Whiney gears - Mustang Evolution
Old 04-29-2015, 01:27 PM   #1
austin3.7's Avatar
Whiney gears
Does anyone else's gears seem to whine when you drive? It's so loud and very noticeable if the music isn't on.
2013 Black Mustang 3.7, Pony package, cold weather package, Borla Ataks, Bama 93R tune
austin3.7 is offline   Reply With Quote
Old 04-29-2015, 01:39 PM   #2
Harm_3.7's Avatar
I had gear whine when I got my 3.73s installed but took it back to the shop and they fixed it. I could only tell I had whine when I installed my one piece driveshaft so the two piece is kind of forgiving to the whine I would guess. Are you running aftermarket gears or are they the stock ones?
Harm_3.7 is offline   Reply With Quote
Old 04-29-2015, 01:43 PM   #3
austin3.7's Avatar
I bought my car preowned to I really have no idea what gears I have lol.
Old 04-29-2015, 02:07 PM   #4
tym_v6's Avatar
Whine on accel or decel? I have a bit of decel whine that isn't bad. If you have accel whine that's definitely coming from the gears, that isn't normal... might suggest previous owner had a botched gear install.
Old 04-29-2015, 02:10 PM   #5
austin3.7's Avatar
They whine only while my foot is on the gas. Once I take my foot off of the gas the whining pretty much stops
Old 04-29-2015, 02:22 PM   #6
Whitelightning's Avatar
That's the drive side of your ring gear. The backlash wasn't adjusted properly. Probably too tight.
Old 04-29-2015, 02:28 PM   #7
I'll teach you guys basic terms so you know what to ask or look out for. I do gears on 8.875's, father has two chevelle a I've set up.
Backlash is the space between the ring gear and pinion gear. Provided the pinion depth is set correctly, then you shim the differential left or right to get closer or further away. You want your gear teeth to look like this picture below. Right in the middle of the coast (inside of ring gear tooth) and the drive side (outside of tooth) to be in the center.
Name:	ImageUploadedByMustang Evolution1430339146.047145.jpg
Pinion depth is setup first, you just put the shim on the pinion gear, install and tighten all the slack out of the driveshaft flange. Then measure the force it takes to turn the pinion. 10-15 is for used bearings. 20-25 for new bearings. Once you tighten up the nut so there is no slack, measure and tighten till you reach the in/lb measurement. This is your bearing preload. Click image for larger version
Name:	ImageUploadedByMustang Evolution1430339314.377857.jpg
Old 04-29-2015, 02:31 PM   #8
austin3.7's Avatar
Is this something that ford would take care of since my car is still under the 36k mile warrant?
Old 04-29-2015, 02:45 PM   #9
tym_v6's Avatar
Unless there are aftermarket gears in there, it should be covered by the drivetrain warranty.
That said, I had my gears replaced under warranty (bearings failed after dealer "adjusted" the fluid level) but yhe preload was so far off that I wound up paying a mechanic to do a full rebuild.
So if you do warranty it, choose your dealer carefully or you might be worse off!
Old 04-29-2015, 03:46 PM   #10
Socal Stangman's Avatar
Its funny you posted this, I happened to notice this yesterday. I don't think mine is gear whine though. It happens on deceleration and I think its coming from the tranny. I never noticed it until yesterday for some reason.
Old 04-29-2015, 03:51 PM   #11
Harm_3.7's Avatar
I think that might be gear whine because I had it on acceleration and deceleration. Might be something else but just letting you know what I dealt with on my gear change.
Old 04-29-2015, 07:51 PM   #12
It could be. I did just have mine done. To be honest I never really noticed it before.
Old 04-29-2015, 08:03 PM   #13
alrefire's Avatar
the only thing that should whine on your car is a supercharger
Old 04-29-2015, 08:16 PM   #14
Harm_3.7's Avatar
Then I would get them checked out asap so the gears do not get messed up and you having to buy another pair!
Old 04-29-2015, 08:26 PM   #15
Gear whine is usually like drone of an exhaust. You know it's there.
Old 04-29-2015, 08:37 PM   #16
Harm_3.7's Avatar
I could hear my gear whine over my exhaust drone haha
Old 04-29-2015, 08:56 PM   #17
5pointYoBro's Avatar
The previous owner must have swapped the gears if they are whining like you say.
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
5pointYoBro is offline   Reply With Quote
Old 04-30-2015, 11:37 AM   #18
sticks123's Avatar
No whine here...had my 3.73's for a month or two!
sticks123 is offline   Reply With Quote
Old 04-30-2015, 06:10 PM   #19
08Mustang's Avatar
My 3.73s whine like crazy on decel...shop said they never had the proper to tools to measure during install. So they gave me my money back and now I gotta get a new gear set and get another shop to put em in
08Mustang is offline   Reply With Quote
Old 04-30-2015, 08:12 PM   #20
Harm_3.7's Avatar
Lol but they still went ahead and did the install? That's not a really smart idea for the person doing the install
Old 04-30-2015, 08:33 PM   #21
08Mustang's Avatar
Yeah I know, I was kinda baffled when they said that. I was thjnking like well why in the hell did you say you could do the install??
Old 04-30-2015, 08:43 PM   #22
Harm_3.7's Avatar
Just get the gears changed out soon as possible because I don't know if they can cause damage or not if not installed right. Honestly I would of been pissed if they said that. I would of been on the news next day for breaking that shop down lol
Old 05-01-2015, 09:08 AM   #23
Then someone needs to check their carrier and backlash.
Usually you reuse the pinion shim, because logically, it was setup with it oem no problems.
Old 05-01-2015, 10:46 AM   #24
Harm_3.7's Avatar
Oh I already had mine checked and it is now whine free 😝
Old 05-01-2015, 11:41 AM   #25
08Mustang's Avatar
Yeah I was livid...and yeah I got another shop to pop the cover and check it out and he said the gears aren't gona be damaged really but they'll never be quiet again no matter how he re shims it. So now a new set of gears is waiting for money for install again😑
Old 05-01-2015, 01:00 PM   #26
Harm_3.7's Avatar
You should have the shop pay for gears and gear oil that you brought to them too
Whiney engine and power steering... Mobley Pre-2005 V6 Mustang 6 10-07-2014 10:22 AM
4:10 gears vs 4:30 gears SwatKatz901 1996-2004 Mustang GT 5 03-24-2012 03:17 PM
3:55 Gears vs 3:73 gears 06Blue 2005-2010 Mustang GT 19 01-04-2012 06:57 PM
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
03:54 AM
