Air conditioning problems - Mustang Evolution
Old 05-06-2015, 10:21 PM   #1
I am experiencing some odd problems. When running my a/c, it blows strong and cools fine for about 30 minutes to an hour, then it starts getting less cooler and the air won't come out of the vent vey much. If you turn off the power to the a/c controls or shut off the car for about 15 to 30 minutes, it will return to normal again. It doesn't appear to be low on freon. Is this a vacuum leak or a bad actuator in the a/c control? Help!
melwana is offline   Reply With Quote
Old 05-07-2015, 07:54 AM   #2
iguanaman3's Avatar
That sounds like your evaporator is freezing up and blocking air flow thru it. When you turn it off the ice melts and it works again. It could be your compressor cycle switch but I would take it to a pro for diagnosis.
iguanaman3 is offline   Reply With Quote
Old 05-07-2015, 06:42 PM   #3
If it's freezing up, it's probably low on Freon. But definitely get it looked at, you could have a small leak or something.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 05-07-2015, 09:29 PM   #4
ponie1992's Avatar
He says it doesn't blow out as much when it happens. Maybe the blower motor is going out.
Jeremy
Jeremy
2016 Ruby Red PP GT
ponie1992 is offline   Reply With Quote
Old 05-07-2015, 10:29 PM   #5
gqsmash's Avatar
Filter could be dirty, hard to believe with that year car but possibility as are all the other things stated
gqsmash is offline   Reply With Quote
Old 05-09-2015, 12:36 AM   #6
Midnight2012's Avatar
Mine had A/C problems at 4000 miles. Will see if I can find the paper work. Was fixed under warranty.
Midnight2012 is offline   Reply With Quote
Old 05-10-2015, 07:33 PM   #7
I received a new compressor at 200 miles
fission is offline   Reply With Quote
air conditioning problems sandawilliams 2011-2014 V6 Mustang 45 08-14-2016 04:23 PM
Heating/Air conditioning controls 10thAniv03Cobra 1996-2004 Mustang GT 1 09-16-2010 05:57 PM
96 3.8l V6 - Air Conditioning gary2381 Pre-2005 V6 Mustang 1 06-24-2010 03:35 PM
Air Conditioning problem - 96 Mustang V6 WVKarenC 1996-2004 Mustang GT 8 06-15-2009 12:42 AM
Air Conditioning Q wrecked2001 1996-2004 Mustang GT 9 10-28-2006 05:08 AM
04:33 PM
