Tuning?? - Mustang Evolution
Old 04-23-2015, 12:23 PM   #1
austin3.7's Avatar
Tuning??
So I'm currently sitting in my car loading up my bama tune for the first time and I noticed the lights on my gauges changed colors. The speedometer side is all yellow but tachometer starts at yellow by 0 rpms and then it gradually changes over to red once it gets to 8k rpms. Is this normal lol? Here is a pic to show you what I'm talking about. Click image for larger version
Name:	ImageUploadedByMustang Evolution1429813409.715874.jpg
ID:	180945Click image for larger version
Name:	ImageUploadedByMustang Evolution1429813431.745740.jpg
2013 Black Mustang 3.7, Pony package, cold weather package, Borla Ataks
austin3.7 is offline   Reply With Quote
Old 04-23-2015, 12:28 PM   #2
natestang07's Avatar
During tune quite the light show takes place lil
Old 04-23-2015, 12:30 PM   #3
Kevin.Cook
Guest
Posts: n/a
Yea. This seems normal. Mine fade from Green to Yellow.
Old 04-23-2015, 12:48 PM   #4
austin3.7's Avatar
I was just curious lol. I wish we could have control over the lights like that
Old 04-23-2015, 01:34 PM   #5
Site Sponsor
Originally Posted by austin3.7 View Post
So I'm currently sitting in my car loading up my bama tune for the first time and I noticed the lights on my gauges changed colors. The speedometer side is all yellow but tachometer starts at yellow by 0 rpms and then it gradually changes over to red once it gets to 8k rpms. Is this normal lol? Here is a pic to show you what I'm talking about. Attachment 180945Attachment 180946
Austin - Enjoying the party? Just sit back and it'll be loaded up soon!
Just to make sure did you have your firmware updated before having the tune loaded?
Let me know if you have any questions and if you're to need an answer on anything immediately don't hesitate to shoot the Bama Team a call directly!
Enjoy!
Alex
Toll Free: 1-866-363-4591
Free Same-Day Shipping!
Old 04-23-2015, 01:40 PM   #6
austin3.7's Avatar
Enjoy!
Alex
Yep I made sure to update the x4 before I loaded the tune. Honestly I'm not that impressed by the tune and I loaded the 93R tune
Old 04-23-2015, 01:44 PM   #7
You have to drive awhile and the idle has to relearn
Old 04-23-2015, 01:54 PM   #8
Sterlingbeast5.0's Avatar
25 to 50 miles should be good. I reset the KAM about every 2-3 weeks FYI
Old 04-23-2015, 01:57 PM   #9
austin3.7's Avatar
Why do you reset your tune every few weeks?
Old 04-23-2015, 03:03 PM   #10
MustangDawg's Avatar
And how do you reset the KAM?
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Old 04-23-2015, 03:04 PM   #11
Site Sponsor
Hey Austin - Nate and Sterling are right on the money here and this will need a few miles to learn. Most if not all thoughts right after having it loaded up are pretty close to what you're saying - It's a mental game but give it some time and I'm sure you'll be pleasantly surprised. I would also suggest having Bama Datalog your tune after a hundred miles or so in order to have you dialed in further.
Good question here and to be transparent about this I do not suggest resetting KAM for any reason. Bama is going to suggest doing the opposite after flashing the vehicle. Resetting the KAM returns the powertrain control module memory to its default setting including all adaptive learning contents such as idle speed, refueling event, and fuel trims are included. Clear the continuous diagnostic trouble codes (DTCs) in the PCM and reset the emission monitors information, is part of a KAM reset and may prevent any issues from surfacing. After the KAM has been reset, the vehicle may exhibit certain driveability concerns. It is necessary to drive the vehicle to allow the PCM to learn the values for optimum driveability and performance.
Let me know if you have any questions about this guys!
Alex
Old 04-23-2015, 03:28 PM   #12
Jon3.7's Avatar
So basically, Alex says fffffffffuuuuuuuuuuuuuuuuuuuuuuuuu
hahahahaha
2013 GT, A6, VMP Tuned, Lethal O/R H pipe, GT500 Mufflers
2016 EB, A6, Steeda Tuned, Steeda CAI
Jon3.7 is offline   Reply With Quote
Old 04-23-2015, 03:41 PM   #13
After months of fighting to tune or not to tune i took the chance with a Steeda cai and bama tune. i plugged in the tuner and i get error code 10020. American muscle says to call SCT. WTF.. maybe i shouldnt have done this. Now on hold for a half hour.
buddyrich14 is offline   Reply With Quote
Old 04-23-2015, 04:06 PM   #14
That is an sct device problem not a Bama problem. Could happen with any tuner
Old 04-23-2015, 05:24 PM   #15
Finally got it. Used the 91 performance tune. May go to the race tune instead though
---------- Post added at 07:24 PM ---------- Previous post was at 07:24 PM ----------
Any feedback guys*?
Old 04-23-2015, 06:11 PM   #16
Any feedback guys*?
Did the error code say anything besides the number?
Old 04-23-2015, 06:28 PM   #17
I dont redo tune per say just reset KAM. It is under spefial function for 2005 and up. The computer relearns and for lack of better words starys to work against the tune. That clears memory and starts back fresh. I know not very technical but hoping someone can explain technically better.
Old 04-23-2015, 06:30 PM   #18
So alex i misunderstood? I was told it is the equivalent of a 47 fuse pull and it should be done every so often? Please let me know
Old 04-24-2015, 07:32 AM   #19
Voltwings's Avatar
Well, he's right. The tune will learn your throttle habbits, will learn fuel trims - both DD and WOT- can fiddle with how the auto shifts ... If you reset this every so often, the computer has to re-average fuel trims again, re-average throttle tables, shift tables, etc. I'm not saying a tune should ever be set it and forget it, you should still log periodically, but basically starting from scratch every few weeks isnt exactly "ideal."
Old 04-24-2015, 09:19 AM   #20
Site Sponsor
hahahahaha
No way Jose! I've been working with Sterling/Naples for almost a year now and never in my wildest dreams would we/I say anything like this to a AM and Bama advocate - This guys got a sick car and he's a familiar face around here! I just wanted to give Bama's take on this as there's some varying opinions on this, that's all!
Hey Buddy - Sorry to hear about the trouble there but I’m happy to hear that SCT was able to get you set up. I typically suggest getting your feet with with the performance tune. Get acclimcated, find out what you like or don’t like (They can datalog with you to have your tunes dialed in further) and then once you’re ready switch over to the Race Tune and enjoy!
Alex
Any feedback guys*?
Sterling - Depending on what tune you're running Bama will modify what can be learned and just how far these adjustments can go - Bama will modify what is learned and how aggressive the learned adjustments can be and at time they'll turn off the learning. But the Bama team does not typically suggest pulling 47 or doing this - Just like Volt said below it's not typically ideal.
Let me know if you have any other questions!
Old 04-24-2015, 09:56 AM   #21
Jon3.7's Avatar
Well the programmer should be at the house when I get home, I'm gonna load it up and head to the track so see what she'll do..
Alex, or anyone here, can I run 93s do the track, and 93r on the track or will it not be enough time on the tune?
Old 04-24-2015, 09:57 AM   #22
Jon3.7's Avatar
I know, I just thought it was funny. aka a joke lol
Old 04-24-2015, 12:20 PM   #23
Voltwings's Avatar
You can switch tunes at the track, just give it a few passes to really show what it will do. Just throw whatever you want on there now and you'll be fine.
Old 04-24-2015, 01:55 PM   #24
Jon3.7's Avatar
Well she's at a quarter tank of fuel now, by the time I get down there it should be low enough to put some 93 in there
Old 04-24-2015, 02:01 PM   #25
Site Sponsor
Just making sure Jon - If you've seen me around here you'll know that I absolutely do not have a sense of humor or joke around...I'm all business...
Just like Volt said below you "can" switch back and forth but it's going to take a couple passes to get used to the throttle response on the race tune. It's pretty aggressive but you'll get acclimated to it very quickly. Keep us in the loop on how everything works out and have fun!
Alex
Old 04-24-2015, 02:18 PM   #26
Jon3.7's Avatar
We'll see how this 17k mile car will do haha. I think im gonna do stock first run then run on 93r
Old 04-24-2015, 05:13 PM   #27
So many acronyms!
sjd312 is offline   Reply With Quote
Old 04-26-2015, 04:10 AM   #28
This is awesome. Yes Alex, Will... Everyone there is amazing and helpful. I will not be resetting the KAM anymore. Ordered 3 more parts while out of country lol. Thanks guys back in town week from monday cant wait to get some more on. Thanks to AM and akk the helpful people on ME
Old 04-26-2015, 08:45 AM   #29
Jon3.7's Avatar
I guess i am the only one who has had issues with their bama tune lol.
Just put rouch axle backs on it and the wife likes it, so i guess she's happy lol
Old 05-10-2015, 10:42 AM   #30
Hampton CIT's Avatar
I have to say if you could pick the color of the dash lights via tuner that would be awesome!
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
TPS Tuning Kiljosh Pre-2005 V6 Mustang 12 01-30-2005 12:15 PM
FORDCHIP tuning in CALI! READ!! Autobadges.com Regional Mustang Discussion 2 08-26-2004 10:52 AM
Mustang Tuning 98VroomVroom Mustang Wheels & Tires 0 03-28-2004 05:46 PM
SCT Tuning Day 4/24-25 in Bristol, CT!!! BlueDonkey Regional Mustang Discussion 2 02-19-2004 08:35 AM
Superchip Custom Tuning stangin99 Pre-2005 V6 Mustang 0 10-22-2003 09:00 PM
06:03 PM
