BMR LCA - Car on jack stands with blue flame audio. - Need input - Mustang Evolution
Old 05-03-2015, 07:32 AM   #1
Hampton CIT's Avatar
Installing some BMR LCA on my 2014 V6. Car on jacks stands (under axle) I'm trying to load the car with a jack on normal jack point to allow me to line up holes for new LCA. I'm about a 1/4" shy of being able to get the bot in the rear mounting point. No play in the urethane bushings is making this quite the language lesson (Sailor 302). I'm absolutely positive this is normal. Anyone have similar experience with this? Is there a trick or do I need to cuss more and grab a hammer? Input needed to my audio edited posting here.
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
Old 05-03-2015, 07:38 AM   #2
This is normal I used a long punch or screw driver to line it up I guess you are on the back at the axle. Hope this helps!!
Teak 14 is offline   Reply With Quote
Old 05-03-2015, 07:54 AM   #3
Scott2's Avatar
If a punch or large screw driver doesn't work and you have a second floor jack you could try it right under each LCA individually for that extra 1/4" of lift.
Old 05-03-2015, 10:02 AM   #4
The punch did the trick. Too much fussing clouds common sense. Thanks Teak14. Gonna make a few passes down some country road and will let you V6 owners know the burning question I've had.
Old 05-03-2015, 11:30 AM   #5
Scott2's Avatar
Glad you got the LCA's on!
Old 05-03-2015, 11:48 AM   #6
tym_v6's Avatar
I drove my car on ramps (actually just a stack of 2x10s) to install my LCAs...worked pretty well but not a ton of space to swing the torque wrench.
Old 05-03-2015, 12:01 PM   #7
Yeah... I could have done that too but that would have made things easier.
Report, Review and Thoughts on BMR LCA listed here - BMR LCA on V6 Review and Report
Old 05-04-2015, 08:23 AM   #8
tym_v6's Avatar
Been there, done that, have the T-shirt.
Where to buy a good floor jack and stands? MachMan1017 General Mustang Discussion 17 03-06-2013 04:12 PM
jack stands Son_of_Zeus 2011-2014 V6 Mustang 5 08-19-2012 05:27 PM
Need help fast car on jack stands!!!! black9D5 2011-2014 Mustang GT 20 07-07-2012 10:08 AM
Jacks, jack stands and late model Mustangs CurbRash General Mustang Discussion 18 04-29-2012 08:36 PM
jack stands 04_GT 1996-2004 Mustang GT 4 10-10-2009 10:54 AM
08:22 PM
