E85 and other alcohols - Mustang Evolution
Old 05-16-2015, 03:34 PM   #1
elkoritaNAY's Avatar
Hi everyone
Just finished watching this documentary on Netflix. It sounds intriguing. There are converter kits to make your car a flex fuel car. Just curious has any one on here tried this or does anybody here run on something else but gasoline? In particular, done these changes to a mustang.
Flowmaster force 2 exhaust, jlt cai, x4 bama tuner, carbon fiber dash overlay kit, modern retro shift knob, mmd hood and side scoops, classic quarter louvers, gt500 spoiler, 3.7 and pony emblems, mustang rocker stripes, eibach anti sway roll bar kit, Bbk shorty ceramic tuned headers
elkoritaNAY is offline   Reply With Quote
Old 05-16-2015, 03:36 PM   #2
natestang07's Avatar
A few guys around here run e85.
Old 05-16-2015, 04:01 PM   #3
Rapinator126's Avatar
E85. Simple swap
Old 05-16-2015, 04:08 PM   #4
With all the food shortages in this world I find it immoral to put food in our gas tanks. But I suppose it would save you some money to cover the rising cost of beef due to the shortage of corn to feed the cattle. Beyond that you run into the issue of engines running hotter on alcohol therefore running less efficiently and not lasting as long.
BrewGuy is offline   Reply With Quote
Old 05-16-2015, 04:10 PM   #5
Old 05-16-2015, 04:10 PM   #6
According to the doc, there is a by product when burning the corn, there is no actual waste. I'm no expert at it, just curious to the idea. It's an interestingness documentary.
Old 05-16-2015, 04:11 PM   #7
And that's why you don't smoke Crack.
Old 05-16-2015, 07:44 PM   #8
Voltwings's Avatar
All the testing and research i have done has proven alcohol to actually run much cooler, but i am interested to hear what your research has to say.
it is possible to have a full catless, mufflerless exhaust and still pass a "sniff" test if the car is running E85.
As soon as i saw you were in this thread i couldnt wait to see your response haha.
We've run E85 in quite a few of our cars and actually race my fiance's V6 on a 50/50 blend (shout out to the guys at MPT). Really there isnt much (if any) horsepower benefit past 50/50, sometimes even as little as 25% E85, you only want enough E85 in the system to combat the knock.
E85 has less BTU (Think power potential) than 93, but obviously has a much higher knock resistance. What this means is you can tune more power into the E85 (due to higher knock resistance) but it takes more to make the same amount of power (hence, the need for extra fuel when switching to E85). I had the math somewhere broken down of a car i had tuned where we compared E85 and 93 blend, 93 spraying meth, and then a blend of e85 and 93 spraying meth and the math proved 93 + meth "made the most power." What i mean is that on paper, that set up had the highest power potential, strictly speaking from a physics and chemistry stand point. ** see disclaimer below.
The reason most tuners will run you on 100% E85 is simple: consistency and convenience. Blending fuels at the pump is somewhat of a pain, and obviously you will never get exactly the same blend every single time, so the tune does need some up keep. Obviously a tuner does not want to, nor can they afford to, deal with people constantly throwing off their blends and screwing up the fuel trims. Therefore, most people just run on 100% E85 for the above reasons. Nothing wrong with that, but given the option to self tune throw some 93 in there.
** Despite meth having a higher power potential, it also has a higher failure potential. You can solder in the best controller, pump, what have you, it is a still a stand alone system that can fail. E85 going through your cars stock fuel system really cannot...
Old 05-16-2015, 07:48 PM   #9
Voltwings's Avatar
I realized i never actually answered the question though. On my fiance's car, ( catless H-pipe + air raid intake) we saw a marginal gain in top end horsepower, maybe 5-7 at best. The real gains were mid range torque, where if i remember correctly it was an easy 10-12 wtq gain in the mid range, it is certainly noticeable. It also will make power a little more consistent when at the drag strip since heat soak is not as much of a factor. Heat soak will obviously be pulling hot air into the engine, but at least you dont need to be worrying about timing pulled as well.
Old 05-16-2015, 08:33 PM   #10
alrefire's Avatar
Took the words out of my mouth.
I guess I should inform you that most of the corn produced is used for animal feed, not human consumption.
Old 05-16-2015, 10:19 PM   #11
You guys are the reason why his prices are going up
Old 05-16-2015, 10:26 PM   #12
9 out of 10 fields here are grain fields. Verrrrrrry few sweet corn fields
Old 05-17-2015, 10:10 AM   #13
Fabman's Avatar
Alcohol burns cooler, not hotter....and there is a huge surplus of GMO corn used for fuels.
That corn is not edible by humans.
Tuned by AED
*694 RWHP/677 RWTQ* 10.22@136mph
Currently Assaulting California's Roadcourses
Fabman is offline   Reply With Quote
Old 05-17-2015, 10:11 AM   #14
Fabman's Avatar
e85 here...the stuff is awesome.
110 racing fuel 16.75/gal
e85/4 bucks.
Running 20 psi on the street full time/priceless.
Tuned by AED
Old 05-17-2015, 01:16 PM   #15
e85/4 bucks.
Fabman so all I need is a converter kit? How did you change it? Is it only beneficial for turbo/supercharger? Do you have to retune?
Old 05-17-2015, 01:19 PM   #16
e85/4 bucks.
Yeah I figured you did but didn't want to say for sure just in case you didn't lol
Old 05-17-2015, 01:22 PM   #17
Fabman's Avatar
Definitely re tune. There are kits out there, mine was done when I installed my big motor so you won't need all the stuff that I did. Basically it runs way cooler allowing you to run more timing/boost than with gasoline. Racing fuel also does this but is hyper expensive. It basically depends on what you want from it. For a daily driver its negligible. Also depends on how available it is in your area.
My F150 Coyote motor was flex fuel and I ran either e85 or gas depending one what was available. My twin turbo F150 Tremor is not flex fuel and I miss that.
Tuned by AED
Old 05-17-2015, 02:08 PM   #18
Voltwings's Avatar
You dont need a "converter kit," you just need a fuel system that can handle the extra capacity. The stock v6 fuel system will handle 50/50 just fine, but 100% requires a retune.
Old 05-17-2015, 02:32 PM   #19
Fabman's Avatar
A filter change is necessary at minimum as paper elements do not do well with ethanol. I've never ran less that 100% ethanol so I'm not sure how easy it is on components when you run 50/50 but it's still hydrophobic and collects water and rusts parts, or so the story goes. There are some reputable tuners and manufacturers that claim a whole litany of items must be changed....others, say otherwise. Best bet is to talk to a tuner who uses e85 regularly. The web is full of experts who speak from inexperience, and I for one am no expert.
Go to the source.
Tuned by AED
Old 05-17-2015, 02:36 PM   #20
Fabman's Avatar
This is a super good thread....check it out.
E85 What you Need To Know!!
Tuned by AED
Old 05-17-2015, 02:40 PM   #21
I grew up in Iowa. I understand that the corn they use for ethanol is feed corn, whence my comment on the cost of beef. There is a direct correlation.
Old 05-17-2015, 02:42 PM   #22
Fabman's Avatar
Yeah, I caught that....but from what I've read (read-can't swear to this) is that there is a surplus of feed stock that's just wasting away....
Tuned by AED
Old 05-17-2015, 02:46 PM   #23
I doubt there is a shortage of feed that effects beef
Old 05-17-2015, 02:47 PM   #24
Fabman's Avatar
This is the kit I used plus ID1000injectors:
DivisionX 2005-2010 3V Mustang GT 1000rwhp Return Style Fuel System
Here is an excerpt:
E85 USERS: We recommend using the Walbro F90000267 465lph pumps as these are the only pumps sold by Walbro as a 100% E85/Flex Fuel compatible fuel pump. We also recommend using the DivisionX DX-0010MW fuel filter with wire mesh filter element as paper elements are not compatible with E85.
Tuned by AED
Old 05-17-2015, 03:12 PM   #25
When E85 became popular there was a major spike in the cost of beef for exactly that reason. More competition for the supply of feed raised the price of it. That is why a cut of fillet mignon is 13 bucks. 90% lean ground beef is $5.99 a pound etc.
Old 05-17-2015, 03:20 PM   #26
GrabberMeBlue's Avatar
Shoot deer and don't worry about the cost of beef.
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 05-17-2015, 03:20 PM   #27
Back east that is very much possible. Here in Central Washington not so much lol
Old 05-17-2015, 03:23 PM   #28
I'm in Wisconsin. Lucky enough to shoot 2 or 3 every year, and that's usually only going out 4 days or so, and on public land.
1979 Gold Trans Am
Old 05-17-2015, 03:24 PM   #29
I still have yet to be drawn for a double tag in my life. One a year for me lol and the occasional spike elk
e85 and proper oil in coyotes. Rapinator126 2011-2014 Mustang GT 52 01-05-2014 07:43 PM
E85 testing on NA 08 Mustang GT 4.6L 3V justin00stang 1996-2004 Mustang GT 8 07-30-2008 01:49 PM
Anyone heard of E85? Dom The Bar 5 04-27-2006 12:20 PM
Has anyone filled up with E85 105 Octane gas? Vash Pre-2005 V6 Mustang 5 01-05-2006 08:08 AM
04:30 PM
