Wheel Size - Mustang Evolution
Old 04-16-2015, 03:42 PM   #1
BlackKnight92's Avatar
Wheel Size
What is the largest tires that i could run on the back? Stock rims, Stock ride height. I do have 1inch spacers on the back tho.
2012 Mustang V6
BlackKnight92 is offline   Reply With Quote
Old 04-16-2015, 03:57 PM   #2
Commercial Member
au01st's Avatar
Which stock rims?
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 04-16-2015, 04:04 PM   #3
Originally Posted by au01st View Post
Which stock rims?
They are the Pony Package ones, so 18inch iirc
2012 Mustang V6
Old 04-16-2015, 05:30 PM   #4
Commercial Member
au01st's Avatar
18x8. I think 255 is the widest you want to go. Even then, some tire manufacturers recommend 8.5" for their 255 width tires.
Old 04-16-2015, 05:32 PM   #5
Perfect, Thanks!
2012 Mustang V6
Old 04-16-2015, 05:57 PM   #6
Commercial Member
au01st's Avatar
What tires are you looking at?
Old 04-16-2015, 08:38 PM   #7
Diehard's Avatar
Looks like most tire mfrs recommend 8.5" wide rims as minimum for 255/40R18 but 8" min. for 255/45R18.
Apparently the profile has a bearing on it.
Old 04-16-2015, 09:34 PM   #8
Commercial Member
au01st's Avatar
That makes sense. Extra profile means extra rubber to flex in/out.
Old 04-17-2015, 07:43 AM   #9
Voltwings's Avatar
A 245 will bulge on an 8" rim and you'll be losing contact patch, ask me how i know. Just putting a bigger tire on a rim does not mean more grip, it just means you're wasting money on tread you're not using.
I promise a 235 will be the best tire on an 8" rim. When you put too big of a tire and the sidewall isnt situated properly it affects all aspects of the ride, turning and going straight. Just put the proper sized tire on there.
Also ... why do you have a 1" spacer on the rear, and do you have extended wheel studs? That is a massive spacer ...
Old 04-17-2015, 08:46 AM   #10
Yes i do have extended studs, they are the Eibach Spacers from AM
Eibach Pro-Spacer Hubcentric Mustang Wheel Spacers - 35mm - Pair 90.4.35.001.3 (94-14 All) - Free Shipping
2012 Mustang V6
what size rims and what size slicks for 2005 GT? inzain Mustang Wheels & Tires 3 11-30-2013 09:37 PM
Tire size and rim size 96gt Lios 1996-2004 Mustang GT 9 04-22-2012 11:33 PM
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 12:45 PM
97 v6 Wheel Size Kiljosh Mustang Wheels & Tires 17 11-10-2004 12:26 AM
NEED HELP with Wheel size Linkan Mustang Wheels & Tires 6 04-25-2004 11:00 AM
12:50 AM
