Pan Hard Bar Install and Adjustment - Mustang Evolution
Old 05-06-2015, 03:12 PM   #1
Socal Stangman's Avatar
Ok so Ill be installing my BMR PHB hopefully tomorrow. Any tips or tricks for the install and adjustment? It looks like a pretty easy install. How about adjusting it, easy? The drivers side tire is sticking out too far so that what I need to fix. Do I shorten or make the bar longer?
Old 05-06-2015, 03:50 PM   #2
Harm_3.7's Avatar
I've seen on a YouTube video to shorten the bar a little bit from stock one but someone else with better understanding will chime in on this
Harm_3.7 is offline   Reply With Quote
Old 05-06-2015, 03:58 PM   #3
I just watched a YouTube video...seems pretty easy.
Old 05-06-2015, 04:31 PM   #4
Kevin.Cook
Guest
Posts: n/a
So is installing these "dummy proof"? Example: User thinks the car looks "fine" After dropping it. Even though they need a Panhard bar, how will they know it is correct after putting it on if they already think it looked ok?
Old 05-06-2015, 04:35 PM   #5
Commercial Member
au01st's Avatar
Tie a washer to a string. Tape above fender to hang down to wheel/tire. Measure difference from each side. Adjust bar and measure again. If it doesn't change the right way, then adjust the bar the opposite direction. Seems pretty fool-proof.
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 05-06-2015, 04:35 PM   #6
Lol...Im not 100% sure what youre saying.
Ill tell you this though. You really notice how far its off when you put on a bigger tire. One of my co-workers noticed actually, my driver side tire sticks put probably almost 1/4" further than my passenger side. You really can notice it once you notice it, does that make sense?
Old 05-06-2015, 04:37 PM   #7
This ^
As for installing and adjusting it's literally a bolt on each side and they usually twist in and out to adjust length.... Cake
Old 05-06-2015, 04:44 PM   #8
Kevin.Cook
Guest
Posts: n/a
Thanks. Sorry for hijacking your thread Socal. As I am trying to find ALL helpful info for my suspension swap in the fall.
Old 05-06-2015, 04:48 PM   #9
Nope,thats fine. I don't consider that a thread jacking. Some of this is new to me as well. All my cars have always been IRS, this is really my first solid axle car that Ive done work on.
Old 05-06-2015, 04:52 PM   #10
Kevin.Cook
Guest
Posts: n/a
I have never looked in to the suspension swap on my car because I assumed the Performance Pack one sufficed. But voltwings help shed some light that it is nothing but a base GT suspension. Which doesn't sound any better then stock V6. lol
So it's good we can all learn together. The lower control arm bracket will be new also.
Old 05-06-2015, 05:06 PM   #11
Suspension is amazing in these cars. Apples to oranges but my 01 is mainly all suspension work and it feels like a completely different car with everything I've done, it's crazy how much a good suspension brings a car to life.
Old 05-06-2015, 05:10 PM   #12
For those that have done this, do you have to take the rear tires off for removal and install of the PHB's?
Old 05-06-2015, 06:11 PM   #13
sunnytan06's Avatar
I think you can just jack it up all 4 corners.
sunnytan06 is offline   Reply With Quote
Old 05-06-2015, 06:22 PM   #14
Voltwings's Avatar
Nope, just jack the rear up / install / lower / adjust.
Quick tip, loosen the top bolt holding the PHB brace in place, otherwise the PHB will not come out of the bracket on the body. Imagine the bracket as a big U with both of them in the middle, if you dont loosen the top bolt to release the "U" it wont come out. This will make perfect sense when you see it.
Then just make sure the car is on the ground (lower without E-brake on so car settles) and use the method above. I used a nail to have a little more weight on the string, but anything will work, you just want the string to remain stable.
Remember loc-tite. You dont want this thing working loose, but really its a very simple job.
Old 05-06-2015, 09:04 PM   #15
Connor323's Avatar
Wait so when adjusting the PHB the car should be on the ground? Mine is already installed, but I need to adjust it.
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Connor323 is offline   Reply With Quote
Old 05-06-2015, 09:06 PM   #16
Commercial Member
au01st's Avatar
Lower, maybe go around the block so everything settles. Check fit. Raise. Adjust. Repeat.
Old 05-06-2015, 09:13 PM   #17
Connor323's Avatar
Gotcha. Thanks
Old 05-06-2015, 10:47 PM   #18
NewMtang's Avatar
If I order the strings from America Muscle, do I still get the 6% discount?
Old 05-06-2015, 10:58 PM   #19
Commercial Member
au01st's Avatar
Yes, but it's only sold in bulk 10,000yd rolls. But hey, that free shipping!
Old 05-07-2015, 06:05 AM   #20
Voltwings's Avatar
I parked mine at the very edge of the garage, and then i laid in the driveway to give myself an extra inch or two and was able to adjust it without raising the car. I feel this should be adjusted on a flat, level surface, but i could be wrong, its just how i did it.
Old 05-07-2015, 02:27 PM   #21
Diehard's Avatar
And if your tires stick out beyond your fender you can do without the string.
Old 05-07-2015, 03:08 PM   #22
Whitelightning's Avatar
I hit it with a hammer to get it in. Measured with string. It's 1/8 off but that's close enough
Old 05-07-2015, 03:51 PM   #23
IS3
IS3's Avatar
Honestly, Mine came with a J&M adjustable PanHard bar. but the right passenger side on the rear still sticks out. you can see that the left side is inside the wheel well, and the right side isnt... the problem here though is that there is really no room for adjustment... I went to an alignment shop and even they cant figure out whats going on.... so now i just live with it...
IS3 is offline   Reply With Quote
Old 05-08-2015, 05:55 AM   #24
Voltwings's Avatar
So the bar's adjustment is grounded out? just flip the bar over and adjust the other way?
Old 05-08-2015, 04:15 PM   #25
IS3
IS3's Avatar
you know what i havent done that since the car came with the bar.. hmm i will definitely try it! thank you!
Old 05-10-2015, 07:51 PM   #26
Diehard's Avatar
Originally Posted by KryptonKnight View Post
The starting point is to remove the OE then adjust the new PHB to the same length as the OE.
He doesn't have the OE. He got the car with the adjustable Panhard bar already on it.
Old 05-10-2015, 07:56 PM   #27
Kevin.Cook
Guest
Posts: n/a
Jack up someones stang in a parking lot and take their oe bar. Just kidding!!!!!! Maybe ask someone for the measurement from theirs?
Old 05-11-2015, 03:38 AM   #28
jonyou's Avatar
I'll be installing my phb later this week probably. If you still need it I can get the measurements for stock.
2014 V6 Performance Package Sterling Grey
MPT Tuned.
Airaid CAI, BBK Shorty Headers, Borla S-types, Stubby Antenna, JLT Catch Can, MMD hood struts, GT500 spoiler, Oracle Halos on GT Grille, Dynotech One piece Aluminum Driveshaft.
jonyou is offline   Reply With Quote
Pan hard bar Brandonfive_oh Mustang DIY and Technical 4 02-12-2015 08:12 AM
Adjusting a pan hard bar C_Dailey95 2005-2010 Mustang GT 0 01-12-2014 05:23 PM
05&up pan hard bar watson 1025 1979-1995 Mustang GT 0 05-14-2013 09:57 AM
pan hard bar bigsmitty24 2011-2014 Mustang GT 29 01-10-2013 06:21 AM
J&M adjustable Pan Hard bar back n a stang Mustang Parts for Sale and Wanted 22 12-26-2012 06:15 AM
02:16 PM
