wire covering - Mustang Evolution
Old 03-25-2015, 11:32 AM   #1
wire covering
Bought some wire covering to change over to a different color...regardless I took some entirely off and replaced and some were just taped to death and attached to different parts of the engine, yet my wiring pc's were big enough to go right over the orginals, would that move create a problem as to heat coming off the engine having some wires double covered?...just wondering if the heat would effect the wiring by being doubled covered....any thoughts?
Beamer is offline   Reply With Quote
Old 03-25-2015, 03:08 PM   #2
iguanaman3's Avatar
Since the heat comes from outside (the engine) and not inside the wire, insulating the wire will not cause it to get hotter. In fact the wire will be cooler for a while at least.
iguanaman3 is offline   Reply With Quote
Old 03-26-2015, 03:45 AM   #3
Wire coverings
Thank you for your thought on this...do appreciate it
Need to connect red wire to gray wire. clflorida Pre-2005 V6 Mustang 4 08-06-2013 06:46 PM
garage floor covering Spiney General Mustang Discussion 4 11-27-2011 09:15 PM
Covering the back peice, under the rear window in leather? SpectorV Mustang Audio & Video 9 03-21-2005 06:25 AM
WHere to wire A/F ratio sensor wire?!? TheSarge Pre-2005 V6 Mustang 0 09-04-2003 02:00 AM
I need a power wire to splice into. Rellik Pre-2005 V6 Mustang 22 07-30-2003 11:56 AM
10:27 AM
