Lowering Spring Installation - No Spring Compressor?? - Mustang Evolution
Old 05-17-2015, 03:05 PM   #1
Mean14's Avatar
So I came across this video and was wondering if anyone has ever tried jacking up the front like this to compress the spring when installing lowering springs...
Anyone have experience with this? Seems like it would save a good amount of time.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 05-17-2015, 05:13 PM   #2
alrefire's Avatar
Why not just go rent the tool for 50 bucks? You get your money back when you return it.
Better than doing that ghetto-fabulous method :p
Old 05-17-2015, 05:40 PM   #3
Mean14's Avatar
I have a spring compressor. I'm asking if anyone has experience with this.
Old 05-17-2015, 06:57 PM   #4
Voltwings's Avatar
its possible for the car to be raised off the jack stands when using this method if you're not careful with the jack. I'm not a fan.
Old 05-18-2015, 03:12 AM   #5
iantrusive's Avatar
I did this and it was actually a hell of a lot easier than using compressors. Had to use compressors for the back though because my dad and I couldn't drop the axle far down enough. We never figured out what caused the axle to stop dropping lol.
Sent from my Mustang.
iantrusive is offline   Reply With Quote
Old 05-18-2015, 08:04 AM   #6
Mean14's Avatar
Good to know, you have a v6? And did you disconnect the Sway bar links for the rear?
Old 05-18-2015, 08:08 AM   #7
Voltwings's Avatar
you'll have to remove the lower strut nut on the axle too, as well as the sway bar mid links. At least we did.
Old 05-18-2015, 09:38 AM   #8
jande063's Avatar
Same, just the shock bolts, and the drop links.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 05-18-2015, 01:06 PM   #9
alrefire's Avatar
Forr a grand total of 15 minutes :p
Old 05-18-2015, 01:28 PM   #10
Voltwings's Avatar
My fiance did the entire rear by herself in 20.
Electric Impact Wrench - 1/2"
Old 05-18-2015, 11:05 PM   #11
2011fastford's Avatar
Region: New Mexico
if you happend to have load on the axle that could have been your problem..
2011 Mustang V6 auto/procharger p1sc kit with 3.70 pulley/circle d 3200 stall/4:10 gears/dss aluminum driveshaft/tial q bov/bbk long tubes with catted x pipe/dynomax ultra flo catback/bbk throttle body/accel super coils/cyclone ported upper and lower intake manifolds/brembo front brake kit
INSTAGRAM @2011fastford505
2011fastford is offline   Reply With Quote
Old 05-21-2015, 10:39 PM   #12
alrefire's Avatar
I bought an air impact gun the other day. Made spring install on a buddy's scion much easier.
Old 05-22-2015, 12:48 AM   #13
iantrusive's Avatar
Sorry guys, yes I have a 6 and the rear sway bar was disconnected. Everything as far as I know was disconnected with no load. We even raised the axle and lowered it again about 3 times trying to find where it was getting stuck, no dice. luckily it dropped enough to get the spring compressor on there, so we just did it that way. You probably won't have the same issue, haven't heard of anyone else having that problem haha
Installing Cams on 4.6 with no spring compressor? Joe Dirt 222 2005-2010 Mustang GT 4 03-30-2015 08:53 PM
Questionable spring installation bigmac3 1996-2004 Mustang GT 6 12-09-2014 12:29 PM
coil spring compressor needed to install eibach springs? rwheels 2011-2014 Mustang GT 6 01-11-2014 11:59 AM
Spring installation Top stang 1996-2004 Mustang GT 6 04-27-2013 11:34 AM
Spring compressor help? iStang65 Classic Mustangs 5 01-24-2013 05:48 AM
04:18 PM
