TSB 14-0212 - Mustang Evolution
Old 05-18-2015, 03:38 PM   #1
TSB 14-0212
Wife has had her new 2013 mustang 7 days and water pump is leaking and it does not have the updated hose that stops air from taking water pump out. My question is
She bought car at a Buick GMC dealer they gave us drivetrain warranty but it does not cover water pump, Could I take this to a ford dealer and have the TSB repair done?
Or do i need to buy parts and fix it myself? Thanks Steve Car has 32,400 miles.
2013 V-6 AUTO COUPE
1965 MKII Roadster Factory Five
steve63 is offline   Reply With Quote
Old 05-18-2015, 03:40 PM   #2
natestang07's Avatar
Typically tsbs aren't covered by dealerships. Doesn't hurt to call and ask
Old 05-18-2015, 04:05 PM   #3
forceflow2's Avatar
They'll do the work if you ask them, but you're certainly going to have to pay for it. Even if you had a warranty, the TSB is really only used for informing technicians of how to perform a repair, it's not the same as a recall. If there was a warranty and they didn't believe that the issue is what the TSB covered, they aren't really under any obligation to carry out the repair described in it.
2013 V6 Premium GHIG purchased 01/16/13
forceflow2 is offline   Reply With Quote
Old 05-18-2015, 04:57 PM   #4
Shadetree43's Avatar
Wouldn't a 2013 with less than 36,000 miles still be under initial bumper - bumper warranty? I'd try a Ford dealer soon.
14 SGM V6 Prem Vert
CS Upper/Lower Grill | GT Mufflers | JLT Catch Can | PP Engine Cover | Steeda PH Brace | JDM Adj PH bar | AMR 18x9 Dark Stainless -Cont Contact Sport 235-55x18 | Roush Vent Pod/Oil Pressure Gauge | Airaid MIT - aFe Pro S |MMD Hood Struts | Steeda Jacking Rails | Prev Maint Rear Axle Vent tube, Radiator degass tube
Shadetree43 is offline   Reply With Quote
Old 05-18-2015, 05:00 PM   #5
Yes, it should but act fast you are definitely getting close depending what the original sales date was.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 05-19-2015, 04:47 AM   #6
ponie1992's Avatar
My 2012 had the leaking water pump syndrome. I had just under 34000 miles when I took it into the dealer. I was over the 3 year mark and the dealer covered it under drivetrain warranty. I have a good thread about it in this section.
Jeremy
Jeremy
2016 Ruby Red PP GT
ponie1992 is online now   Reply With Quote
Old 05-19-2015, 02:33 PM   #7
Ford is going to do the repair under warranty WOO HOO
2013 V-6 AUTO COUPE
Old 05-19-2015, 02:51 PM   #8
ponie1992's Avatar
Very cool! Unfortunately, some haven't been so lucky to have theirs covered.
Jeremy
Jeremy
2016 Ruby Red PP GT
Old 06-30-2015, 01:47 PM   #9
In the event someone else comes across this thread while researching TSB 04-0212 regarding the leaking cooling system, I want to share my experience from today.
I just purchased a 2012 Mustang last week with the 3.7 that has 59,000 miles on it. I noticed leaking coolant from the car and took it to my regular mechanic to look at it so he could tell me what was wrong in the event it wasn't covered under warranty, so I wouldn't have to pay my local dealer's $85 diagnostic fee. While he was looking at it he could not find the leak, but did notice some staining on the engine under the water pump indicating it had been leaking. Since my manual stated that the water pump was covered under the powertrain warranty, which is 5 years/60,000 miles, I took it to the dealer. They did confirm that it was a leaking water pump; however they said that only the water pump, br3z8501g was covered under the warranty. They also had to replace the hose er3z8276a and seal 7t4z8590 (per the TSB I found out after my research). They only charged me for the parts, no labor since they did not call me prior to doing the work. Even if they had called, I would have probably argued against having to pay any labor for installing those parts since they would have to be removed and reinstalled when replacing the water pump anyway. So, I came out paying $45.22 in parts. I was glad it happened before the powertrain warranty ran out!
Krisk is offline   Reply With Quote
Old 07-01-2015, 10:18 AM   #10
ponie1992's Avatar
That's not bad considering some people were turned away by the dealer.
Sent from my SM-G920V using Mustang Evolution mobile app
Jeremy
2016 Ruby Red PP GT
'09 GT TSB's ?? FenixBirdWind 2005-2010 Mustang GT 10 11-12-2009 04:36 PM
TSB related to gear install? gmantheman 2005-2010 Mustang GT 5 06-02-2008 09:12 PM
Ford TSB ? drichard Pre-2005 V6 Mustang 4 10-30-2003 06:55 PM
02:38 AM
