Issue with hood vents and exposed intake filter - Mustang Evolution
Old 05-11-2015, 12:29 PM   #1
Kevin.Cook
Guest
Posts: n/a
So just wanted everyone to be aware. When cutting the vents or getting hood vents on your V6, please be aware that moisture will still find it's way through the heat blanket under the hood. Even though I left some of it and to me, the Airaid was not entirely exposed, I figured it would be fairly safe. I was WRONG.
The moisture crept through the heat blanket and the intake filter was completely soaked after it rained today. Now I have to dry it and dry the MAF sensor.
Just a warning to others who may look for a similar setup.
Old 05-11-2015, 03:33 PM   #2
Hampton CIT's Avatar
God bless you for posting this. Been considering this very mod.
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
Old 05-11-2015, 03:39 PM   #3
Kevin.Cook
Guest
Posts: n/a
It is still a good mod to do. I will just need to find a water resistant material to put under the vent near the intake instead of hoping the heat blanket shields it. Also, the material needs to withstand engine bay heat.
It did initially trigger some nasty idling, the CEL, and the Wrench light. But after drying everything off and letting it run for a bit, the car is happy again.
Old 05-12-2015, 01:07 AM   #4
NewMtang's Avatar
Did you do the install for the vents? I haven't noticed anyone that has changed hoods completely having this problem.
Old 05-12-2015, 06:37 AM   #5
fordfan100's Avatar
Airaid offers a plate that covers the intake for hood vents
fordfan100 is offline   Reply With Quote
Old 05-12-2015, 06:45 AM   #6
Commercial Member
au01st's Avatar
http://www.knfilters.com/mobile/news.aspx?id=1235
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 05-12-2015, 07:46 AM   #7
Kevin.Cook
Guest
Posts: n/a
Where do you see that? I tried searching their site and only found intake kits like mine. Looks like for the 2015s, they come covered -_-
Old 05-12-2015, 08:04 AM   #8
Kevin.Cook
Guest
Posts: n/a
Originally Posted by au01st View Post
K&N Engineering News and Events - Mobile
That au01st. I saw Airaid had these too. But I want to try and find a solid cover first before going that route.
Here is a video that someone with a GT shows the same issue under heavy water. It rained about that heavily yesterday.
Old 05-13-2015, 01:51 AM   #9
fordfan100's Avatar
It came in my box from late model resto. Maybe call them and they can help you
Old 05-13-2015, 03:11 AM   #10
Kevin.Cook
Guest
Posts: n/a
Do you have a picture of this part?
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Old 05-13-2015, 05:48 PM   #11
paintmann111's Avatar
He screwed up and cut out the whole section. The stock GT hood (which I have) only has a slit cut down the side of that indent.
paintmann111 is offline   Reply With Quote
Old 05-17-2015, 08:31 PM   #12
fordfan100's Avatar
No i threw it away. You may want to try and call airaid they should have it. All it looked like was a piece of sheet metal the went over the filter and forced water to run off. They also sell waterproof socks for the filter
Old 05-17-2015, 10:18 PM   #13
alucard3600's Avatar
It came in my airraid box too, it was a flier that said they were free of charge if you called and asked for one, but god knows where that piece of paper got off to....
2014 3.7l Auto Oxford White
Mods: Cervini Stalker Hood, Roush highflow upper and lower grill, AirRaid CAI, LMR strut tower brace,Mac LT headers,Mac Prochamber, Kooks Highflow Cats,Dynomax Race Bullets (resonators), 2.5 o/a pipes, 2011 Gt500 Axlebacks, MPT 93 performance tune.
alucard3600 is offline   Reply With Quote
Old 06-03-2015, 01:11 PM   #14
Pretzel's Avatar
Do you think I would run into this problem with a OEM GT hood? I will (hopefully) be purchasing one this weekend, but I also have the Airaid CAI. I know there seem to be quite a few uncovered CAI offered for the GT's...
Pretzel is offline   Reply With Quote
Old 06-03-2015, 01:18 PM   #15
Kevin.Cook
Guest
Posts: n/a
Well I am reordering a new (GT) hood insulation for my car. Because the slits are on the sides of the undervent parts. Not the whole thing being cut out. JLT has a foam insert you can put in above the vent on top of the intake to block water.
Old 06-03-2015, 01:32 PM   #16
Pretzel's Avatar
You mean this here sir?
Hood Insert Plug (2013-14 Mustang GT/Boss only) [JLT-13H] - $9.95 : JLT PERFORMANCE, Home of the JLT TRUE COLD AIR KIT
That looks like a great idea, hope it works! Thanks!
Old 06-03-2015, 01:32 PM   #17
oxford5pointoh's Avatar
There is a guy who made a YouTube video where he hits stock gt hood with a hose for a few minutes, cold air filter was drenched afterwards.
IG @Oxford5pointoh
Old 06-03-2015, 01:44 PM   #18
Pretzel's Avatar
IG @Oxford5pointoh
Is that the video above? I think I will definitely order a pair of those JLT plugs, then run my own water test!
Old 06-03-2015, 01:46 PM   #19
Originally Posted by Pretzel View Post
Is that the video above? I think I will defiantly order a pair of those JLT plugs, then run my own water test!
Lol, yeah that's the video. Guess that's where I had seen it.
IG @Oxford5pointoh
Old 06-03-2015, 02:10 PM   #20
doyouevenforum
Guest
Posts: n/a
I have the jlt Intake and insert. Been through a few storms since and filter was dry.
Sent from my SAMSUNG-SM-N900A using Mustang Evolution mobile app
Old 06-03-2015, 02:15 PM   #21
Pretzel's Avatar
Good to know! BTW, do you remember if the price on the JLT website was for the pair of inserts, or do I need to order two?
Old 06-03-2015, 02:19 PM   #22
Kevin.Cook
Guest
Posts: n/a
The $10 price was for 1. But 1 is all you need. You only need it for the intake side.
Old 06-03-2015, 02:21 PM   #23
Pretzel's Avatar
Oh yeah. Duh.
Old 06-04-2015, 10:38 AM   #24
Diehard's Avatar
I thought the guy in the video mentioned something about a possible concern for the fuse box side. But I wouldn't think that would be a problem since it's OEM design.
Old 06-04-2015, 10:54 PM   #25
GrabberBlue1993's Avatar
Did you screw your hood up? I have 2 hood vents and a dual ram air intake on my hood and it absolutely poured the past few days and I have no problems with water getting on my intake.....
"At least it isn't a Honda"
GrabberBlue1993 is offline   Reply With Quote
Old 06-05-2015, 07:43 AM   #26
Voltwings's Avatar
The intake filter getting wet isnt as bad as the MAF getting wet, i imagine it comes down to a combination of things. Speaking of which, a Dual ram air intake? Got pics?
Old 06-05-2015, 09:35 AM   #27
By dual ram I meant two ram air inlets that connect under the hood and go to the same outlet under the hood. Not two outlets for like a TT set up lol.
Sent from my 831C using Mustang Evolution mobile app
ID:	184172   Click image for larger version
Old 06-05-2015, 09:36 AM   #28
Voltwings's Avatar
AHH, you've got a blow through MAF ... you could literally inject water INTO your intake (called wet compression actually, check it out) and not have problems, so yours doesnt count lol.
Filter getting wet they hood vents WhiteCali5oh 2011-2014 Mustang GT 15 11-28-2014 04:41 PM
Opinions needed on hood vents PureVenom Mustang Audio & Video 20 11-30-2006 04:15 PM
02:00 PM
