Eibach Sportline Springs - Mustang Evolution
Old 04-29-2015, 01:01 PM   #1
5pointYoBro's Avatar
If you have these springs, would you mind posting some pics of what it looks like on a V6.
Most pics on AM are of GT's.
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
5pointYoBro is offline   Reply With Quote
Old 04-29-2015, 01:41 PM   #2
Kevin.Cook
Guest
Posts: n/a
Also, some experiences after getting them added. Such as did any other suspension NEED changed.
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Old 04-29-2015, 01:43 PM   #3
DiESeven's Avatar
Eibach Mustang Sportline Spring Kit - Coupe & Convertible 4.12535 (11-14 GT, V6) - Free Shipping go browse through the customer photos. there's a few v6s in there.
Old 04-29-2015, 01:48 PM   #4
Site Sponsor
Hey Lava - Managed to find one for ya!
Alex
Toll Free: 1-866-363-4591
Free Same-Day Shipping!
Old 04-29-2015, 02:03 PM   #5
Im confused as to what you mean haha?
I plan on adding with the springs...
Eibach shocks/struts
Adjustable panhard bar
Front and Rear Sway Bar
Rear Lower Control Arms with relocation brackets
Rear Upper Control Arm with relocation bracket
J&M Caster Camber Plates
Old 04-29-2015, 02:30 PM   #6
Whitelightning's Avatar
Instead of people saying springs and pan hard bar only, it needs to be springs, panhard bar, and upper control arm.
You don't need caster plates unless you're tracking the car or you're going past 1.5" in the front. Eibach is a rough 1"
Old 04-29-2015, 02:34 PM   #7
Kevin.Cook
Guest
Posts: n/a
Well, i mean for other people that plan on getting other mods done. I am trying to see where i need to allocate funds. Like, spend all of it on the entire suspension, or get springs, shocks, struts, headers, and gears.
Old 04-29-2015, 03:18 PM   #8
So I can just go with the camber bolts instead of CC plates??
Im getting the
Eibach Sport System Plus
BMR adj. panhard bar
Whiteline adj. upper control arm w/ mount
BMR lower control arms with relocation brackets.
and now Caster Camber Bolts instead of plates.
Old 04-29-2015, 03:20 PM   #9
Forsure get some gears, like 3:55 or 3:73.
i got 3:55 and it changed my car completely. Accelerates like a beast now, unlike the 2:73s
But i think you need to adjust the lower control arms when you lower your car. Thats why im just replacing both the upper and lower control arms at the same time
Old 04-29-2015, 03:44 PM   #10
Harm_3.7's Avatar
Im getting the
Lava I'm pretty sure you have everything there to lower the car and I think down the road to upgrade shocks and struts because they will go bad faster than when your on the stock height.
Harm_3.7 is offline   Reply With Quote
Old 04-29-2015, 08:29 PM   #11
Im getting the
I wouldn't do whiteline unless it's their watts link. I've seen multiple times that the thing just falls apart or separates the bushing. BMR or SR
Old 04-29-2015, 08:31 PM   #12
My shocks and struts went out at 110,000 miles on stock suspension. The front groans horribly, the rear just leaked. I'm still piecing the stuff together. If you make it far enough, around the first of the year Joni has a huge sale on their stuff. I picked up my stuff for $250 all corners
Old 04-29-2015, 08:37 PM   #13
Harm_3.7's Avatar
I'm still on stock shocks and struts and I'm at 50K. SR springs are what I have been running for like 15k and honestly the stock shocks are still holding up.
Old 04-29-2015, 09:01 PM   #14
Harm3.7-- The sport system plus comes with eibach shocks and struts
Whitelighting-- Alright, I'll stay with BMR on both upper and lower control arms.
When and where is this sale?????
Old 04-29-2015, 09:25 PM   #15
Do I need adjustable control arms on either the upper or lower?
Old 04-29-2015, 09:42 PM   #16
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Lower shouldn't need to be adjustable. Upper is highly recommended, especially if you're going to install a one piece driveshaft later down the road.
2012 Kona Blue 3.7L V6:
Old 04-29-2015, 09:47 PM   #17
Harm_3.7's Avatar
Oh well your set then and for the upper control arm get the adjustable one I made a thread about this last night which you can read up.
Old 04-29-2015, 10:04 PM   #18
I have a one piece driveshaft, so i forsure get an adjustable upper control arm.
Thanks for the heads up
Old 05-05-2015, 11:00 PM   #19
Mean14's Avatar
Whiteline fell apart with the old design. I believe they have updated since then after getting a couple complaints.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 05-09-2015, 11:12 PM   #20
What is this I hear of caster bolts breaking?
Do I need these for a 1.1" drop in the front?
Old 05-10-2015, 01:27 AM   #21
Harm_3.7's Avatar
I have a 1.5in drop in the front and didn't even need caster bolts. My front wasn't even that out of alignment when I got it done.
Old 05-10-2015, 11:33 AM   #22
Guess I'll cross that out off of the list then haha.
What springs are you on??
Old 05-10-2015, 01:15 PM   #23
Harm_3.7's Avatar
Running the SR springs
Old 05-10-2015, 02:10 PM   #24
Socal Stangman's Avatar
Do you mean camber bolts?
Old 05-10-2015, 07:33 PM   #25
sunnytan06's Avatar
I do like the 1.5 inch drop on sr over the sportline. However eibach after all is a very good suspension company. I'm just curious if the quality of eibach will be better than sr
sunnytan06 is offline   Reply With Quote
Old 05-10-2015, 07:40 PM   #26
Mean14's Avatar
I have a buddy who installed SR performance springs on his v6 and claimed it dropped 1.3" all around. I believe the GT drops a bit more due to it being a bit more heavy. Where as the sportline drops the v6's 1.1" in front and 1.7" in the rear.
Old 05-10-2015, 07:55 PM   #27
sunnytan06's Avatar
Yeah I'm looking for a bigger drop. So let say sr drop 1.5 all round ( from AM) I probably will be happy with the height but I'm worry about the quality. After all I still looking for performance upgrades
Old 05-10-2015, 08:03 PM   #28
Yee
Old 05-10-2015, 08:03 PM   #29
Mean14's Avatar
I've heard nothing but good things about SR from the people who have them. The only reason I got sportlines is because it drops the rear more and evens out the ride. Anddddd I picked up a brand new set for $140 I was going to buy SRs until I found those.
Old 05-10-2015, 08:04 PM   #30
Exactly. I just like the extra drop in the rear for the sportlines.
***Post some pics of your drop if you can***
Wish I could put sportlines in the rear and sr up front lol
Old 05-10-2015, 08:06 PM   #31
Kevin.Cook
Guest
Posts: n/a
Buy both sets and sell the unused springs.
Old 05-10-2015, 08:08 PM   #32
Yeah I guess someone would buy the extras cheap off craigslist from me
Old 05-10-2015, 08:09 PM   #33
Mean14's Avatar
I haven't installed anything yet. I'm waiting for my UCA/mount before I install all the goodies. I will post a separate thread when I complete it though.
Old 05-10-2015, 08:29 PM   #34
Harm_3.7's Avatar
This is how my car looks with the SR springs. (Ignore that terminator in the back lol)
Name:	ImageUploadedByMustang Evolution1431311289.721544.jpg
Old 05-10-2015, 08:30 PM   #35
Harm_3.7's Avatar
I just did upper and lowers this last week and buddy you will love your car so much more. Wheel hop/traction problems are no where to be seen now!
eibach sportline springs with 20's formulaDstang 2011-2014 V6 Mustang 0 06-16-2013 11:44 AM
eibach sportline springs Doe_Rae_mi 1996-2004 Mustang GT 3 05-29-2013 06:02 PM
Eibach sportline lowering springs Pimman 2005-2010 Mustang GT 19 01-04-2013 11:12 AM
Eibach sportline springs Doe_Rae_mi 1996-2004 Mustang GT 12 12-13-2012 04:57 PM
Eibach Sportline Springs sonic04edge Mustang Parts for Sale and Wanted 12 06-26-2005 09:22 AM
05:48 PM
