Pypes Rubbing - Mustang Evolution
Old 05-04-2015, 03:18 PM   #1
BlackKnight92's Avatar
Pypes Rubbing
I purchased my Pypes Axle Back exhaust and finally got it on. My main issue is the driver side keeps rubbing on the bumper cutout. Any tips on how to get it straightened out without taking it to a shop to have another hanger welded in?
2012 Mustang V6
BlackKnight92 is offline   Reply With Quote
Old 05-04-2015, 03:25 PM   #2
Socal Stangman's Avatar
Top or sides?
Old 05-04-2015, 03:30 PM   #3
Originally Posted by Socal Stangman View Post
Top or sides?
Outer side
2012 Mustang V6
Old 05-04-2015, 03:35 PM   #4
It doesn't need a new hanger, just an adjustment. You have to loosen the clamp by the over the axle pipes. Hold the tip where you want it to be and then tighten it down. Its very easy.
Old 05-05-2015, 06:21 PM   #5
Abominable Mustang
WhoDat's Avatar
Region: Alaska
You can also loosen the clamps where the midpipe meets the overaxle pipes and rotate the pipes to help line them up. That's what I had to do
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 05-05-2015, 08:17 PM   #6
Diehard's Avatar
I can envision cases where WhoDat's procedure may be necessary.
I had to jam some wood between the tip and the cutout and then loosen and re-tighten the bolts.
Having two people would be best.
Old 05-05-2015, 08:39 PM   #7
Abominable Mustang
WhoDat's Avatar
Region: Alaska
On the tip itself, I wrapped a folded up towel around it to keep it centered in the cutout
Old 05-06-2015, 05:14 PM   #8
Arturo3.7's Avatar
I was having the same issue with my Pypes exhaust so i bought some v clamps and tighten it up but after a couple of months it will still make a noise. So now i'm just getting Roush axle back.
Arturo3.7 is offline   Reply With Quote
Old 05-06-2015, 11:16 PM   #9
Mike3.7's Avatar
I've the same issues with mine honestly I just think that's where the price becomes a factor seeing as they are cheaper than most other options they seem to "re-adjust" themselves eventually. I've adjusted mine twice now and eventually they go back to rattling against the cutout again and again. Not sure if there is a solution I'm not using or should be using but I've had this same issue so no worries on being alone lol
Mike3.7 is offline   Reply With Quote
Pypes OffRoad H Pipe + Pypes Muffler Deletes!! Jake 2005-2010 Mustang GT 21 08-17-2012 07:23 AM
Rubbing Alchohol StreetRacer4371 The Bar 7 11-08-2004 12:53 PM
Fixed my "rubbing problem" greenflash00 The Bar 2 02-18-2004 10:51 AM
Getting some rubbing up front...any suggestions? greenflash00 Mustang Wheels & Tires 18 02-08-2004 12:42 PM
09:42 PM
