I know I'm going to be sorry for asking but... - Mustang Evolution
Old 05-11-2015, 04:33 PM   #1
Diehard's Avatar
What does "UPC" stand for?
As in LCA or adjustable UPC's.
Old 05-11-2015, 04:34 PM   #2
natestang07's Avatar
Lower control arms and upper control arms I believe,
Old 05-11-2015, 06:46 PM   #3
jayochs's Avatar
upper control arms would be UCA lol not UPC.
2014 Ford Mustang 3.7 Premium 6-speed:
MPT Performance Tune, AM Laguna Seca Black 19" Rims, Borla Touring Axlebacks, Boss 302 Strut Tower Brace, Airaid Modular Intake Tube, aFe Pro Dry S Air Filter, Mustang GT Grille w/ Foglight Mesh, Taillight Tint, Tinted Door Ventvisors, Diode Dynamics LED's
jayochs is offline   Reply With Quote
Old 05-11-2015, 06:59 PM   #4
Pretty sure he meant uca. Never seen upc around here
Old 05-11-2015, 07:27 PM   #5
king_13's Avatar
The only UPC I know of is the barcode.
Sent from my iPhone
2014 Oxford White 5.0 Premium
2015 Maroon Chevy Cruze LTZ
2011 Performance White V6 Premium SOLD
king_13 is offline   Reply With Quote
Old 05-11-2015, 07:59 PM   #6
Diehard's Avatar
There has been at least 3 references to it in this forum, recently. I believe Alex of American Muscle was one of them. I'll try to find them.
Old 05-11-2015, 08:17 PM   #7
Diehard's Avatar
Looks like it does refer to the UCA. Must be a different term.
Originally Posted by oxford5pointoh View Post
I am sure BMR stuff is great, but I prefer Steeda, and I'm trying to keep everything the same brand. Keep it all cohesive. I've had great experiences with their product and customer service. I already have the CC plates, Panhard, and springs. Looking to get the UPC, LCA, brackets for UPC & LCA and eventually the watts link. Once I get the UPC and bracket I will actually install my kit. I also have the Koni yellows. I don't race my car but I drive it about 7-800 miles a week. So I need it to be reliable and practical until it becomes my weekend car once paid off.
Originally Posted by olerodder View Post
If you go with the race springs you will be sacrificing most if not all of the comfort. A progressive spring lets you have some comfort like when you are driving around town but the harder you push it the more it becomes like an all out race spring. Going with a race spring means you are going to sacrifice more than a little comfort...........it will be quite a lot more noticeable than the Sportline or Supersport.
I've not had it to the track yet and don't expect much bumpsteer and carving corners at the limit I have only seen a little, nothing drastic.
I have the LCA's on the car and the UPC is waiting until I put in the 1 piece drive line..........I'm sure I will need it then as I will need to get the pinion angle in sync with the trans angle.
My suggestion would be to get them both if you are going to lower the car with Sportlines or Super Sport springs. My driveshaft angle is a little off from factory but the two piece driveline is a little more forgiving than a 1 piece.
Forget about the "camber bolt", you don't need it and they are not safe.
I've helped lower 5 late model Mustangs along with my own and non of them needed to have anything done. How do I know, all of the owners of the other lowered Mustangs had their alignment checked, as did I. The camber bolt is a total waste of time/money.
If you use the BMR UPC, also use the BMR LCA..........just doesn't make any sense to mix and match different brands.......like putting Champion spark plugs on one bank of the motor and Autolite on the other.
If you would need to adjust your pinion angle with non-adjustable LCA's and non-adjustable UPC your are screwed. Get the adjustable UPC and if you have no need to change the pinion angle set it at 0. If you have LCA's you should get an UPC to make everything solid............the stock UPC is junk and helps remote wheel hop.....IMHO
Old 05-11-2015, 08:26 PM   #8
Diehard's Avatar
Here's another one.
Originally Posted by AMWill View Post
OP,
You can get away with using the Eibach camber bolts. The alignment will be good enough that you won't notice any weird wear on the tires. However, if you're constantly driving aggressive or even have one hard auto cross track day, the camber bolts sometimes have issues holding position. The biggest benefit of the caster/camber plates is getting a perfect alignment, but also not worrying about them coming lose after hard wear on the suspension.
Also, I would get some solid LCA's, adj UPC's, and LCA relocation brackets as soon as possible. The H&R springs have a big ride height drop and will really affect your suspension's geometry. You'll notice the car will wheel hope easily and traction will be an issue on the street or track, without the upgrades listed above. I just wanted to give you a heads up about this!
Let me know if you have any other questions!
Shane
Old 05-11-2015, 08:32 PM   #9
Hm I clicked on the link and could only find upper control arms. Not sure what it means then
Old 05-11-2015, 08:48 PM   #10
Diehard's Avatar
One of the people that used the term will probably clarify it.
Old 05-11-2015, 10:26 PM   #11
oxford5pointoh's Avatar
Auto correct fail bud. I meant UCA each time
I work retail so I use UPC ALOT and my phone thinks that MUST be what I want to say.
IG @Oxford5pointoh
Old 05-11-2015, 10:40 PM   #12
And apparently they just took Amshaneleskys profile and made it into AmWill lol
Old 05-12-2015, 05:49 AM   #13
Waylap1's Avatar
Region: New Hampshire
Lol, idk ...wtf? TTYL
Waylap1 is offline   Reply With Quote
Old 05-12-2015, 06:41 AM   #14
jayochs's Avatar
brb lmao lylas qt
Sent from my Samsung Galaxy Note 4 using Tapatalk.
Just asking silverstang 1996-2004 Mustang GT 18 04-28-2007 11:38 AM
Yes i asking this, how do you properly re-oil a filter? Jrw4482 1979-1995 Mustang GT 12 05-14-2006 05:47 PM
LOL some guy asking me if i had a v6... SpectorV The Bar 23 04-07-2005 02:30 PM
I'm sorry but this is just stupid Brent The Bar 13 08-26-2004 07:28 PM
02:34 AM
