Sway bar - Mustang Evolution
Old 03-25-2015, 10:27 PM   #1
dobiev6's Avatar
Sway bar
Took my V6 into the dealer for regular maintenance check up. Asked them to check out noisy rear end. They are telling me I need a new sway bar? It's a '12 with just 40K on her. Does this seem legit? I've read a couple of other blogs that lead me to believe it's only the bushings. Any input would be appreciated, hate dealerships!
dobiev6 is offline   Reply With Quote
Old 03-26-2015, 12:40 AM   #2
2011fastford's Avatar
Region: New Mexico
yeah may just be the bushings they sell kits for it, i've always had good luck with poly bushings, and the sway bar on this car is pretty easy to remove so no worries there..
2011 Mustang V6 auto/procharger p1sc kit with 3.70 pulley/circle d 3200 stall/4:10 gears/dss aluminum driveshaft/tial q bov/bbk long tubes with catted x pipe/dynomax ultra flo catback/bbk throttle body/accel super coils/cyclone ported upper and lower intake manifolds/brembo front brake kit
INSTAGRAM @2011fastford505
2011fastford is offline   Reply With Quote
Old 03-26-2015, 05:23 AM   #3
I suspect I have the same issue. Been waiting for better weather to look into it.
Airslot is offline   Reply With Quote
Old 03-26-2015, 12:23 PM   #4
dobiev6's Avatar
Sway bar
Thanks, I'll start with the bushings and see if that solves the noise issues.
Old 03-26-2015, 09:42 PM   #5
tym_v6's Avatar
Could also be the bushings in the end links going bad. If so, there are aftermarket links with poly bushings that can fix the problem.
Old 03-27-2015, 12:25 AM   #6
JohnnyBob's Avatar
Had same issue a month ago, thought about just getting bushing and links but decided to just got with the entire thing. Got the H&R sway bar, at first I didn't want to spend that much just for a bar. When I got it man! It didn't feel cheap at all and my cornering is beyond improved. Didn't think a bar could do so much difference on the car.
JohnnyBob is offline   Reply With Quote
Old 03-27-2015, 03:50 PM   #7
elkoritaNAY's Avatar
after I installed the eichbach I had them squealing a lot but they after some wax or something and it went away after that.
Flowmaster force 2 exhaust, jlt cai, x4 bama tuner, carbon fiber dash overlay kit, modern retro shift knob, mmd hood and side scoops, classic quarter louvers, gt500 spoiler, 3.7 and pony emblems, mustang rocker stripes, eibach anti sway roll bar kit, Bbk shorty ceramic tuned headers
elkoritaNAY is offline   Reply With Quote
Old 03-27-2015, 09:20 PM   #8
aleXXXps's Avatar
My rear sway bar went after only 14k miles. I actually just had Ford fix it today under warranty. Here's the new one:
Name:	ImageUploadedByMustang Evolution1427512769.368405.jpg
I was disappointed that such a part would break so soon. My rear end was noisy and I thought it was a shock or something.
aleXXXps is offline   Reply With Quote
Old 03-27-2015, 09:30 PM   #9
iguanaman3's Avatar
Attachment 178560
It is very uncommon for one to break but that is what your warranty is for. It was most likely defective from the start.
It happens, nothing is perfect. Besides you now have a brand new one now.
iguanaman3 is offline   Reply With Quote
Old 03-27-2015, 09:38 PM   #10
Go eichbach front and rear
Old 03-28-2015, 09:27 AM   #11
Commercial Member
au01st's Avatar
I had my rear sway bar end links replaced under warranty. Took three trips and they started with a shock that was apparently also blown. After the new end links (which I suggested on my first visit) all was quiet and right in the world.
Granted, I am eventually going to replace them with aftermarket, but hey, didn't cost me a dime.
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 03-28-2015, 06:55 PM   #12
tym_v6's Avatar
Hopefully the squeak doesn't return! Came back workin a week of the dealer replacing mine, so I eventually went Steeda.
Poly bushing replacement in PH bar and sway bar rear 5LHO 2011-2014 Mustang GT 0 02-21-2015 12:38 PM
For a 1966 mustang, should I get a 1' sway bar or a 1' 1/8 sway bar, does it matter? Carthage Classic Mustangs 1 12-16-2011 06:37 PM
sway bar STEVE Mustang Parts for Sale and Wanted 31 07-04-2004 05:58 PM
sway bar STEVE Pre-2005 V6 Mustang 18 05-28-2004 09:38 AM
Sway bar Question 01mineralgrey6 Pre-2005 V6 Mustang 35 05-03-2004 11:20 PM
12:23 PM
