Adjustable Upper Control Arm Needed? - Mustang Evolution
Old 04-28-2015, 11:05 PM   #1
Harm_3.7's Avatar
So I have a SR springs, a one piece driveshaft, and purchased BMR lower control arms with relocation brackets. My questions is I purchased a BMR non adjustable upper control arm as well but will need to get the adjustable one? Is it really needed to get that one for will non adjustable one be fine?
Harm_3.7 is offline   Reply With Quote
Old 04-28-2015, 11:57 PM   #2
Adjustable is best so you can adjust the pinion angle, especially since you have the one piece driveshaft.
Old 04-29-2015, 12:59 AM   #3
Harm_3.7's Avatar
Will I need to do the pinion angle adjustment?
Old 04-29-2015, 01:25 AM   #4
Yes
Teak 14 is offline   Reply With Quote
Old 04-29-2015, 11:41 AM   #5
Diehard's Avatar
Do the LCA relocation brackets adjust the pinion angle as well? But perhaps not as good as the screw adjustment on a UCA??
Or do the LCA relocation brackets only correct the LCA angle?
Old 04-29-2015, 12:20 PM   #6
Commercial Member
au01st's Avatar
LCA brackets correct LCA angle and keep power going to the ground after lowering.
UCA adjusts pinion angle.
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 04-29-2015, 12:28 PM   #7
Commercial Member
au01st's Avatar
Old 04-29-2015, 03:58 PM   #8
Diehard's Avatar
Thanks!
That's an excellent video. I came across it while searching for replacing 2 pc DS with 1 pc and the need to correct pinion angle.
I'm surprise that with all the talk about changing DS's, there's never much if anything said about checking the pinion angle when changing type of DS.
Old 04-29-2015, 05:17 PM   #9
iguanaman3's Avatar
I believe pinion angle must be adjusted after lowering you car not from changing driveshafts. Changing driveshafts won't effect pinon angle, but lowering does.
iguanaman3 is offline   Reply With Quote
Old 04-29-2015, 08:35 PM   #10
Diehard's Avatar
In addition to lowering requiring pinion angle correction, everything I find on the subject says that there's a different pinion angle recommended for a 1 piece vs. a 2 piece D.S.
EDIT: On the other hand Shaftmasters Product Description on 3.5" Mustang Aluminum Drive shafts includes a statement, "No need to adjust pinion angle from Factory OEM setting".
For Sale: J&M Adjustable Upper Control Arm 08Mustang Mustang Parts for Sale and Wanted 7 05-12-2015 08:02 AM
Adjustable upper control arm pinion angle? UrMaster 2011-2014 Mustang GT 8 05-01-2015 11:25 AM
Whiteline adjustable rear upper control arm adjustments? 515roushtvs5.0 2011-2014 Mustang GT 4 01-02-2015 06:03 PM
SR rear control arms Adjustable & Non-Adjustable mooseruler Mustang DIY and Technical 10 12-17-2014 08:27 PM
For Sale: Bmr upper control arm, lower control arms and relocation brackets blacked out gt Mustang Parts for Sale and Wanted 26 05-30-2014 09:04 AM
06:40 AM
