Please help broken AC line??? - Mustang Evolution
Old 03-23-2015, 08:09 PM   #1
IS3
IS3's Avatar
Hello peers!
I found a broken piece under the hood of my 3.7 and i want to know the name or product number of it so i can replace it. I believe its part of the AC hose??
Thank you!!!Click image for larger version
Name:	ImageUploadedByMustang Evolution1427162898.364656.jpg
ID:	178229Click image for larger version
Name:	ImageUploadedByMustang Evolution1427162915.838317.jpg
ID:	178230Click image for larger version
Name:	ImageUploadedByMustang Evolution1427162940.483545.jpg
ID:	178231Click image for larger version
Name:	ImageUploadedByMustang Evolution1427162954.860212.jpg
IS3 is offline   Reply With Quote
Old 03-23-2015, 09:37 PM   #2
How did that broke?
Ranger052 is offline   Reply With Quote
Old 03-23-2015, 10:30 PM   #3
IS3
IS3's Avatar
It started when i noticed the AC wasnt blowing cold air. I tried to put freon and all of a sudden it went out from the broken part showing on the pic. I had no idea how it broke...
Old 03-23-2015, 11:11 PM   #4
iguanaman3's Avatar
That is your compressor to condenser discharge line. I replaced mine 2 months ago. Mine developed a leak at the "muffler" joint from the vibration that caused yours to break. The new ones do not have the muffler, hopefully that will fix the problem. The part is about $85 from Rock Auto, Ford wants nearly double that.
It is an easy fix, the pipe is held on by 2 bolts. Of course you need you AC system evacuated and recharged too.
iguanaman3 is offline   Reply With Quote
Old 03-23-2015, 11:28 PM   #5
NewMtang's Avatar
Is it still under warranty?
Old 03-24-2015, 03:55 AM   #6
bucko's Avatar
With a severed break that large, I'd replace the dryer too, as moisture has no doubt entered the system.
Old 03-24-2015, 10:52 AM   #7
IS3
IS3's Avatar
Thank you, I went to Rock Auto website and found the part you mentioned. Do they include an installation guide?
Unfortunately no, when i bought it used, i was only given 3 months warranty...
Oh no, what is the dryer? will it be expensive?
Old 03-24-2015, 12:55 PM   #8
iguanaman3's Avatar
There is nothing with it but it is an easy install. Remove the radiator cover, unplug the pressure switch on the old line. Remove the bolts holding the line and pull it out. Put the new one in and install the bolts and plug in the pressure sensor. The line uses o-rings to seal it so don't damage them and you will be fine.
My compressor quit due to low pressure 2 months after my 36 month warranty was up. Luckily it is not as serious (expensive) as compressor failure.
Since your line is open to the air it will absorb humidity possibly saturating the dryer. If you live in a area that has dry air you might get away with just a recharge. But I would replace the dryer just to be sure. Rock Auto has them too I'm sure. I do not know how hard they are to replace. I would bet that everyone who as a Mustang that has the muffler in the discharge line will be in the same boat as us pretty soon. It is a design defect for sure.
2014 Broken Strut.. Self inflicted, Please help *Pics* OhSix750 2011-2014 Mustang GT 14 04-24-2014 09:08 PM
t5 swap... Trans broken after 800 miles HELP HELP flatstanley1 1979-1995 Mustang GT 11 01-17-2014 08:39 PM
04 GT Guages are Broken Help with swap raptor97322 1996-2004 Mustang GT 2 12-13-2012 10:53 AM
Help: Control Panel broken already Klaximilian 2011-2014 Mustang GT 9 10-11-2012 09:05 AM
My headlight switch is broken, help DropTop_Stang Pre-2005 V6 Mustang 6 10-15-2003 04:59 PM
06:10 PM
