New Cel codes after removing Midpipe - Mustang Evolution
Old 04-14-2015, 02:08 PM   #1
RomanG's Avatar
Yesterday i had installed a lethal performance H pipe. After having ground clearance issues i removed the H pipe and reinstalled my factory pipe.
2 codes had come up
P0365 which is Camshaft position sensor B circuit bank 1
And
P0369 Camshaft position sensor B circuit intermittent bank 1.
It is also important to mention that I had installed a used BBK 73mm throttle body at the same time, which is still on the car.
Has anyone had a problem with this sensor, where is the location and how could it be fixed. Thank you.
RomanG is offline   Reply With Quote
Old 04-14-2015, 02:12 PM   #2
natestang07's Avatar
2 codes had come up
And
BBK throttle body=trouble for almost everyone
Old 04-14-2015, 02:13 PM   #3
RomanG's Avatar
How so?
Old 04-14-2015, 02:14 PM   #4
How so?
They throw codes often. Bbk being crap is one thing around here most people agree on lol
Old 04-14-2015, 02:16 PM   #5
RomanG's Avatar
Would these codes and the throttle body be related though
Old 04-14-2015, 02:34 PM   #6
Lots of things can cause the code. Could be as simple as a bad alternator, could be a voltage issue.
Old 04-14-2015, 02:49 PM   #7
Voltwings's Avatar
My BBK on my old 2001 had the throttle position sensor in a whacked spot, you had to shave the mounting holes or it would idle at like 2000 rpms lol ... Something very similar could be at play here. Typically in my experience, crankshaft codes come from increased idle or idle airflow that the computer is not expecting.
When going from 2" to 3" - 3.5" intakes the airspeed velocity slows down a lot, and can often register lower amounts. What we had to do (mazdaspeed platform) was literally zero out the MAF below a certain point and raise the idle up a few hundred rpm to get the velocity back up. All the sensors on today's cars are really sensitive to changes and things like this.
Old 04-14-2015, 03:12 PM   #8
AJcruz1's Avatar
6K mi. and zero problems with my BBK TB or my shorty headers
AJcruz1 is offline   Reply With Quote
Old 04-14-2015, 03:41 PM   #9
Do you want a cookie?
Old 04-14-2015, 09:32 PM   #10
Socal Stangman's Avatar
I don't think it's fair to say all of BBK stuff is crap. Some times you get a bad part, that's life. To say all their stuff is bad,I wouldn't agree with that at all.
Old 04-14-2015, 09:39 PM   #11
I don't like their headers and their throttle bodies don't seem worth the likelihood of hassle.
Old 04-14-2015, 09:54 PM   #12
iguanaman3's Avatar
Not liking is one thing but make stuff up to bad mouth them is not right. I have used the BBK 73mm throttle body for over a year and am quite pleased. It doesn't throw codes and I have never heard of that happening either. They use the same Ford electronics and drive so they are no more likely to go bad than stock and they give a definite boost in mid range power which is where the Cyclone needs it most.
iguanaman3 is offline   Reply With Quote
Old 04-14-2015, 10:14 PM   #13
I don't see where I made things up at all. I along with many around would not put BBK stuff on my car due to quality and problems. Seems like at least 3 or 4 times a month someone pops up with a problem pertaining to bbk.
Old 04-14-2015, 10:57 PM   #14
Lets just move on. His thread is not about bashing any product. Let's see if he could get some help. Thanks
Old 04-14-2015, 11:23 PM   #15
NewMtang's Avatar
Got any Oreos?
Old 04-14-2015, 11:25 PM   #16
To be fair he was getting help and ideas until you guys came in..
---------- Post added at 10:25 PM ---------- Previous post was at 10:24 PM ----------
Originally Posted by NewMtang View Post
Got any Oreos?
My pregnant wife does not let those hang around for long lol
Old 04-15-2015, 12:24 AM   #17
iguanaman3's Avatar
You are right. So I would say there is no chance those codes are from the BBK throttle body. He needs to look else where. Could be that some wire got damaged in the midpipe install.
Old 04-15-2015, 05:47 AM   #18
2011fastford's Avatar
Region: New Mexico
never heard of any body having issues with the bbk throttle body, a few here and there with shorty headers.. i've been running one on my car for about 30k miles.
2011 Mustang V6 auto/procharger p1sc kit with 3.70 pulley/circle d 3200 stall/4:10 gears/dss aluminum driveshaft/tial q bov/bbk long tubes with catted x pipe/dynomax ultra flo catback/bbk throttle body/accel super coils/cyclone ported upper and lower intake manifolds/brembo front brake kit
INSTAGRAM @2011fastford505
2011fastford is offline   Reply With Quote
Old 04-15-2015, 03:17 PM   #19
RomanG's Avatar
After removing BBK throttle body and resetting the codes and battery, both codes reappeared shortly after.
Might be a placebo, but oddly enough the car feels alot more sluggish. Not sure whats going on.
Will have to jack up the car and recheck the 4 sensors connected to the midpipe.
Old 04-15-2015, 03:19 PM   #20
After that it could be a voltage issue
Old 04-15-2015, 03:27 PM   #21
RomanG's Avatar
Where would that stem from?
Old 04-15-2015, 03:28 PM   #22
RomanG's Avatar
Where is that sensor even located on our 3.7?
From what i understand those 4 sensors on the midpipe are oxygen sensors if im not mistaken
Old 04-15-2015, 03:38 PM   #23
You are correct about the o2 sensors being on the midpipe. Let me look around a bit.
Old 04-15-2015, 03:49 PM   #24
Man I'm having a tough time tracking that down online lol
Old 04-15-2015, 04:29 PM   #25
RomanG's Avatar
Same here, apparently beamers have this problem more than anything.
Old 04-15-2015, 08:51 PM   #26
RomanG's Avatar
After doing a little bit of research i found the position sensor from motor craft. However im not sure if the Bank A sensor is different from the bank B sensor. (Doubt it)
However this sensor does not look familiar what soever and cant find it on the car. If anyone could possibly chime in with this.
Ive also been reading that its possibly failing due to a bad alternator. Apparently a failing alternator sends out high Ac waves affecting the sensor?
Will be looking for the location of the sensor in the meantime lol.
Old 04-15-2015, 08:54 PM   #27
I said alternator from the beginning lol
Old 04-15-2015, 09:03 PM   #28
RomanG's Avatar
Didnt see that lol, got distracted by the mentioning of cookies on my thread
Old 04-15-2015, 09:04 PM   #29
I would start there first. If you are going to buy a new sensor check out Rockauto. They have great prices
Old 04-15-2015, 09:08 PM   #30
RomanG's Avatar
Just found their website and it is pretty cheap. Im trying to find a schematic of the sensor layout on the engine, to dark here to try and find it.
Old 04-16-2015, 02:12 PM   #31
RomanG's Avatar
Update:
Spoke with Jared from Mpt (very helpful) about the revision of the tune. I am expecting the tune to be emailed today. I informed him of the problem that occured after i uploaded the tune. He said i will receive the tune today, to upload it and run te car for a bit to see if anything different happens. If nothing good happens i will be switching out to a new sensor. I believe i found thr location of them (back of the engine block)
Old 04-16-2015, 02:26 PM   #32
Update:
Did he say it could be tune related?
Old 04-17-2015, 08:44 AM   #33
AJcruz1's Avatar
Don't like there stuff then don't buy it. I simply stating my experience. Dick!
Old 04-17-2015, 12:08 PM   #34
That took awhile! Your cookies are already gone bro
Old 04-18-2015, 12:24 PM   #35
RomanG's Avatar
Edit: found the problem! After digging around the engine on my day off, i found the problem. One of the wires connecting to a camshaft sensor was ripped. Must of occured when changing out the midpipe. Removing this sensor involved removing the uppet manifold to make room behind the block. Wiring will be replaced today and and will update the results.
Help CEL codes Vazqueza90 1979-1995 Mustang GT 12 02-08-2015 10:57 AM
Smoking after O/r midpipe RollDat 2011-2014 Mustang GT 11 08-30-2014 01:47 AM
Help with CEL codes 96smoke 1996-2004 Mustang GT 7 03-20-2014 03:08 PM
CEL and 2 codes, need help Kevo91 1996-2004 Mustang GT 12 04-29-2013 01:39 PM
Problem - throwing CEL codes Eturner 1996-2004 Mustang GT 13 10-05-2012 03:56 PM
06:38 AM
