05-10 GT rotors vs 11-14 3.7 rotors - Mustang Evolution
Old 05-08-2015, 01:14 AM   #1
Commercial Member
au01st's Avatar
Are the rotors the same? I know for 11-14 the GT's rotors are larger, but are ours the same as older GTs? Just curious.
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 05-08-2015, 05:02 AM   #2
2011fastford's Avatar
Region: New Mexico
yes 05-10 rotors are the same as 11-14 v6 rotors, unless it's a PP v6 which uses 11-14 gt sized brakes
2011 Mustang V6 auto/procharger p1sc kit with 3.70 pulley/circle d 3200 stall/4:10 gears/dss aluminum driveshaft/tial q bov/bbk long tubes with catted x pipe/dynomax ultra flo catback/bbk throttle body/accel super coils/cyclone ported upper and lower intake manifolds/brembo front brake kit
INSTAGRAM @2011fastford505
2011fastford is offline   Reply With Quote
Old 05-08-2015, 05:43 AM   #3
And you can put the 11-14 GT rotors on the V6, you just need the GT brackets & shields.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 05-08-2015, 07:35 AM   #4
Commercial Member
au01st's Avatar
Knew that the size could be upgraded. See older roush slotted rotors for $134/pair on eBay. Figure with new rims it might be nice to see something behind them as well.
Old 05-08-2015, 07:43 AM   #5
Voltwings's Avatar
The only thing i could think would be an issue, is if the hubs are not the same. As in the backspacing / offset of the rotor so to speak, may not line up with the newer body style caliper, rim, etc. Likely not an issue, but something to be aware of.
Old 05-08-2015, 08:07 AM   #6
He should be ok, if you look at just rotors on AM the ones for the 11-14 V6 also show for the 05-10 GT in the description.
Old 05-08-2015, 08:22 AM   #7
Commercial Member
au01st's Avatar
Yeah, I saw that, but figured I would ask here first before I ordered and got a new set of door stops.
Want something to look good behind these:
99-04 GT or V6 front calipers with rotors and pads SpectorV Mustang Parts for Sale and Wanted 3 05-27-2005 01:58 PM
WTB: Baer 13" cross drilled rotors 1bad281 Mustang Parts for Sale and Wanted 1 01-31-2005 03:41 PM
Got my new calipers and rotors today **with pics** SpectorV Pre-2005 V6 Mustang 17 06-10-2004 05:42 PM
Brembo Sport Slotted Rotors (Rear) Hawk Pads mattstang Mustang Parts for Sale and Wanted 7 04-30-2004 07:08 PM
Need Pics of 13" brembo rotors installed!! Autobadges.com The Bar 21 12-14-2003 04:32 PM
10:48 PM
