Wheel Spacers - Mustang Evolution
Old 05-01-2015, 09:50 PM   #1
dobiev6's Avatar
Wheel Spacers
Looking for some input on users of wheel spacers. I like the look from photos I have seen, but curious of the need to keep taking the wheels off to ensure the spacers are staying tight. Thanks...
dobiev6 is offline   Reply With Quote
Old 05-01-2015, 09:58 PM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
You SHOULD only have to retorque the spacers once. It is good practice to check them regularly though.
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 05-01-2015, 11:16 PM   #3
Socal Stangman's Avatar
I'll be doing some this weekend.
Old 05-02-2015, 01:42 AM   #4
RomanG's Avatar
Sitting on 1 and a half inch spacers on the rear wheels. Torqued them to 100 and then some.
Checked then about 100 miles in and did not find any backing out. Like mentioned above, it is good practice to check them every so often just to be safe
RomanG is offline   Reply With Quote
Old 05-02-2015, 10:29 AM   #5
dobiev6's Avatar
Wheel Spacers
Thanks guys, I appreciate the feedback. RomanG I love the stance with the 1-1/2"!
Old 05-02-2015, 02:09 PM   #6
FastFord13's Avatar
Never was a fan of wheel spacers, just looks funny from behind.
Sent from LG G3.
Old 05-02-2015, 03:48 PM   #7
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Yeah, that 1 1/2" in the pic above is a little much. Too much poke to me for that size tire. Maybe a 1/2"-1" spacer and a wider wheel/tire
Old 05-02-2015, 05:11 PM   #8
iantrusive's Avatar
I love the look of wheel spacers, but I'm too chicken to try them myself lol
Sent from my Mustang.
iantrusive is offline   Reply With Quote
Old 05-02-2015, 05:34 PM   #9
Scared of what?
Old 05-02-2015, 08:06 PM   #10
Good solid information
Check it out:::
Installing Wheel Spacers- How to
Old 05-02-2015, 08:09 PM   #11
Check for clips and remove them
Look for these on your studs. Remove them, They were only put on for the assembly line and are not needed or wanted anymore.
Old 05-02-2015, 11:32 PM   #12
iantrusive's Avatar
I've just heard stories about spacer problems, I'm sure it's generally safe if you do them correctly, but if something goes wrong, I won't have the money to fix it.
Old 05-03-2015, 06:46 AM   #13
They are safe on the rear wheels if done properly
Spacers on the rear wheels have been used by Drag Racers for probably fifty or sixty years to use wide wheels and tires for traction.
I have seen people try to use them on the front wheels but I have also seen a lot of my friends wreck the car after doing it. I would never use any spacers on the steering front wheels."NEVER"
I have used them on the rear wheels many times on many different cars with no problems except modifying the wheel wells for clearance. Blocking the rear so it had no travel and keeping a check on them. That was a lifetime ago. I would never use them on my Mustang now a days because I can buy offset wheels to run wide slicks on if I was still drag racing. Besides, I'm not about to block up my rear suspension or cut my wheel wells on my Mustang.
With the great sticky tires you can get now from manufacturers like NITTO and the great selection of offset wheels you can buy I would not use a spacer at all.
If you want them just for looks, go ahead and do it but just do it properly and you will be safe. But I would suggest A SWARR BAR from American muscle to keep the strain off the rear axles. Or at least weld the axles to the differential.
LOOK HERE:::
http://www.americanmuscle.com/search...tion=2010-2014
wheel spacers (adapters) OXstang11 Mustang Wheels & Tires 9 10-28-2005 11:42 AM
2 H&R 1" Wheel Spacers 5x114.3 tedness Mustang Parts for Sale and Wanted 6 10-18-2005 11:42 PM
wheel spacers own you tedness The Bar 22 04-21-2005 01:14 PM
Wheel Spacers 19ClearCobra96 1996-2004 Mustang GT 3 11-21-2004 03:18 PM
1.25" wheel spacers!!! a1yola Mustang Parts for Sale and Wanted 10 03-01-2004 05:53 PM
10:45 AM
