Curious about wheel size - Mustang Evolution
Old 04-18-2015, 03:03 PM   #1
Really like the look of 20" wheels .... but how much do they affect performance? I have 19" wheels ,3:31 gears, on a performance pck and really like how she accelerates. Do you think going up in wheel size would make enough difference to feel like going back to standard size gears??
Ppkonablue12 is offline   Reply With Quote
Old 04-18-2015, 03:06 PM   #2
natestang07's Avatar
What size are you at now?
Old 04-18-2015, 03:20 PM   #3
19" on the car now.
Old 04-18-2015, 03:21 PM   #4
I doubt going from 19 to 20 would be very noticeable. Hopefully someone with a little more knowledge chimes in
Old 04-18-2015, 03:24 PM   #5
It depends on how much the 20 in wheels weighs compared to the 19 in, but probably not a noticeable difference. Another big deciding factor is the tires, if you use performance summer tires or all season conventional tires...
So wheel weight and tire type are the questions that need answers...
Adventure till you drop
Old 04-18-2015, 03:30 PM   #6
Right now I have the OEM PP 19" wheels ( don't know what they weigh) but I'm guessing aftermarket 20" might be lighter. I was thinking the larger circumference would be the biggest factor...
Old 04-18-2015, 03:32 PM   #7
It will effect your turning radius, now to a certain degree depends on what tire you use, in terms of a OEM tire for the 20in or a lower profile...
Or possible rubbing, depending on the suspension...
But in all honesty I think you'll be ok...
Old 04-18-2015, 04:27 PM   #8
Diehard's Avatar
When you mention comparing it to the performance that 3.31 gears provide, you imply that you are looking for the impact as the result of a change in tire diameter.
A change from 19" to 20" wheels does not affect the tire diameter.
Your existing tires are 255/40R19 (27" Dia) and your future tires could be 255/35R20 (27" dia) resulting in the same tire diameter or no impact on drive ratio change.
Just a change in appearance of tire profile.
Old 04-18-2015, 05:16 PM   #9
Ahh, thanks Diehard. That's what I wasn't understanding/realizing ... you can adjust via tires.
what size rims and what size slicks for 2005 GT? inzain Mustang Wheels & Tires 3 11-30-2013 08:37 PM
Tire size and rim size 96gt Lios 1996-2004 Mustang GT 9 04-22-2012 10:33 PM
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 11:45 AM
curious........ Thomas91169 The Bar 14 07-08-2004 10:52 PM
I'm curious about the horsepower of your cars wiarumas The Bar 22 08-04-2003 09:54 AM
07:48 AM
