Livewire TS cable routing - Mustang Evolution
Old 05-16-2015, 05:47 AM   #1
Hampton CIT's Avatar
Just picked up a Livewire TS from Bama. The only disappointment so far has been the OBDII cable. On the online images the cable has a 90 degree bend where it attaches to the unit. Unfortunately in reality the cable is straight. Who wants a fat cable across the dash?? Tucking it in between windshield and dash. The cable also has an inline block for other connections which is darn awkward to hide. The dash side panel you see with a driver's side door open seems removable. BeforeI go tucking to remove this, I though I'd ask where others are hiding this cable block. Any input is greatly appreciated.
Hampton CIT is offline   Reply With Quote
Old 05-17-2015, 03:05 PM   #2
i pulled out my LH vent and stuck a piece of custom cut wood in there with a ball screwed on the end to mount the holder. it works well,is hidden out of sight. i also heard that SCT have released a new version of the livewire ts with a obd plug on back instead of the side
eats7 is offline   Reply With Quote
Old 05-17-2015, 05:28 PM   #3
Thanks eats. I looked at the Livewire TS + (with the port in the rear) but figured no big deal because of the 90 cable as shown in the marketing picture. I got my cable inline block tucked away after messing with spacing and a generous application of zip ties under the dash.
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
FI Belt Routing Problem. primer2tone 1996-2004 Mustang GT 2 11-26-2012 07:05 PM
Clutch Cable routing? MustangGT02 1996-2004 Mustang GT 3 08-18-2012 01:41 PM
Vacuum routing diagram Tj88mustang 1979-1995 Mustang GT 16 11-10-2011 04:01 AM
Gauge Wire Routing w/CDC gauge pod tripod_2005 2005-2010 Mustang GT 13 04-30-2010 11:46 AM
Wiring Harness Routing? Marx 2.3 Mustang 3 03-17-2010 11:44 AM
09:41 PM
