dynotech 4 aluminium driveshaft - Mustang Evolution
Old 04-30-2015, 03:37 PM   #1
vinnysantoni's Avatar
Can anyone tell me the benefits of getting a dynotech aluminium driveshaft.
ALSO I am getting it from a guy for $300 used it has 3,00 miles and am having my mechanic to look at it to make sure its all okay.
vinnysantoni is offline   Reply With Quote
Old 04-30-2015, 03:42 PM   #2
Hampton CIT's Avatar
Less rotational mass generally means the engine has less resistance and will improve acceleration. My questions would be who buys a $700 drive shaft, goes to the trouble of installing it then pulls it out. Good call in having it looked at.
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
Old 04-30-2015, 04:12 PM   #3
Right driveshafts are not cheap. does it help with mpg at all?
Old 04-30-2015, 04:17 PM   #4
Kevin.Cook
Guest
Posts: n/a
I have an aluminum driveshaft and I did not see any changes. For better or for worse.
Old 04-30-2015, 04:49 PM   #5
Diehard's Avatar
Are you asking, benefits of getting a "dynotech" or benefits of getting an aluminium driveshaft.
Benefits of the Dynotech would, in this case, be the price.
Benefits of getting an aluminum DS seem to vary somewhat between people that have gotten them. They definitely have a lot of theoretical benefits with regard to weight savings and speed limits.
There seems to be mixed opinions on the need to check/change pinion angle when changing from a 2 pc to a 1 pc drive shaft. You may want to look into that as well and don't take one persons opinion on the subject. (You could check with Dynotech, for their opinion.)
Old 04-30-2015, 05:12 PM   #6
smurf stang's Avatar
Aluminum driveshafts are used more for safety since it is a one piece design.
Not for mpg's or hp.
Sent from the Bathroom
2016 VW GTI 2.0 Turbo
Old 05-06-2015, 11:31 PM   #7
Mike3.7's Avatar
Most people invest in the driveshaft when they tune over the 115 speed limiter which going over 115 the 2 piece stock driveshaft can't handle. Probably the second biggest mistake Ford did to this car other than the 2.73s
Mike3.7 is offline   Reply With Quote
Old 05-11-2015, 08:15 PM   #8
king_13's Avatar
Yep, at 130+ mph the stock driveshaft literally goes "BOOM".
Sent from my iPhone
2014 Oxford White 5.0 Premium
2015 Maroon Chevy Cruze LTZ
2011 Performance White V6 Premium SOLD
king_13 is offline   Reply With Quote
Old 05-12-2015, 11:43 AM   #9
What about the vibration dampening and no clunk at lower speeds?
I heard 1 piece DS helps with these two issues also.
AirAidCIA | BAMA 87P Tune | BoralAtak AB| BMRAdj UCA | BMR UCA Mnt | BMRAdj PHB | GCCoilOvers | DSS 1 Piece AL Driveshaft | BMRLCA | BMR LCA Reloc Brackets | BARTONShifter | GT CS Spoiler| RedLine Hood struts | MMD Axim 20X8.5 Audio: Dynamatted Rear & Doors | AudioControl LC8i | Speakers: Infinity 682.9cf | RockFord Prime R250X4 Amp | Rockford Prime 500.1 Mono AMP | Kicker Twin10" L5 Solo Barics in a Ported BOX |P.S MORE TO COMEEEEE!!!!
Firstang001 is offline   Reply With Quote
Old 05-12-2015, 11:53 AM   #10
Kevin.Cook
Guest
Posts: n/a
It does. But so far for the Auto people, it adds a nice clunk when going to Reverse.
Pretty loud to. I was asked about it in a parking lot. Someone thought my car broke down. LOL
Old 05-12-2015, 12:03 PM   #11
Ohh.. So you are saying that it will help with the issues I listed but will add a clunk in reverse to autos only?
Old 05-12-2015, 12:20 PM   #12
Kevin.Cook
Guest
Posts: n/a
So far that seems to be the finding. I even checked the bolts twice. Everything is fine. So I guess the clunk comes natural with this. lol
Old 05-12-2015, 12:33 PM   #13
Ok Thanks!! I was curious because I recently ordered a DSS AL Driveshaft. I would hate myself if I paid to install a clunk on my car..
P.S. I have a V6 Manual.
Old 05-12-2015, 02:05 PM   #14
Harm_3.7's Avatar
The clunk is actually normal when I spoke to AM about this. There's really no fix I guess but it's not like it's such a big thing where it's annoying.
Harm_3.7 is offline   Reply With Quote
Old 05-12-2015, 03:14 PM   #15
DiESeven's Avatar
Clunk here too. It's normal I believe. Doesn't bother me because it only happens putting the car in reverse. And even then, it doesn't happen every single time. I find that the harder I press in the brakes, the less chance of a clunk sound.
Also, retuned car, took off 110 limiter and went 130mph (closed abandoned strip in mejico). The car felt as stable as if you were stopped. Extremely pleased with this addition.
When I would try for 110 on the stock drive shaft, it felt wobbly and massive vibrations.
Old 05-13-2015, 10:37 PM   #16
Midnight2012's Avatar
Had my stocker to 110mph and was as smooth as a baby's butt.
Midnight2012 is offline   Reply With Quote
Old 05-14-2015, 03:54 AM   #17
20prima10's Avatar
Like I've said before the clunk is just from the transmission going into reverse. The drive shaft is sitting still and then it's slammed the opposite way and stops real quick because the brakes are on. It's common sense when two or more metal parts interact like this they will make noise. The stock one does to but it's a lot quieter and under heard because of the material difference.
20prima10 is offline   Reply With Quote
Old 06-02-2015, 12:06 AM   #18
tym_v6's Avatar
Which shaft do you have? AE or DSS? I wonder if the CV joint in the DSS shaft reduces that clunk from going into reverse.
I'm getting kinda tired of my wobbly stock driveshaft and am planning a change soon.
Old 06-02-2015, 12:44 AM   #19
Harm_3.7's Avatar
I have the AE one and it does the same thing.
Opinions between Driveshaft Shop and Dynotech 1 piece MOOSEDAWG29 2011-2014 Mustang GT 61 05-04-2015 07:32 AM
Dynotech Aluminum Driveshaft Installed Scotty 1 Roush Mustang 11 05-07-2014 07:04 AM
aluminium driveshaft Fourloko530 Pre-2005 V6 Mustang 18 08-28-2013 06:00 PM
aluminium driveshaft Fourloko530 Pre-2005 V6 Mustang 1 08-28-2013 03:29 PM
install your own aluminium driveshaft? roushcoyotepony 2011-2014 Mustang GT 12 01-04-2013 08:31 AM
04:44 PM
