First issues with my stang - Mustang Evolution
Old 03-25-2015, 12:04 PM   #1
3.7L's Avatar
As of recently my stang has been having a few minor issues. Car is a 2013 with a little under 20k miles. The front driver side wheel was squeaking whenever I would drive over a bump. Shortly after this occurrence, I got the error message " tire pressure monitoring system fault." I check the tire pressure, all was normal. Since the car needed an oil change I had my good friend, the local Ford service manager, take a look at the issues. She told me I have a bad control arm and the the TPMS sensor is bad. All repairs are under warranty. I am posting this because I read a few posts asking about the reliability of our cars. Other than these two issues, the car has not had any issues! Unfortunately I won't have my car back for a few days, but hey at least all repairs are free!
3.7L is offline   Reply With Quote
Old 03-25-2015, 08:31 PM   #2
The control arms are a very common issue. From what I have read on another forum they finally did come up with a fix, which you will probably get when they put your new one on. For a while people were having to have them replaced several times.
BrewGuy is offline   Reply With Quote
Old 03-28-2015, 11:19 AM   #3
king_13's Avatar
I've never had this problem, is there a specific model that has this issue?
Sent from my iPhone
2014 Oxford White 5.0 Premium
2015 Maroon Chevy Cruze LTZ
2011 Performance White V6 Premium SOLD
king_13 is offline   Reply With Quote
Old 03-28-2015, 02:53 PM   #4
Sent from my iPhone
2011-2013 Mustang lower control arm noise TSB's. - Ford Mustang Forums
Old 03-30-2015, 01:37 PM   #5
etr3.7's Avatar
Is that what I hear whenever I go over a bump? And is it really that common of a problem
etr3.7 is offline   Reply With Quote
Old 03-30-2015, 01:47 PM   #6
3.7L's Avatar
If you hear squeaking, then yes. From what I have heard it is very common. My buddy with a 2012 v6 had his control arm go bad last year, then it happened to me last week. Luckily the warranty takes care of it, but it takes about a week for ford to get the replacement part and to install it, well at least in my case.
Old 03-30-2015, 02:56 PM   #7
king_13's Avatar
Do you call your nearest Ford dealership and let them know that your control arms squeal or?
Sent from my iPhone
Old 03-30-2015, 04:06 PM   #8
They will replace them with a "shielded" LCA.
I'm at 13k on the "shielded" ones and starting to get the squeak again.
At this point I think the only true fix is to go aftermarket.
Wysh is offline   Reply With Quote
Old 03-30-2015, 04:22 PM   #9
2 Stangz's Avatar
Region: Nevada
Yeah OP you're definitely not the only one on MEVO that has had this LCA issue. TPMS isn't a big deal either. Keep up with your maintenance and you should be fine, these cars are mean't to be driven.
Old 03-31-2015, 04:57 AM   #10
etr3.7's Avatar
That's what I was thinking of doing just go aftermarket and not have to worry about it happening again
Old 03-31-2015, 05:33 AM   #11
shunc01's Avatar
Are you sure it's the lca? I had mine replaced from Ford covered with a warranty and it was my lower end links, it makes that squeeking noise when I go over bumps, problem solved but I added Bmr LCA a few months after that since I lowered my car.
MPT TUNE, Borla S-Type, Airaid Cai, Ford racing X pipe, Mac ceramic shorty headers, 2010 GT500 rims, 35% tint, Sr Springs, J&M phb, camber bolts, blacked out side markers, front and taillights.
2016 GT RACE RED MANUAL aka " RAGING BULL"
Mods:
Borla stypes cat back exhaust, tint kit all lights, 5.0 race red shift knob, MMD V SERIES SPOILER... and more to come...
shunc01 is offline   Reply With Quote
Old 03-31-2015, 06:38 PM   #12
etr3.7's Avatar
Not sure but it seems to be doing the same thing it squeaks when going over a bump
Old 03-31-2015, 07:19 PM   #13
shunc01's Avatar
Try to do this push your trunk up and down and if it squeaks it's the rear sway bar links is the problem since this is what I did when I showed my car to the dealership and they honor it no problem.
Mods:
Old 03-31-2015, 07:52 PM   #14
fordcrashdummy's Avatar
The control arms have a tsb out in them and have since 2012. Why they kept putting broken control arm bushings in I have no idea. I have the same problem on my 2014 but I've had that since I drove off the lot with 19 mi. That and water getting caught between the inner and outer rear quarter panel are constant issues I had and see other people have often. I also have a bad ground connection in the passenger door which lead to the electronics doing weird things but that isn't very common.
fordcrashdummy is offline   Reply With Quote
Old 03-31-2015, 08:08 PM   #15
Famine's Avatar
Region: South Dakota
I would rather have squeaking as opposed to popping. Glad you're getting it fixed.
Famine is offline   Reply With Quote
First new car, first mustang, first ford Sportsman New Member Introductions & Greetings 21 11-20-2015 02:59 PM
For the first time saw my first 2015 stang and.... shunc01 General Mustang Discussion 54 11-23-2014 08:55 AM
First Mustang...First Ford...First Car This Awesome! Debster New Member Introductions & Greetings 13 04-28-2013 12:30 PM
First Post, First Car, First Mustangg EdgeLivin New Member Introductions & Greetings 14 04-03-2012 12:49 PM
» Members Mustangs
JetWolf
JetWolf
Sally
Fryes
Add your Mustang
06:25 PM
