
Yea I'm sure it's the valve. Do I just get a new one and replace it?
Old 03-23-2015, 11:15 AM   #12
iguanaman3's Avatar
Replacing it is what the shop should have done but they would probably have soaked you for the cost of the part. A new one is available for $22.50 on Ebay. I would buy that and make the shop replace it and do the "relearning".2010 2014 Mustang GT V6 Genuine Ford Motorcraft Valve Stem TPMS Sensor | eBay
Old 03-23-2015, 11:23 AM   #13
Thanks for the help man.
Old 03-23-2015, 12:06 PM   #14
iguanaman3's Avatar
You're welcome. That's what this place is for.
Old 03-23-2015, 03:45 PM   #15
derklink's Avatar
Originally Posted by AMAlexLazarus View Post
Hey Guys,
Alex
Thank you, Alex! I will try that.
Old 03-23-2015, 07:48 PM   #16
sticks123's Avatar
I had a fault on mine and took it to the ford dealership and they reprogrammed it and it worked fine and NO charge.
sticks123 is offline   Reply With Quote
Old 04-26-2015, 09:32 PM   #17
Midnight2012's Avatar
No need for the TPMS sync tool on our cars.
This works just fine:
Name:	ImageUploadedByMustang Evolution1430105548.781399.jpg
Midnight2012 is offline   Reply With Quote
Old 04-26-2015, 09:59 PM   #18
iguanaman3's Avatar
Except 2012 or older Mustangs don't have the same TPMS system. Mine does not tell you which tire is low, you have to figure it out. No LCD screen either for this learning trick. It's good to know that newer systems are more accurate and I was wondering how the system could know which tire was low. You must have to do this "relearn" when you rotate your tires too. Thanks for posting it.
Old 04-27-2015, 02:06 AM   #19
TPMS monitor fault
Mine is a 2012 and when I push the emergency button 6 times the relearn info appears on the dash near the tach and speedo. No LCD screen needed. It appears like your warning symbols that you don't see until they are needed. Via LED warnings. It doesn't tell you which tire is low. It just syncs each TPMS individually to your computer. And no you CAN rotate without re-syncing. It just knows a tire is low, not which one.
If it didn't work then it wouldn't appear on my dash for relearning and it indeed does.
Try it on yours and you will see, you don't have to follow through just turn the key off and don't go thru the process.
Can't be sure but I doubt you have to re-sync on the ones that know which tire is low either. Each TPMS doesn't have a different frequency. It's saying which tire you are syncing so you know which one to let the air out of is all.
Old 04-27-2015, 07:45 AM   #20
iguanaman3's Avatar
Cool. I will try that.
TPMS fault Eric5oh 2011-2014 Mustang GT 4 02-16-2015 05:14 AM
Tire pressure sensor fault Rileychan01 2011-2014 V6 Mustang 12 06-17-2014 03:59 PM
Tire Pressure Sensor Fault? Black8thElement Mustang Wheels & Tires 4 04-28-2014 07:31 AM
Crack cover, not my fault! Who the hell doesnt torque the bolts down on IRS brace! drusmith 1996-2004 Mustang GT 12 03-16-2011 05:33 PM
I was involved in an accident that wasn't my fault, any suggestions what to do now? Attorney? avsalom Classic Mustangs 3 08-24-2009 04:40 AM
03:58 AM
