Do I need ramps and jacks for exhaust install? - Mustang Evolution
Old 04-16-2015, 10:21 PM   #1
dacm99's Avatar
Like it says, from all the videos I've seen, dropping the mid pipe makes the axle back install a lot easier. Has anyone dropped the mid pipe with jack stands in the rear only?
dacm99 is offline   Reply With Quote
Old 04-16-2015, 11:13 PM   #2
2011fastford's Avatar
Region: New Mexico
you dont need to drop the mid pipe to install axle backs... just take the stock mufflers off and put the new ones on.. ramps will give you plenty of height to do it... if you want it higher use jackstands
2011 Mustang V6 auto/procharger p1sc kit with 3.70 pulley/circle d 3200 stall/4:10 gears/dss aluminum driveshaft/tial q bov/bbk long tubes with catted x pipe/dynomax ultra flo catback/bbk throttle body/accel super coils/cyclone ported upper and lower intake manifolds/brembo front brake kit
INSTAGRAM @2011fastford505
2011fastford is offline   Reply With Quote
Old 04-16-2015, 11:32 PM   #3
VIG
VIG's Avatar
Region: Delaware
I just slid under my car and swapped the mufflers.
No ramps. No jack stands. No dropping the midpipe. I prefer doing the least amount of work possible. Dropping the midpipe is adding extra work.
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 04-16-2015, 11:37 PM   #4
Region: New Mexico
your probably not lowered lol
Old 04-17-2015, 06:34 AM   #5
Diehard's Avatar
I find these Harbor Freight Ramps come in handy. That's what I used for the axle backs.
ID:	180269   Click image for larger version
Old 04-17-2015, 06:52 AM   #6
sid719e's Avatar
^ That's exactly what I used. You can just push up on the over axle pipe to slide the mufflers out of the hanger brackets. No reason to drop the midpipe. Just try not to dislocate your thumb like I did. Those stock mufflers are heavier than they look.
sid719e is offline   Reply With Quote
Old 04-17-2015, 07:12 AM   #7
2014SGM's Avatar
Region: Mexico
It is easier when you drop the midpipes. Trying to keep the midpipe out of the way when sliding the mufflers on and off is a pain. It is only 2 bolts per midpipe, too.
2014SGM is offline   Reply With Quote
Old 04-17-2015, 07:16 AM   #8
dacm99's Avatar
Thanks everyone.
Old 04-21-2015, 12:38 PM   #9
sticks123's Avatar
It's WAY easier when you drop the mid pipe and ramps make it TONS easier also!! Tried it both ways!!
sticks123 is offline   Reply With Quote
Old 04-21-2015, 04:22 PM   #10
jayochs's Avatar
hahaah you were also a slim *** mofo.
i would never have been able to slip under there without ramps lol
and i didn't drop the midpipe. it's not hard to do, honestly. dropping the midpipe seems like such hassle just for these
2014 Ford Mustang 3.7 Premium 6-speed:
MPT Performance Tune, AM Laguna Seca Black 19" Rims, Borla Touring Axlebacks, Boss 302 Strut Tower Brace, Airaid Modular Intake Tube, aFe Pro Dry S Air Filter, Mustang GT Grille w/ Foglight Mesh, Taillight Tint, Tinted Door Ventvisors, Diode Dynamics LED's
jayochs is offline   Reply With Quote
Old 04-21-2015, 05:06 PM   #11
Blogger
99ford's Avatar
Dang that's impressive you must be skinny.
Old 04-21-2015, 05:24 PM   #12
natestang07's Avatar
The 3v must be higher in the back because I am a bigger guy and I was able to swap mufflers with the car on the ground no problem
Old 04-21-2015, 08:05 PM   #13
Blogger
99ford's Avatar
Old 04-21-2015, 08:08 PM   #14
VIG
VIG's Avatar
Region: Delaware
Lol, I'll take the compliment!
Old 04-21-2015, 08:15 PM   #15
Diehard's Avatar
And have short arms!
Old 04-21-2015, 09:50 PM   #16
alrefire's Avatar
Exactly what I did @stock height Haha
Old 04-21-2015, 10:16 PM   #17
Commercial Member
au01st's Avatar
Technically you could dig a hole and not need any ramps or jacks.
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 04-21-2015, 10:17 PM   #18
I have seriously considered doing this some times. A trench would make life so much easier.
Old 04-21-2015, 10:18 PM   #19
Commercial Member
au01st's Avatar
I'll let my signature line speak for itself, lol.
Dang, don't know if my signature shows up from my phone...
Old 04-21-2015, 10:19 PM   #20
It doesn't, just says sent from iPhone.
Old 04-21-2015, 10:20 PM   #21
alrefire's Avatar
Better idea.
Dig a hole and install a lift! Haha that's what coty did :p
Old 04-21-2015, 10:21 PM   #22
It's not me, it's you.
primer2tone's Avatar
Lol, I remember when raising my car was as easy as driving up ramps. And then coilovers happened. 😭
Old 04-21-2015, 10:21 PM   #23
dacm99's Avatar
So I finished install tonight. I started by just sliding under the car. Then that damn driver side gave me a hard time. Then I reached under and dropped the mid pipe. That got the muffler in but getting the mid pipe back in was even worse. So I stopped had two beers, got the jack and stands, lifted the SOB and wham, I was done. Driver side took about an hour and a half. Realizing the jack was the way to go I used it on the passenger side, and only loosened the mid pipe bolts. Muffler came right out, put the new one in and tightened everything up. Five full mins on passenger side. That included alignment.
Moral of the story, two beers are necessary equipment for completing the job.🍻
Old 04-21-2015, 10:26 PM   #24
dacm99's Avatar
I actually said out loud during the install, never dropping this car. We will see if I remember that comment.
Old 04-22-2015, 04:43 AM   #25
Strange Mud's Avatar
rather than removing the mid pipe I suggest removing the hangers from the car along with the oem ABs re-attaching them to the new ABs and rehanging everything. It was trying to get the mufflers onto the hangers when they were on the car that caused me to *%$#! I also had to break off the clamps where they were welded to the oems by that little tab.
Oh yeah, I used stands.
exhaust
Finally off the jacks!!! Stanglover1966 Pictures and Videos 19 04-19-2013 10:40 PM
Car Jacks - Caliper Cover Install Quikstang 2011-2014 V6 Mustang 3 08-06-2012 04:58 PM
How to: Epic Mustang ramps. DDTCM The Bar 15 06-17-2012 01:55 PM
Jacks, jack stands and late model Mustangs CurbRash General Mustang Discussion 18 04-29-2012 08:36 PM
Anyone else LOVE parking ramps? jimmy_beaner The Bar 6 08-20-2005 05:38 PM
06:22 AM
