transmission/DS "metal ding" sound after Alum. 1 pc. DS installed - Mustang Evolution
Old 05-10-2015, 07:08 PM   #1
Just had AM's aluminum 1 pc driveshaft from the driveshaft shop installed by a very reputable driveline shop. Vibrations are gone now from the stock 2 pc. All good, EXCEPT now shifting from forward to reverse a small but recognizable metal ding or bell sound comes from the DS/trans area. Is this gear slop acceptable and the noise too? transmission shifts fine and works great.
ADHock is offline   Reply With Quote
Old 05-10-2015, 07:49 PM   #2
Kevin.Cook
Guest
Posts: n/a
I too hear this on mine same stuff you are experiencing. I checked the bolts twice. Never found a fix.
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Old 05-10-2015, 07:56 PM   #3
Harm_3.7's Avatar
I thought with an adjustable upper control this goes away but I installed one and it didn't make a difference lol
Harm_3.7 is offline   Reply With Quote
Old 05-11-2015, 11:55 AM   #4
Retrokid63's Avatar
Region: Maine
I have the same situation. The drive to reverse noise only appeared after I swapped the factory driveshaft to one piece aluminum. Everything is tight and I'm guessing that it's normal (I hope).
2014 V6 Base "Gotta Have It Green" automatic, Boss stripes
1972 Gran Torino 2 door coupe...sold
1965 Mustang coupe, 289 dual quad, Edelbrock Performer RPM heads, Ford Racing cam, Magnaflow exhaust, street-strip automatic....she's a screamer!
Retrokid63 is offline   Reply With Quote
Old 05-11-2015, 12:07 PM   #5
20prima10's Avatar
This probably just due to the rotation cause from the gears switching between reverse to drive. Drive shaft it probably getting a quick bump up to 1/4" but probably less. Jack the car up and rotate or rock the driveshaft. However much play you see or hear is probably the cause for your noise. Nothing to worry about here guys.
20prima10 is offline   Reply With Quote
Old 05-11-2015, 02:34 PM   #6
JCALD's Avatar
The aluminum driveshafts are much noisier than the steel and amplify the sounds. Not a problem, just an annoyance.
JCALD is offline   Reply With Quote
Old 05-12-2015, 12:10 PM   #7
Is this experienced by Auto Or Manual or Both Transmission?
I am curious now
AirAidCIA | BAMA 87P Tune | BoralAtak AB| BMRAdj UCA | BMR UCA Mnt | BMRAdj PHB | GCCoilOvers | DSS 1 Piece AL Driveshaft | BMRLCA | BMR LCA Reloc Brackets | BARTONShifter | GT CS Spoiler| RedLine Hood struts | MMD Axim 20X8.5 Audio: Dynamatted Rear & Doors | AudioControl LC8i | Speakers: Infinity 682.9cf | RockFord Prime R250X4 Amp | Rockford Prime 500.1 Mono AMP | Kicker Twin10" L5 Solo Barics in a Ported BOX |P.S MORE TO COMEEEEE!!!!
Firstang001 is offline   Reply With Quote
Old 05-12-2015, 12:12 PM   #8
Kevin.Cook
Guest
Posts: n/a
I have an Auto and I get the loud ding when going to Reverse.
Old 05-12-2015, 07:39 PM   #9
20prima10's Avatar
Seems like the only people are those of you with out the fun trans
Manual for fun
Auto for track speed.
I'm by far a manual trans guy. Love them but I can't lie an autos better for the strip.
Old 05-12-2015, 07:45 PM   #10
Kevin.Cook
Guest
Posts: n/a
I would LOVE a manual trans. HOWEVER, I got my Mustang at the End of Year Sale last year. Where all of the Ford dealers were dropping prices on new 2014 Mustangs to get them off the lot for 2015s.
I checked all around the San Antonio and Austin areas. ALL of the manual transmissions were SOLD. The ONLY Auto left worth anything was the one I got. With the tech package, reverse sensors, and performance package. Better then nothing I guess....
I cry every time I think about it
Old 05-13-2015, 03:37 AM   #11
20prima10's Avatar
I got lucky finding mine. I'm from Michigan and was in pa for work and saw it at the dealer. Went inside and said I wanted to see it and sure enough it was a manual so I picked it up. I know your feeling though because I couldn't find a manual in Michigan any where
anoying ding sound 87blackonblack 1979-1995 Mustang GT 6 03-11-2012 06:53 AM
What series or year is the metal on metal hot wheels from? daren The Bar 3 03-12-2010 09:36 AM
Several things FS: (clutch, alum flywheel, ect) jimmy_beaner Mustang Parts for Sale and Wanted 41 06-14-2009 10:32 PM
DING, DING, DING 06limegt 2005-2010 Mustang GT 8 04-07-2008 01:37 PM
04:34 AM
