Breaking Into 12's - Mustang Evolution
Old 04-28-2015, 03:26 PM   #1
RaceRed3.7's Avatar
Breaking Into 12's
So since Ive started going to the drags more and more Ive gotten addicted.. After besting many cars I thought were faster such as a Evo(Not sure what year) on 28pounds of boost and countless v8's (2007 GT longtubes, tune, stock 355's. Charger, Challenger.. Etc.) Im stuck in the low to mid 13's. What can I do to get closer or into the 12's?? I have tried 275's and different tires and It made my time slower, which I was surpriced! Please post any thing that you think would help me get to my goal. All the stuff I have is in my sig. Please dont say forced induction lol. Thanks!
-SOLD-13.246s@107.81 RaceRed 2013 v6 Mustang, 3.73 gears, MPT 91Race Tune, Axle-Back Straight Pipe, Tower Brace, BMR LCA's, BBK Shorty Headers, BMR Relocation Brackets, Lethal Performance X-Pipe Catless.
-2008 Civic SI...
RaceRed3.7 is offline   Reply With Quote
Old 04-28-2015, 04:10 PM   #2
Kevin.Cook
Guest
Posts: n/a
maybe work on getting your car's center of gravity lowered. Lowering springs and some better shocks and struts to match the damper. Ever thought about a TLOK? Do you experience alot of wheel spin at take off?
Old 04-28-2015, 04:11 PM   #3
Location: Camp Pendleton North (San Clemente/Orange County
Maybe 4.10 gears? With those sticky tires it might help utilize the grip better,
more advanced timing on your tune
Look up ecu tuning online and read up books, learn about angular timing ect to double check your tune
Nitrous
Rear seat delete if you havent already
Look up fiberglass molding and rebuild your body panels with carbon fiber (its actually not too hard ive done it)
Get an ecomodder.com account i got one for electrical engineering interest but learned a lot of the things they do help lower air resistance and reduce drag
Rear wheel wheel covers much like on the weird looking civics
Boat tail rear end, its ugly as hell but significantly reduces drag,
Cut out your a/c
Remove all accessories ie drag on the engine
Get carbon fiber doors and trunk
Calculate to make sure youre power to tire ratio is good for what youre aiming for
Theres a ton you can do its mostly up to what youre willing to sacrifice in most cases weight reduction and drag reduction are amazingly helpful most people dont think of them as much as they do for gears an hp but much more comes into play, but weight and drag reduction make your car less comfortable and especially with the boat tail ugly as ****
Sent from my SM-G900P using Mustang Evolution mobile app
swhitfield2013 is offline   Reply With Quote
Old 04-28-2015, 04:36 PM   #4
3.7batmobile's Avatar
Aluminum driveshaft
2012 3.7 Mustang; GT500 Axlebacks, 401A GT Shift Knob
3.7batmobile is offline   Reply With Quote
Old 04-28-2015, 04:47 PM   #5
Voltwings's Avatar
just pull the interior. Usually front and rear seats and trunk crap is worth 100 lbs or so
Old 04-28-2015, 05:02 PM   #6
RaceRed3.7's Avatar
How much do you think that should take off? .1 Or less?
-2008 Civic SI...
Old 04-28-2015, 05:03 PM   #7
RaceRed3.7's Avatar
Originally Posted by 3.7batmobile View Post
Aluminum driveshaft
Thats on my list for when i make booku bucks lol
-2008 Civic SI...
Old 04-28-2015, 05:30 PM   #8
oxford5pointoh's Avatar
Remove your spare, rear seat, and get the drive shaft.
Old 04-28-2015, 05:40 PM   #9
IIRC, every 100lbs is worth about a tenth.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 04-28-2015, 05:44 PM   #10
RaceRed3.7's Avatar
Damn thats a good deal! Ill try to do that and then brake boost my way to the 12's. Ill try it this friday hopfuly if weather and work permit it.
-2008 Civic SI...
Old 04-28-2015, 05:54 PM   #11
alrefire's Avatar
Nitrous
Cut out your a/c
Nitrous
Cut out your a/c
Good advice. But that would be the last thing he'd want to do at this point.Those are "race car" parts, for lack of a better phrase.
I apologize in advance if the OP already has some of this stuff done, I can't see your signature on my phone :p
I think you should start out with all the bolton mods (if he plans on staying NA, port your intake manifold, and focus on suspension.
Everyone loves to talk about engine mods, but they ignore suspension.
Lowering the car (springs only) will kill your 60 foot and make you slower.
Your pinion angle and lca angle will be way off...
As far as suspension goes, I'd recommend
-A good set of struts/shocks (koni yellows, for example)
- Set of springs, but nothing too low (too low will kill your 60 ft)
-lcas with relocation brackets
- uca with relo bracket (I personally prefer a torque arm. But most people don't know what it is, and don't want to spend 1k on it.)
-phb will center your rear axle after you lower it
The list goes on and on, but that's a good starting point for suspension.
My best advice that I can give you is don't be cheap. An overwhelming number of mustang owners love to do stuff the cheap way, and it does nothing but hurt them in the long run. Look into it before purchasing, and ask lots of questions
Good luck! Hopefully you'll get into the 12s soon!
Old 04-28-2015, 05:54 PM   #12
alrefire's Avatar
Lcas w/relo brackets
Old 04-28-2015, 05:55 PM   #13
Senior Member
Otroo's Avatar
Just spray her.
Otroo is offline   Reply With Quote
Old 04-28-2015, 06:28 PM   #14
Aluminum driveshaft
Aluminum drive shaft on the v6 actually only drops a couple pounds an isnt much if any smaller its not actually a performance mod but a safety mod
Old 04-28-2015, 06:55 PM   #15
Voltwings's Avatar
100 lbs is usually good for .1 to .2, but when you're reaching the limit those are your gains, gets harder to shave off time.
Old 04-28-2015, 07:00 PM   #16
Would be easier to help if we saw some time slips so we can see where you need improvement......................................................
Old 04-28-2015, 07:06 PM   #17
Ya im not big on drag racing im more of a drifting and track type, but as for drag you can actually gain 6mpg with rear wheel covers, not sure what that translates to in acceleration if anything but thats just a minor change gutting the car would be good
Ive got a buddy hes big into drag racing out here his car looks like they didnt finish building it from the factory cause there is literally nothing inside it except a few extra bars and one seat haha the weight reduction and suspension mods are a good bet
Although as said before as you reach the pinnacle of your performance even drastic mods wont change your time much
Or go balls deep an drop custom twin turbos lmao
Old 04-28-2015, 07:08 PM   #18
Not sure if iy will actually help but i heard from a buddy he completely took off the intake on his accord to make it faster said he gets better power 😂 you could try that go straight throttle body to the open air haha
Old 04-28-2015, 07:15 PM   #19
That is by far the most retarded thing you can do to the car.
Did he actually take the intake off or did he go ITBs? (Independent Throttle bodies).
Old 04-28-2015, 07:19 PM   #20
Voltwings's Avatar
lol right, **** the MAF, weight reduction. Unless it was speed density tuned, but umm... i doubt that.
Old 04-28-2015, 07:20 PM   #21
I doubt pulling an intake and pulling in hot air right by the TB is going to increase HP. The only way that is really going to work is if its turbo in which case you would have a filter right off the turbo but its canceled because the air goes through the intercooler.
And to the OP, when you had your stock tires were you spinning much? If not it may help to put the stock 225 tires on. Adding heavier/ wider tires is going to slow the car down unless you have traction issues.
StarzTA17 is offline   Reply With Quote
Old 04-28-2015, 07:28 PM   #22
Voltwings's Avatar
or put the stock tires back in the front, a cheater bigs and littles set up
Old 04-28-2015, 08:03 PM   #23
RaceRed3.7's Avatar
Ya next time I buy tires im gonna go 225 55 17. I have stock 215 65. I had 275 35 18 and they sucked for some reason..
Just sold my whole 275 on 18s setup due to lateral force being to high because of the rim not being fully round. Could really feel the vibrations last 70.. Sucked! Only out $40 though so no biggie
-2008 Civic SI...
Old 04-28-2015, 08:05 PM   #24
alrefire's Avatar
Maf, O2 sensors, and knock sensors all make excellent paper weights according to my old tuner
Old 04-28-2015, 08:08 PM   #25
VIG
VIG's Avatar
Region: Delaware
How do you calculate that ratio?
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 04-28-2015, 08:09 PM   #26
Check the specs on the Roto girder also while your under the hood prepping it to run straight throttle body. Lol
Old 04-28-2015, 11:19 PM   #27
2011fastford's Avatar
Region: New Mexico
too many things factor into this....
1. where are you located? DA plays a big part in track times out here in New Mexico a full bolt on tuned V6 won't break into the 13's
2. Stickey tires and 15x10's... if your a stick car... a bias ply will work well 28x10.5-15 if your an auto car you will be good with DR's something like ET streets
3. work on getting a good 60ft thats key..
2011 Mustang V6 auto/procharger p1sc kit with 3.70 pulley/circle d 3200 stall/4:10 gears/dss aluminum driveshaft/tial q bov/bbk long tubes with catted x pipe/dynomax ultra flo catback/bbk throttle body/accel super coils/cyclone ported upper and lower intake manifolds/brembo front brake kit
INSTAGRAM @2011fastford505
2011fastford is offline   Reply With Quote
Old 04-29-2015, 06:56 AM   #28
RaceRed3.7's Avatar
I live in Oklahoma, I really want some daily driver wheels that are good for both drags and street. Big tires seem to be the best option; I mean the wall not the width. It seems the thicker the tire the better. I tried a wide tire and it was terrible!(275-35-18) I wanna try 15's with big tires seems like it would help a ton!
-2008 Civic SI...
Old 04-29-2015, 07:37 AM   #29
So big question is.... what are your 60' times currently?
Old 04-29-2015, 07:58 AM   #30
RaceRed3.7's Avatar
2.077 was my best with stock wheels. Going back this weekend to try and master it with the stock wheels by using proper brake boosting hopefully it works out! Gonna be tricky.
-2008 Civic SI...
Old 04-29-2015, 08:01 AM   #31
Voltwings's Avatar
Brake boosting? You look to be all motor, so i can tell you it wont work, but I tried this on my Fiance's auto:
3.73 gears, 275 nittos, LCAs and brackets, PHB, her car was set up right, and i'd leave off idle, stage to 1500, 2000, 2500 ... no difference, 2.0x 60' every time. I dont think the stock converter is going to let you get off the line much harder than you are now.
Old 04-29-2015, 08:07 AM   #32
RaceRed3.7's Avatar
3.73 gears, 275 nittos, LCAs and brackets, PHB, her car was set up right, and i'd leave off idle, stage to 1500, 2000, 2500 ... no difference, 2.0x 60' every time. I don't think the stock converter is going to let you get off the line much harder than you are now.
Got ya! Thanks! So its best just to floor it when Its about to turn green
-2008 Civic SI...
Old 04-29-2015, 08:14 AM   #33
Voltwings's Avatar
pretty much, at least in my experience. Look into MPT's E85 tune if you have that option, we ran it on Valerie's car at the road course and there was a noticeable torque increase. Not so much HP gain, maybe 5-7, 10 at BEST, but the midrange was much fatter. May make getting off the line a bit easier, and it looks like thats where most of your time to gain is.
E85 also runs significantly cooler, so it may keep you more consistent throughout the night.
Old 04-29-2015, 08:25 AM   #34
RaceRed3.7's Avatar
I remember seeing a post about this. Is it a half half blend or what? e85 is everywhere around here. I just can't datalog for MPT so if I am required to I don't have a laptop :/ Honestly though I would not have any problem running e85 on the daily. Sounds like a good route to go, Ill look into it a bit more.
-2008 Civic SI...
Old 04-29-2015, 08:28 AM   #35
Voltwings's Avatar
Yes, it runs 50/50. Best of both worlds, in that 93 has more BTU (power potential) than e85, but e85 obviously has much higher knock suppression. I'd try to meet up with a local and maybe datalog with their computer?
Anyone seen Breaking Benjamin in concert? Brent The Bar 5 09-24-2005 07:17 AM
Breaking News: Michael Moore is running in 2008 Brent The Bar 25 09-11-2005 02:07 PM
Omfg Breaking News! Seph The Bar 4 04-05-2005 08:22 AM
"Breaking it in" Exit_In_Red Pre-2005 V6 Mustang 29 11-10-2004 12:48 PM
06:58 PM
