Rear view mirror rattle fix - Mustang Evolution
Old 04-15-2015, 12:25 PM   #1
Commercial Member
au01st's Avatar
So my rear view mirror has had a rattle for a while now. After my last rattle taking multiple trips to the dealer to get fixed I decided I could tackle this one myself. It wasn't just over bumps and gravel roads, even a smooth stretch with the tiniest imperfections would cause a high pitched rattle that I could hear over the exhaust, and after adding a 10" subwoofer to the trunk it only got worse. After lots of searching I decided on a course of action. The rattle comes from the mirror mount not being perfectly snug on the windshield, not the mirror housing itself. A YouTube video showed someone putting an elastic band up against the glass to keep it quiet. It seemed simple but I wanted something that you won't see.
I went to the hardware store in search of an o-ring and found the perfect size. Just cut it and work the ring around the mount. Silence! The mirror still shakes when the bass hits, but it doesn't rattle and you can't see anything out of the ordinary. $2 fix and my stereo sounds so much better!
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 04-15-2015, 12:33 PM   #2
Chaz12's Avatar
I think mine is rattling as well! I need to find out if it's the mirror or the dash though
2013 Premium Performance White
GT500 blue racing stripes with matching hash marks, cold air intake, Flowmaster super 44s with Roush tips, CDC performance grille, side scoops, painted white quarter windows
Last Mod: CDC Performance Grille
Next mod: Bama Race Tune!
Bama 91 Race tune, GT500 blue racing stripes with matching hash marks and side stripes, cold air intake, Flowmaster super 44s with Roush 4" Tips, CDC performance grille, side scoops, painted quarter windows, all lights tinted
Chaz12 is offline   Reply With Quote
Old 04-15-2015, 12:40 PM   #3
Commercial Member
au01st's Avatar
Hold the mount with your fingers or turn the mirror facing straight down when you hear the rattle. It was easy to isolate. With my mirror facing straight down the rattle was gone. If the o-ring hadn't worked my next step was going to be to remove the mirror and disassemble it to try and make it more quiet from the inside out. I wasn't looking forward to that task.
Old 04-15-2015, 02:25 PM   #4
Mustangs's Avatar
My mirror rattles but it's coming from the mirror surround not the base
Mustangs is offline   Reply With Quote
Old 04-15-2015, 08:59 PM   #5
Brandonb2012's Avatar
I need a way to make mine stay in place lol, my 12inch CVX doesn't give it a chance, I just learn to live without it haha
Brandonb2012 is offline   Reply With Quote
Old 04-15-2015, 09:10 PM   #6
Stangholio's Avatar
My mirror rattles too. Right now it's mainly on bumpy roads. If I grab the mirror the rattle stops. PITA
GHIGitty
Stangholio is offline   Reply With Quote
Old 04-15-2015, 09:25 PM   #7
Easy fix, take it off
Old 04-15-2015, 09:35 PM   #8
natestang07's Avatar
Or let it fall off... :p
Weight reduction though
Old 04-15-2015, 11:22 PM   #9
Commercial Member
au01st's Avatar
Yall really should give this a shot. At $2 if it doesn't work then oh well...
Old 04-15-2015, 11:41 PM   #10
Whitelightning's Avatar
Mine does this. I just touch it with my finger, silences it. I have foam glued to be back right now. But i will definitely try this
---------- Post added at 11:41 PM ---------- Previous post was at 11:40 PM ----------
+1
Old 04-15-2015, 11:46 PM   #11
I went like 3 months without mine. Don't realize how much you use it until you don't have it anymore. Then when you put it back on you don't realize how in the way it is.
Old 04-16-2015, 01:31 AM   #12
iguanaman3's Avatar
My 2012 coupe had an aftermarket rear view lcd mirror installed when I bought it. It also had an annoying buzzing sound at startup. It took a year but I found it was the switch on the mirror. It was loose and vibration would cause it to buzz. A piece of black electrical tape on the underside of the switch fixed it. What a relief.
iguanaman3 is offline   Reply With Quote
Old 04-16-2015, 07:05 PM   #13
tym_v6's Avatar
And the rear-view mirrors on our cars are HUGE...sometimes it feels like it's filling a quarter of my view...LOL.
Old 04-16-2015, 08:53 PM   #14
Diehard's Avatar
Just made a similar comment to the wife today. I have a GPS positioned on the dash just below the mirror.
Old 04-16-2015, 10:57 PM   #15
Depends. I wouldn't mind the regular size mirror and they move the microphone for sync. The base 2010-2012 had classic Style mirrors, then premium has the huge one. Either way, it's big, it rattles
Old 04-19-2015, 10:40 AM   #16
kozmo's Avatar
what did you use to "work the ring around the mount"? A flat screwdriver?
kozmo is offline   Reply With Quote
Old 04-19-2015, 11:48 AM   #17
Commercial Member
au01st's Avatar
My fingertip. Easier if you haven't cut your nails in two weeks.
Old 09-25-2015, 03:28 PM   #18
Rezzmatic's Avatar
Re:
I have this same issue on mine with about 15k miles on it. Took it to the dealer and he ordered a new mirror assembly for me. He's changing it as I sit at the dealership and type this post. My door lock grommets vibrate too when I have the bass up to about 70%. Does somebody else have this problem? It's extremely annoying to see this on a 30k car. Dealer says its normal with shaker systems (what!?!? ). I have a 10 year old vw Jetta with monsoon audio system which sounds amazing with no rattles or vibrations.
Rezzmatic is offline   Reply With Quote
Old 09-25-2015, 09:19 PM   #19
jayochs's Avatar
huh.. i wonder if i should go and ask about it for a replacement lol.
Sent from my XT1575 using Tapatalk
2014 Ford Mustang 3.7 Premium 6-speed:
MPT Performance Tune, AM Laguna Seca Black 19" Rims, Borla Touring Axlebacks, Boss 302 Strut Tower Brace, Airaid Modular Intake Tube, aFe Pro Dry S Air Filter, Mustang GT Grille w/ Foglight Mesh, Taillight Tint, Tinted Door Ventvisors, Diode Dynamics LED's
jayochs is offline   Reply With Quote
Old 09-25-2015, 10:54 PM   #20
Rezzmatic's Avatar
I got mine replaced today. I guess that's what the issue was- the old mirror assembly might have been broken/loose/faulty, somehow. Now it's perfect - no rattle. Do check in with your local dealer.
The door lock grommets still vibrate, btw and the dealer has no idea what to do.
Old 09-26-2015, 09:51 PM   #21
Originally Posted by rezzmatic View Post
i got mine replaced today. I guess that's what the issue was- the old mirror assembly might have been broken/loose/faulty, somehow. Now it's perfect - no rattle. Do check in with your local dealer.
super glue on the lock grommets
like bryl cream, a little dab will do you
ALLYDRIVER1 is offline   Reply With Quote
Old 09-27-2015, 09:43 AM   #22
Rezzmatic's Avatar
I'm going to try that today and post back.
Thank you!
Old 12-04-2017, 06:37 PM   #23
RobtRoma's Avatar
I know this is an old thread but thought I would post my thanks. I would have sworn my buzzy rattle was in the mirror housing. It would only stop if I gripped the mirror body. It wouldn’t stop if I tried pushing on the mount. But for $2.65 I figured it would be worth a try. Son of a gun, it worked. No more noise. Thank-you!
2010 Mustang GT Premium - Silver
2002 Escape XLT - Dk Highland Green
RobtRoma is offline   Reply With Quote
Old 12-08-2017, 03:56 PM   #24
WJBertrand's Avatar
I tired the o-ring idea and that did not work for my rattle. I was still under the warranty so my dealer replaced the mirror and the rattle is gone. In my case the rattle seemed to be inside the mirror housing. Funny story, the new mirror was upside down which made for some puzzling compass readings....
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Rear View Mirror Rattle DJwils08 2011-2014 Mustang GT 3 04-23-2013 11:02 AM
Removing rear view mirror bracket Fballman9 1979-1995 Mustang GT 6 11-09-2012 04:18 PM
2010 GT Rear view mirror camera jrny99 2011-2014 Mustang GT 2 03-15-2012 01:24 AM
12" light bar above rear view mirror, Help? imlucky369 1996-2004 Mustang GT 12 11-20-2011 03:50 AM
12:40 AM
